Results 1 to 40 of 54
    Established Member Two Rings Alex M's Avatar
    Apr 19 2021
    C8 A6 VCDS/OBD11 Mods
    Couldn't find anything on this forum, so here are a list of confirmed to be working mods via VCDS or OBD11 long-coding/one-click-apps.
    I'll update as I continue to test.
    Confirmed on 2021 C8 A6 (Premium Plus w/o HD Matrix)
    Gear Display: D off/S on works, however when I tried D on/S on it did not work for me.
    Seat Heating Balancing: Works as intended, car must be equipped with existing functionality.
    Seat Ventilation Balancing: Works as intended, car must be equipped with existing functionality.
    Air Recirculation Memory: Works as intended.
    Seat Belt Warning: Works as intended.
    Needle Sweep: Works as intended.
    Comfort Turn Signal: Works as intended.
    Some notable apps that did NOT work are the RS taillight animation. In order to get it to work, you need to have a car equipped with HD Matrix lighting. Another one that bricked the MMI was the screen startup logo. Set it to Audi Sport and it bricked.
    Shout out to Homer1946 from AudiWorld for his confirmed list on a 2021 C8 A6 Prestige.
    All VAG Mods for C8 A6:
    1. Needle Sweep in Virtual Cockpit - Confirmed
    a. Select Control Module
    b. 17 – Instruments
    c. Coding – 07
    d. Long Coding Helper
    e. Byte 1, Check Bit 0 “Staging, Yes” (Not sure why it’s labelled this way, but it does enable the needle sweep)
    f. Exit Long Coding Helper
    g. Click “Do It!”
    2. Display transmission gear for "D" and "S" drive modes - Confirmed
    b. 02-Auto Trans
    c. Adaptation – 10
    d. Chanel IDE04111-Single Gear Display
    e. Select from New Value drop-down “D on/S on”
    f. Click “Do it!”
    3. Change Parking Assist Speed Threshold - Confirmed (on ‘21 Prestige)
    b. A5-Frt Sens. Dry. Assist
    c. Adaptation – 10
    d. Chanel IDE03782-Switch-off speed for parking assist
    e. Select from New Value drop-down in km/h (default 10 km/h)
    f. Click “Do it
    4. Double Beep When Unlocking Doors- Confirmed
    Description: Enable audible double beep when unlocking the car
    b. 46-Central Conv
    c. Adaptation – 10
    d. sounder_settings_beeptime_opening_central_locking
    e. Change from "no_beep" to "double_beep"
    f. Click “Do it!”
    g. central_locking_system-beep_at_opening
    h. Set to “On”
    i. Click “Do it!”
    5. DRL (Daytime Running Lights) turn Off when vehicle is in Park with EPB applied - Confirmed
    b. 09-Cent. Elect.
    c. Coding – 07
    e. Byte 2, Check Bit 2 “drl_break,active”
    g. Click “Do It!”
    6. Seat Symmetry + Passenger Seat Control Using Driver Seat Controls - Confirmed.
    b. 06–Seat Mem. Pass. and 36-Seat Mem. Drvr.
    c. Coding – 07
    e. Byte 2, Check Bit 5 “seat_symmetry_movement.0=not active / 1=active”
    f. Byte 6, Check Bit 1 “passenger_seat_adjustment_by_driver_seat,0=n ot active / 1 active”
    g. Exit Long Coding Helper
    h. Click “Do It!”
    7. Enable Ability to lock car with Engine running – Confirmed (Warning: With engine running, vehicle can be locked using the door handle or key fob. To unlock the vehicle, the key fob Unlock button must be used.)
    b. 46–Central Conv.
    c. Coding – 07
    e. Byte 9, Check Bit 7 “central_locking_system_lock_unlock_at_engine_runn ing,0=not active / 1 active”
    g. Click “Do It!”
    8. Enable Lap Timer - Confirmed
    b. 17 – Instruments
    c. Coding – 07
    e. Byte 1, Check Bit 3 “Lap counter, Yes”
    g. Click “Do It!”
    9. Daytime Running Lights (DRL) On/Off setting in MMI - Confirmed
    b. 09-Cent. Elect.
    c. Coding – 07
    e. Byte 2, Check Bit 1 “drl_mmi,active”
    g. Click “Do It!”
    10. Automatic Lock On/Off setting in MMI - Confirmed
    b. 46-Central Conv.
    c. Coding – 07
    e. Byte 35, Uncheck Bit 0 “automatic_lock_not_at_mmi,0=not active / 1=active”
    g. Click “Do It!”
    11. Increase Range of Comfort Open/Close with Key - Confirmed on 2021 Prestige
    b. 46-Central Conv
    c. Coding – 07
    e. Byte 13, Uncheck Bit 0 “comfort_operation_range_limitation,0=not active / 1 active”
    g. Click “Do It!”
    12. Activate RS style taillight animation - Confirmed for Prestige (might require taillights already capable of some animation)
    b. 46-Central Conv
    c. Coding – 07
    e. Byte 37, check Bit 4 to change from 0 to 1 - name might be blank or “INFO: SSBR_Variante”
    g. Click “Do It!”
