Originally Posted by
Smac770
You'd have to better document the moment of sync loss. Is it sync'd on engine off and then not sync'd on next engine on, is it dropping sync while engine on; when you notice it, is the passenger temp different (before you turn the driver's temp).
The only visual on sync status is if you press the temp knob and it brings up the temp dial display, you see at the bottom center symbols for the two functions in the CAR - A/C menu: auto recirculate and sync. Or check the status in CAR - A/C menu. The only two ways to break the sync is to select off via the CAR - A/C menu or to change the temp using the passenger side knob.
Maybe your passenger side knob is developing a glitch.
So what happens is this----if I have climate set to 70 on both sides and synced, I can turn the driver's side knob up and/or down all day long and the passenger side always follows. But let's say I leave it at 70 and go home. The next day when I'm leaving, both sides are at 70 just as I left them, but when I turn the driver's side temp, the passenger side doesn't change. And then I go into the MMI system and it shows that it's not in sync, so I manually put it back into sync again. This happens sometimes, not every time. It seems completely random and I never know when it will go out of sync, but it definitely will not stay synced for more than a few days at at time.
And for everyone else, nobody is messing with the passenger side knob because this has happened many times when nobody was in the car except me. And yes, I'm using the same key all the time.
It's bizarre.
