Originally Posted by
EuroxS4
Yes they have to be done in that order as mentioned. However Field 3 staying at 0 would indicate an issue. If the vehicle throwing any faults at this time for o2 sensors or anything?? IIRC Field 3 usually shows flow in g/s to determine flow and then determines wether the cat is good or not. Does MVB 036 show b1-s2 ok in field 2 when running that test?? If rear o2 sensor is coded out It will never set readiness for catalyst.
no codes for o2 sensors. yes b1-s1 ok & b1-s2 ok. ran thru tests multiple times. im gonna change o2 sensors see if that changes anything if not gonna have to swap injectors & flash it back to stock & see if that helps. previous owner who had it tuned is on audizine & ive been in contact with him & he doesnt think rear o2 was disabled since he always passed emissions. but since it is an older tune (10yrs old) theres a possibility it was.
