Page 8 of 8 FirstFirst ... 678
Results 281 to 307 of 307
  1. #281
    Aug 12 2021
    02 C5 S6, 68 Lancia Fulvia
    Raleigh, NC
    Stayed up late buttoning up some things because I couldn't resist. Only thing left to assemble is the belly pan.
    Next up, an alignment and a car wash.
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  2. #282
    Veteran Member Three Rings 2.ohhh's Avatar
    Jul 14 2015
    '03 RS6, '18 Mini Clubman S, '13 Explorer Sport
    Annapolis, MD
    Quote Originally Posted by taddraughn View Post
    Yeah really hope future 0A3 swappers see this because it sure as hell beats paying 300 dollars for a box from JHM that doesn't even work.
    Great work as always! Just seeing this as I headed to my beach condo to do some renovation work...Assuming that you are all good and don't need the pigtails, just let me know if you still do (or anyone else for that matter that doesn't have a spare loom around) and I can get out tomorrow morning.
    Now...'94 Land Cruiser, '18 Mini CooperS Clubman 2.0t, '13 Ford Explorer Sport 3.5t...Then...'03 RS6 6spd, '03 A6 2.7t 6spd sedan,
    '83 Rabbit GTI Callaway, '91 Golf GTI 2.0 16v, '99 Golf GTI 2.0, '69 Austin America, '52 Pontiac Chieftain, and many more....
  3. #283
    Veteran Member Four Rings idotavant's Avatar
    Jan 20 2016
    wv
    Welcome to the Ao3 club! I’m allroad 4.2 with jhm ao3 swap. Can’t imagine the even shorter 01e gears
    05 Allroad 4.2 ao3 swap; jhm v3 kit
    06 Dakota 4x4 long travel v8 6spd
    03 Tuono 1000
    04 MB c240 4motion wagon (gf’s)
    02 a4 avant 3.0 tip (defunct; part-out or sale)
  4. #284
    Senior Member Three Rings C5S6's Avatar
    Oct 04 2008
    '02 S6 Avant, '03 A6 Sedan
    CO mountains
    Great job [again!]
    -TJ
    2002 S6 MT6
    2003 A6 2.7t MT6
  5. #285
    Aug 12 2021
    Raleigh, NC
    Quote Originally Posted by idotavant View Post
    When you say JHM swap do you mean you had them do it for you? Sorta interested to know if you have a jhm speedo box installed and if it works.
    Quote Originally Posted by C5S6 View Post
    Great job [again!]
    Thanks! Feels great to have it on the road. Took it for a couple drives today and the first one was a little nerve wracking just waiting for something to go wrong. But everything seems solid and no fluids are escaping so starting to feel like I can trust it.
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  6. #286
    Jan 20 2016
    wv
    Previous owner had them swap it in. I’d be happy to look at things for you. I assumed the speedo was done with a tune. All I know is it works
    However… I do not have cruise control
    03 Tuono 1000
  7. #287
    Aug 12 2021
    Raleigh, NC
    You don't have to take any thing apart to see if it has it.. I was just genuinely curious because I haven't talked to anyone that got their speedo box to work. According to that B6 thread, it should be possible to edit the EEPROM and get the speedo to work without running any physical wires. The ABS module communicates the vehicle speed via CAN and the cluster has all the CAN networks so the info is there, it just doesn't know to use it. I haven't tried my cruise control yet, but I need to enter my gear ratios on my ColorMFA as it cant currently tell between gear 5 and 6
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  8. #288
    Jan 20 2016
    wv
    I’ll take a look. Pics above?
    03 Tuono 1000
  9. #289
    Aug 12 2021
    Raleigh, NC
    Easiest way to tell is probably to see if they ran I wire coming out of the ECU box that goes and plugs into the 3 pin VSS connector.
    Luckily JHM is willing to give me a store credit refund for the speedo box even though I'm outside their 60 day window for doing that; so going to get it shipped out today. I also made them aware that pinning 33 on the ABS module gets your speedo working. To me it seems much better to be using all four wheel speeds and calculating vehicle speed vs relying only on one of the front wheels to give you speed since that would result in incorrect speeds going around corners (not sure if that's really noticeable)
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  10. #290
    Aug 12 2021
    Raleigh, NC
    So last night I set toe on the car so I can feel okay driving it a couple days until my camber gauge comes in. The alignment shop that I was recommended is booked till mid march lol. My toe was really far out when I started last night... 2.6 deg on drivers side front toe out and .94 degrees toe out on the passenger front. I have all four wheels set straight ahead for now. Will take care of camber adjustment this weekend and then check toe again afterward, but thinking I will have it close enough that I can drive for a while without any horrible tire wear or anything.
    Trying to take it easy to let the clutch bed in (if that's really even a thing) but I've been too tempted not to do a couple pulls. This engine is really sweet! So smooth all the way up to redline and you can really feel the distinct power bands from the variable intake manifold working! I can tell I'm really gonna like this car.
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  11. #291
    Jan 20 2016
    wv
    Ok. I know there is a suspicious extra taped wire coming out of there. I haven’t made it to the garage yet
    03 Tuono 1000
  12. #292
    Feb 01 2017
    NoVA
    Nice! I'm sure it's even more responsive with the manual, the tiptronic really sapped some whp (the lighter manual transmission weight is a bonus).
