Results 1 to 12 of 12
Hybrid View
    Junior Member Two Rings
    Jun 05 2015
    Indianapolis
    Can N205 valve be run with only one bolt?
    Replaced my N205 variable valve timing solenoid, in the process of reinstalling the two bolts that hold it in, I snapped the head off one of the bolts. I tried extracting the bolt shaft but was unsuccessful, all I did was destroy the threads.
    I’ve seen other N205 valves with only one mounting bolt, my question is can I get away with just the one bolt holding it in? A few quick drives around the neighborhood have shown no problems or leaking.
    2006 A4 S Line 6 Speed Quattro / APR Stage I / ECS Luft-Technik Intake / 034 Street Density Engine Mounts / ECS Drilled/Slotted Geomet Rotors / VMR 710 18" / Michelin Pilot Super Sports / ECS Tuning Performance Oil Catch Can System / AMMO NYC Drive Clean
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    I guess if it don't leak, its ok. Just keep an eye on it for a few days.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    NOPE don’t bother it will throw the signal off cause it is not fully sealed.
    Go to hardware store there either m6 x1.0 or m5x1.0. Cost last time I bought those was 11 cents per screw.
    Quote Originally Posted by Jayz691 View Post
    If you had any skills training, owned a business and actually worked on customers cars would this be the professional advice you would provide?
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by canadianA4B7 View Post
    Lol, whatever bud, not gonna argue with the "know it all"..cheers.
    Jun 05 2015
    Indianapolis
    I have the correct screw, my problem as I said in my original post is that I destroyed the threads trying to get the old screw out. So that means I can’t get a new screw in where there are damaged threads. The N205 does feel fully sealed as it is now. It’s a total hack job but I’ve got a zip tie through the mangled screw hole and it’s pulled very tight. I’m hoping that will hold for now, the car is going in for some extensive service soon and I’m going to try and find a used housing where the N205 mounts for them to install. Also let’s not berate the skill or experience of others on the forum, we’re all here to provide our best input.
    Feb 15 2016
    Cambridge,Ontario
    My assumption would be it's broken off in the timing cover ?
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 05 2015
    Indianapolis
    You’d be exactly right. The car is going in for major service soon and I’m going to try and find a used timing cover as a replacement.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by eric3D2 View Post
    These covers can be very pricey, hit the yards and see if you can scoop one up... Be very careful with the oil control rings inside that cover...
    Not sure if there is enough material there to drill it out and helicoil it.
    1976 Yamaha XS 360
    Jan 07 2021
    2000 New Beetle, 2007 A4 Cabriolet, 2010 A3 S-Line
    California
    Sounds like a good time to upgrade to the Iabed TSI cam follower conversion kit. Might as well do the cam chain while you are in there…
    In the process of de-beatering a 2007 A4 Cabriolet
    Jan 21 2018
    frackville, pa US
    If your on FB, join the "Audi b7 a4 club" group.. Theres a few guys on there with tons of extra parts. Ya can prob pick up a good used cover for $20-$30.
    Jun 05 2015
    Indianapolis
    Thanks for all the help, guys. I just applied to join that Facebook group. Definitely will be checking out the local places around here in Indy to see if I can find a cover. The TSI cover seems pretty slick too, I was checking that out on ECS. Looks like it uses a different cam follower system.
    Also, no leaks on the N205 so far. Looks like my jank ass zip tie job is holding. I hate doing things like that on my car, and I hate destroying things when I try to fix them. Live and learn I guess.
    Feb 15 2016
    Cambridge,Ontario
    Gotta keep the car running somehow
    1976 Yamaha XS 360
