Results 1 to 2 of 2
Threaded View
    Veteran Member Three Rings A4B7Avant's Avatar
    Jun 07 2017
    PA
    Helmholtz resonator design - multiple peaks
    Got the new exhaust mounted the other day and it does have a drone.
    I downloaded a freq analyzing app and the strongest peaks are at 63hz and 125hz with a valley in the response between the two. Interesting that they are one octave apart and I have a suspicion they are interactive or somehow related together.
    The 125hz peak is the dominant one as it is present most of the time and the 63hz mostly occurs only when acceleration. I don't know enough engineering theory to understand the correlation.
    I found an Excel file some MR2 guy created to calculate/design the resonator and I use that (I'm assuming that it is right).
    In any case, I am designing a Helmholtz resonator (Not J pipe) to try to cancel as much of the resonance out as possible and my question is,
    1) What frequency to spec it to? Ie. Do I spec bang-on to the frequency (say 125hz) or do I pick something lower and hope it cancels more of the 63hz peak?
    2) If I spec favoring one peak or another, how much attenuation can I expect on the other peak?
    Here is the link to the calculator.
    https://wilhelmraceworks.com/calcula...resonator.xlsx
    2019 A4 P+ Brilliant Black, Black Optic, Sports Pkg
    2008 A4 Avant SE Ibis White SOLD
