Things needed:
New O-ring for drain plug
Oil Filter p/n: 06m198405f
511.00 0W-40: 10 Quarts
T25 torx
T45 torx
32mm socket for oil filter housing
Small pry bar
Crack open the oil cap.
Get the car in the air, flat. And remove the lower car cover. There is 15 T25 torx screws/2 plastic nubs for you to remove to get access to the oil pan.
You'll find the oil pan located in the center front of the car. This will require a T45 too loosen the drain plug. Remove. Drain. It'll take a while... I let that thing drip for about an hour... and only got about 9.5 quarts of oil out. Tighten after to 22ft/lbs. Replace the O-ring.
Now moving on. The oil filter housing is in the engine bay. Right in between the turbo inlets. Loosen that and replace the filter and o-ring and retighten to 16ft/lbs.
Fill 9.5 quarts of oil. Check level in car. Make sure its full. Done.
I'm currently looking to see what oil dipstick we can put in to manually check the oil since these motors seem to burn a bit of oil. Will update when I find anything.
