Results 1 to 10 of 10
    Junior Member One Ring
    Aug 11 2021
    Kokomo, Indiana
    D1S to replace stock D3S
    I have a 12 A4 S-Line with Xenon lighting.
    I have the dipped headlight message and the driver side headlight is out. My buddy who has had some A4's (B7'S) gave me a new set of D1S 6000K SuperVision bulbs. He said they are interchangeable. I am concerned about replacing the D3S bulbs with D1S bulbs.
    Is there a concern in changing them out.
    I have read the voltage requirements are not the same and I don't want to cause other failures in order to save some some money in the short term.
    Any feedback would be greatly appreciated.
    Thanks
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    Buy D3S and get on with the change. 5500K for the most likeliness to the DRL.
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Aug 11 2021
    Kokomo, Indiana
    It says original is 4300K, would you still go with the 5500K.
    Alan
    Established Member Two Rings Hagasan41's Avatar
    Sep 16 2013
    Orlando
    Quote Originally Posted by AlanB8A4 View Post
    Alan
    4300k is better for inclimate weather such as rain/fog and snow as it doesn't reflect light into the driver when compared to the the higher kelvin bulbs. Just depends what you're after as you'll need to make a sacrafice. If you prefer the whiter/blueish light then go with a 5000-6000k bulb.
    2015 A4 Quattro S-line 6MT Glacier White/Black
    Jul 16 2018
    Atlanta
    You can't replace the D3S with D1S, completely wrong voltage.
    And I concur you should stick to 4300K for better all weather operation. The more full white balance of 5k-6k is going to make your iris close down more and make it even harder to pick up the less sensitive red and yellow colors. That center stripe is yellow. Plus that blue light is going to scatter that much more in fog.
    If it's a non-running show car, 10k all the way. But if you have to actually drive it on real roads in real weather, 4k (4300).
    Aug 11 2021
    Kokomo, Indiana
    Thank you all for the feedback.
    Going with the originals!
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by Hagasan41 View Post
    Quote Originally Posted by Smac770 View Post
    Even though I personally run 5500k, I completely agree with Hagasan and Smac. There's a reason 4300-4500k is the standard OEM temperature. By moving up the temp spectrum you begin sacrificing visibility.
    Am I going to swap back? No, because I like the way it looks. But I also live in San Diego where we get like 15 days of 'weather' a year.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Aug 11 2021
    Kokomo, Indiana
    I ordered the Philips D3S from Tire Rack at $78 each. Ill get them Friday and post a pick of the new Driver side and old passenger side(bulb still works)
    Then I'll post a pick of both new ones.
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    I did this as a conversion on my S4, the bulbs are different as posted above.
    Link here for some info............. https://www.audizine.com/forum/showt...headlight+bulb
    Nov 02 2017
    Sweden
    Switched to CBI and will never go back to stock bulbs and Kelvin. So much more useable light on the road now.
