Results 1 to 9 of 9
    Jan 17 2021
    1980’Ford F-150
    Maple Ridge
    can’t find compression tester with 16mm plug fitting
    so of course audi has to do everything weird. im up in canada and can not find a single solitary leak down or compression tester that isn’t really expensive that includes the 16mm (5/8) fitting. they all have 10/12/14/18 but no bloody 16. can anyone point me in the right direction? under 100 please
    Veteran Member Three Rings Bloomquist's Avatar
    Oct 18 2018
    San Francisco
    Quote Originally Posted by Robscoe View Post
    its a 16mm hex but a 14mm thread. you need a 14mm
    B7 A4 Avant - 'Stage 3' APR k04
    B5 A4 - Getting a VRT build
    Vanagon Tintop - 1.8t
    I'm also on this other site.
    Jan 17 2021
    1980’Ford F-150
    Maple Ridge
    ….. you’re fucking joking right?
    Jan 17 2021
    1980’Ford F-150
    Maple Ridge
    i’ve been losing my actual mind trying to find one with the m16 fitting. Are you certain that it’s a 14mm?
    Junior Member Two Rings
    Oct 09 2017
    Saratoga
    Yes, there are no normal 16mm plugs. 14mm is the common size.
    Oct 18 2018
    San Francisco
    not joking you, i own a compression tester and a leakdown tester. 14mm. just look at a spark plug the diameter of the threads is smaller than the hex.
    Jan 17 2021
    1980’Ford F-150
    Maple Ridge
    dear lord i’m stupid. well thanks for letting me know lol here i was just absolutely cheesed that only like 200 dollar ones have the 16mm. ffs why would i think that the hex size had anything to do with the thread size. Guess that’s what 15 hour days does to your brain
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Haha I’ve been there, too. Good luck on the compression test
    Oct 18 2018
    San Francisco
    haha no worries! I feel you. Good luck with the test!