    When I had a broken intake arm it really fell on it's face and once it was upgraded with the gruvenparts arms you really could feel the intake work, probably more so with the 'mush' of the torque converter removed from the equation.
    Nathan
    ____________________________
    '19 SQ5
    '64 356 SC 1720
    '73 914 2.8 6-cyl conversion in progress
    ‘02 S6 Avant - gone to a new owner to live up to it’s potential as a 6-speed
    RIP (tree) ‘99.5 A4 2.8 Quattro Tip - GIAC engine and tip chip, Stage 3 MAF mod, A8 front rotors
  13. #293
    Senior Member Three Rings Jawsman2's Avatar
    Aug 06 2020
    2007 Buell XB12scg, 2002 Mercedes E55 AMG
    Redmond, WA
    Thank you so much for messaging me about this find, I feel like I can finally have some closure with this car if I can make it work for me as well. It's the last piece of the 0A3 puzzle. If you read my thread and this thread, I think anyone should have a pretty good idea of what they're getting into if they choose the 0A3. (And they should consider the 0A3 over the 01E.)
    2002 Tectite Grey/Black E55 AMG Kleemann K2 N/A Kleemann headers/downpipes ecu tune/ x pipe, secondary cat/resonator delete, Supersprint muffler/ H&R/Bilstein
    2007 Buell XB12scg Cherry bomb
    Work email:
    [email protected]
    IG: Jaws.Garage
  14. #294
    Aug 12 2021
    Raleigh, NC
    Quote Originally Posted by Jawsman2 View Post
    No problem! Should work for you as well. One thing that I didn't mentioned that I also did (because I'm not sure if it makes any difference at all) was go into my cluster adaptation on VCDS and modify channel 60 (just subtract 2 from the number) I think the code went from 1027 to 1025?? can't remember exactly. Not sure if that actually matters though.
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  15. #295
    Aug 06 2020
    Redmond, WA
    I'll hit you up when I get around to doing it. I'm going to swap my cars so I can take care of a few things and keep it in my shop.
    Work email:
    [email protected]
    IG: Jaws.Garage
  16. #296
    Aug 17 2014
    Co
    Hey man, great work! Really enjoyed reading through this thread. Question: when you split the intake manifold apart, did you reuse the rubber gasket that seals the two halves? I can’t for the life of me find a part number or anyone even mentioning it. I’m curious what people are doing in order to replace this gasket. Thanks!
  17. #297
    Aug 12 2021
    Raleigh, NC
    Quote Originally Posted by e30bum View Post
    You won't find a part number because it isn't a gasket :) Just lots of clear silicone sealant. Took a bit of effort to remove all of it from the the little channels in the manifold that hold the sealant.
    Audi was just buying the manifolds from Pierburg and state in the self study program that the manifold is "bonded" and not serviceable at all and must be replaced in its entirety if there are issues with it. So I doubt you'd find PNs even for flaps, screws or other components.
    I used Dirko Gray when putting mine back together. Probably doesn't matter much as long as the sealant you use is fuel and oil resistant. Can't remember exactly but I think I may have gone through over a tube of the stuff.
    I would suspect most people just leave the manifold well enough alone.
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  18. #298
    Aug 17 2014
    Co
    Awesome! Thanks for the detailed response. Looking forward to more progress on your build.
  19. #299
    Mar 01 2011
    Calgary
    Am I reading this correctly? A single wire was required to get your speedo working with the 0A3 box?
    I have purchased this kit and am now wondering if it was unnecessary on my B5 S4/D2 S8 0A3 swaps:
    https://www.ultraperformance.co.uk/0...s-trigger-ring
    https://www.ultraperformance.co.uk/0...sensor-bracket
  20. #300
    Aug 12 2021
    Raleigh, NC
    Quote Originally Posted by zipdoa View Post
    That's correct. I think this will depend on what ABS module you have but if its the same as the one in the c5 and b6 then it should work for you as well.
    I was thinking about purchasing that kit as well after my jhm box didnt work.
    Sent from my SM-G973U using Audizine Forum mobile app
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  21. #301
    Jan 20 2016
    wv
    I found the box under the dash. I’ll just keep using it, unless doing it your way will help me get cruise control
    03 Tuono 1000
  22. #302
    Aug 12 2021
    Raleigh, NC
    My cruise works fine, so might be worth a try. If you want to try I can mail you a couple pins if you need.
    2002 S6 0A3 Swap
    1968 Lancia Fulvia
  23. #303
    Jan 20 2016
    wv
    That would be great. The pins are for the abs module? I’ll pm you
    03 Tuono 1000
  24. #304
    Mar 04 2015
    Denver
    what axles did you use for this trans swap?
  25. #305
    Jan 20 2016
    wv
    Quote Originally Posted by Booested4door View Post
    The c5 4.2/0A3 combo requires 2 x rt front mt b6s4 axles
    03 Tuono 1000
  26. #306
    Mar 04 2015
    Denver
    killer! thanks man! have one, need to find another. good to know im on the right path
  27. #307
    Feb 01 2017
    NoVA
    Surprised to see it listed. I miss that car!!!
    My daughter was complaining my new car doesn’t have rear seat heater like the S6 did.
    https://carsandbids.com/auctions/9a0...-audi-s6-avant
    Nathan
    '19 SQ5
    '64 356 SC 1720
