Results 1 to 15 of 15
    Junior Member Two Rings b6_nikola's Avatar
    Jun 13 2019
    Chicago
    CAT Monitor test won’t turn on in VCDS
    Been having an issue the last few months with the cat monitor not setting ready. I bought a hex cable & downloaded vcds. deleted any codes that were stored & then ran readiness tests for all the monitors. all ready except cat monitor. when i go to block 46 to run the test, it wont even turn it on/run it. any tips??
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Is your car tuned? If so, what tuning do you have?
    Sent from my Pixel 5
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Were any of the stored codes related to oxygen sensors? And if you drive the car for an extended period (at least 50 miles), do any codes return?
    2001 Corvette (C5) Z06
    Active Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    In order to run all emissions test you need to do these in the order listed here. Hope this helps.
    Catalyst test needs a temp of 550 degrees C to start running the test. Please follow the chart and report back.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles, Odometer matching, SKC/Pin retrieval services/ Component Protection/Module Coding/Diagnosis Services and repairs.RB4/RB8 Specialist cloning and repairs. Located in Northern NJ. For inquries pm for details or contact me via Whatsapp
    Ziddy Autowerks
    Jun 13 2019
    Chicago
    Quote Originally Posted by imnuts View Post
    yes it is tuned. it’s an older Revo stage 2 tune. previous owner has ran it for about 10 years with no issues at all
    Jun 13 2019
    Chicago
    Quote Originally Posted by EuroxS4 View Post
    ive done it multiple times over the last few months. the cat monitor test wont run. channel 3 stays at 0 & does not change value. im gonna change the o2 sensors when i get back home & see if that changes anything
    May 22 2012
    Estonia
    Hi,
    If I remember correctly, then you have to run 034 and 036 at first. Only after that 046 activates. And as EuroxS4 said temp is important.
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by ReinS View Post
    Hi,
    Yes they have to be done in that order as mentioned. However Field 3 staying at 0 would indicate an issue. If the vehicle throwing any faults at this time for o2 sensors or anything?? IIRC Field 3 usually shows flow in g/s to determine flow and then determines wether the cat is good or not. Does MVB 036 show b1-s2 ok in field 2 when running that test?? If rear o2 sensor is coded out It will never set readiness for catalyst.
    Ziddy Autowerks
    Jun 13 2019
    Chicago
    no codes for o2 sensors. yes b1-s1 ok & b1-s2 ok. ran thru tests multiple times. im gonna change o2 sensors see if that changes anything if not gonna have to swap injectors & flash it back to stock & see if that helps. previous owner who had it tuned is on audizine & ive been in contact with him & he doesnt think rear o2 was disabled since he always passed emissions. but since it is an older tune (10yrs old) theres a possibility it was.
    Aug 12 2009
    Dirty Jerz
    Most places will allow you to pass with one readiness monitor not set. I'm not sure how REVO did their tune, so I can't say for certain that is the case, but it is a possibility.
    Jun 13 2019
    Chicago
    unfortunately cat monitor has to be ready for me to pass :( & i dont have anyone local that wants to look at the tune. audi dealership wont touch it since it’s tuned. i bought some used oem injectors just incase i need to go back to stock to pass emissions
    Senior Member Two Rings frogspit's Avatar
    Jul 15 2017
    CA
    revo stage 2 disables that test, you need to flash back to stock. iirc the revo stage 1 tune doesnt code out the test either, but 2 and above does
    GTX2863R Motoza Tuned E85 17psi
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Quote Originally Posted by frogspit View Post
    A quick google supports this theory.
    They're not scared of you. They're scared of what you represent to 'em.
    Jan 24 2010
    Paramus,NJ USA
    Yes they will let you pas with one monitor not set however that monitor cannot be emissions related. Flash back to stock and set readiness if no cat need to modify CDKAT map in ecu.
    Ziddy Autowerks
    Jun 13 2019
    Chicago
    yup exactly & now the hazards wont stop blinking. i swear every time i leave town some bs happens
