It is very strange. The only possibility I’m considering right now is that the thermostat is potentially stuck open? Preventing the standard heat-up procedure as coolant is circulating the radiator.
Replaced the following sensors:
- Inner V temp sensor
- Cylinder head coolant temp sensor
- Engine block coolant outlet temp sensor
Haven’t replaced the radiator outlet sensor as there isn’t any issues with it afaik.
- - - Updated - - -
Also, replaced the wiring for one of those sensors that was frayed. The wiring is all good now, so doesn’t seem to be the issue either.
