Results 1 to 8 of 8
    Junior Member Two Rings
    Jan 28 2020
    Brooklyn NY
    HELPPP, how to manually put car into neutral
    I’m praying to the Audi gods that someone here can help me out. So I lost my only key to my b8.5 s4 (I know I messed up so pls save the negative comments). I have a new key waiting for me at the dealership but the car is currently in my driveway with about 2.5ft of space on both sides, tow truck company told me it’s not enough room on the sides to slide in the dollys to roll it out. And the service advisor at Audi told me there’s no way I can manually put my car in neutral but I’m here to double check that. Does anyone know how I can put this thing into neutral so I can roll it out of the driveway safely? I couldn’t find any videos online that were specific to my year/model. Any help would be greatly appreciated
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Is it unlocked? If yes, then this is not a huge problem, you can remove the coin holder/cigarette tray in front of the shifter and depress the "button" which releases shift lock solenoid with allen key. There's a dropbox service manual link shared on this forum, called 8K service manual or something, and you can find this info either in stronic or "stronic service" docs.
    If the car is locked, I'm pretty sure tow people know how to open the windows from the outside, so shouldn't be a problem.
    Jan 28 2020
    Brooklyn NY
    The car is locked right now. Audi has my new key so I’m going to go pick it up and use it to open the door and try that method. I appreciate the help man
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by fastboatster View Post
    Is it unlocked? If yes, then this is not a huge problem, you can remove the coin holder/cigarette tray in front of the shifter and depress the "button" which releases shift lock solenoid with allen key. ...
    According to the owner's manual, even if the car is unlocked, you still need to have the key. Here's a copy/pasted section of the "Selector lever emergency release" (verbatim from page 98 of a 2014 manual):
    Applies to vehicles: with multitronic/S tronic/tiptronic
    If the vehicle's power supply fails, the selector lever can be released in an emergency.
    * To access the emergency release mechanism, remove the ashtray insert "B" using the release switch "A" >fig. 108 .
    * Loosen and remove the cap in the ashtray mount.
    * You now have access to a pin. Using a screwdriver or similar object, press the pin down and hold it in that position >fig. 109.
    * Now press the release button and move the selector lever to the N position.
    The selector lever can only be moved from the P position if the key is in the lock and the ignition is switched on. If the power supply fails (for example, the battery is discharged) and the vehicle must be pushed or towed, move the selector lever to the N position first using the emergency release.
    That last paragraph is a bit confusing, as if the battery is dead, it would still seem that, as long as the car is unlocked, you would be able to access the ashtray insert and push the release button as required to move the selector lever from the P to the N position. That said however, if the steering wheel is locked and cannot be released, pushing the car forward or backwards in a straight line would be challenging.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Apr 23 2019
    CA
    I didn't have the key in the lock and the ignition was off (actually the battery was completely disconnected) when I needed to move the selector lever from P to D to connect the selector lever cable to the trans when I was messing with my trans.
    P.S. the car was left unlocked before I disconnected the battery so Idk. That said, I'm pretty sure the car doesn't need to have a key in the lock to release the selector lever, it's a pretty standard feature probably mandated somewhere so that the cars could be easily towed away when needed.
    Apr 20 2021
    South Africa
    Can move selector without the key but you cannot release the handbrake , but a new audi key should be programmed to the car already
    Current Ride:
    Audi B8 S4 Phantom black Stock ++
    Previous Rides:
    Audi B6 S4 Nogaro Blue ,full exhaust ,cams ,valves and headgaskets
    Audi 8l S3 Silver stage 2+
    Audi 8l A3 1.8T heavily modified
    Jan 28 2020
    Brooklyn NY
    so I got car in neutral. Anyone know how to unlock my steering wheel so I can get it out of my driveway properly?
    Jul 18 2010
    NE Ohio
    Perhaps you can borrow some car dollies, the kind used to roll vehicles around in tight spaces (e.g., a garage). Alternatively, and probably not fun would be to disconnect the coupling on the intermediate shaft. The steering wheel would stay locked but the front wheels would be able to be moved (I think!). Here's a pic of the shaft:
    A reputable towing company experienced with moving cars would likely have the dollies and can assist you. Keep us posted!