    13. Adaptive Brake Lights (Emergency Brake Light Flash) - Confirmed? (Changes made but difficult to test)
    Description: During emergency braking scenario (e.g. ABS braking), brake lights will strobe. This coding only applies to US-spec vehicles; this is already coded by default for EU- and Canadian-spec vehicles. Example here .
    b. 46-Central Conv
    c. Coding – 07
    e. Byte 21
    f. check Bit 0 “emergency_brake_indication,0=not active / 1 active”
    g. check Bit 2 “emergency_flashing_via_acc,0=not active / 1 active” -(only modify if vehicle is equipped with radar cruise)
    h. check Bit 3 “emergency_flashing_precrash,0=not active / 1 active”
    i. Exit Long Coding Helper
    j. Click “Do It!”
    14. Unblock blocked-while-driving functions- Done. Waiting to confirm.
    Description: The nhtsa adaptations allow a certain number or additional android auto or carplay screens. Much of those are controlled by the calculated speed on the phone. The MMI screens can all be fixed with the below instructions (VCDS). No adverse effects so far. Allow all screens while car is moving:
    You MUST open the hood to bypass the firewall prior to opening the controller. If you fail to do this you must completely power down the car (and wait for that to happen) before you can try again.
    b. 5F-Information Electr
    c. Adaptation-10
    d. Starting at Channel IDE11502-FB_CAR_0, change anything ‘blocked’ to ‘non_blocked’
    e. Starting at Channel ENG167428-nhtsa_properties-limitation_dependency, change all android and apple to ‘non_blocked’
    f. There is also some blocks at “_FB_MISC_” - unknown effect
    g. Click “Do It!”
    15. Adjust Consumption in DIS - Not confirmed
    Description. This allows you to calculate your own mileage based on the pump and your odometer and then correct the DIS reading.
    b. 17 - Instruments
    c. Adaptation - 10
    d. Channel 1B “Display conversions of consumptions and operating ranges”
    e. Change 100 to xxx (see samples below)
    f. Click “Do it!”
    Sample 1 - Calculation based on volume per distance (e.g. l/100km):
    DIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
    Channel 1B will be changed from 100 to 105
    Sample 2 - Calculation based on distance per volume (e.g. MPG):
    DIS: 23 MPG.
    Real: 24 MPG. (100 * 23 / 24 = 95,83)
    Channel 1B will be changed from 100 to 96
    Applied to My Car so far (2021 C8 A6):
    Change the speed to 20 kmh (from the default of 10)
    4. Double Beep When Unlocking Doors - Confirmed
    14. Unblock blocked-while-driving functions - Done. Waiting to confirm.
    Channels I changed to “unblocked” on my 2021 A6 Prestige (US).
    FB_CAR_ 10
    FB_CAR_ 12
    FB_CAR_ 17
    FB_CAR_ 18
    FB_CAR_ 2
    FB_CAR_ 6
    -nhtsa_properties-nhtsa_limitations_switches_for_carplay_no_softkeyb oard
    FB_MISC_10
    FB_MISC 11
    FB_MISC 13
    FB_MISC 15
    FB_MISC 17
    FB_MISC 18
    FB_MISC 2
    FB_MISC 23
    FB_MISC 25
    FB_MISC 26
    FB_MISC 28
    FB_MISC 3
    FB_MISC 30
    FB_MISC 4
    FB_MISC 5
    FB_MISC 6
    FB_MISC 7
    FB_MISC 8
    FB_MISC 9
    2024 Florett Silver A8L D5.5 | Black Optics Plus + Executive Pkg
    ECS Tuning | 034Motorsport | BMC | Ghost | AudiSport
    2021 Ibis White A6 55 C8 | P+ Black Optics, Executive + Luxury Pkg
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    Nice! Thanks for the list. I've done many of these myself following this post/thread over on the OBDEleven C8 forum. This thread is specific to unblocking while driving.
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Registered Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Nice. There was this thread that has some changes.
    https://www.audizine.com/forum/showt...highlight=vcds
    Apr 19 2021
    Totally forgot about that thread...
    Still trying to figure out how to make tail light animation work on a car w/o HD Matrix lightning.
    Senior Member Two Rings aquarian's Avatar
    May 29 2011
    Bellevue, WA
    Now we need someone to find out how to deactivate start/stop.
    2012 Audi R8 V10 - Titanium package - TCU tuned - Hard-wired Escort 8500 X50
    2017 Audi Q7
    2021 Audi S7
    Aug 21 2010
    Carlsbad, CA
    Quote Originally Posted by aquarian View Post
    This has been solved! I installed a memory switch and now the car remembers the state the ASS was in on shut down/restart. I have it disabled and every time I start the car, the ASS is off. Check out post #10 in my build thread for a link to the switch and install description. I know of at least one other C8 owner, an RS6, that installed the same item. Neither of us has any codes, etc. Works perfectly. I couldn’t be happier.
    May 29 2011
    Bellevue, WA
    Quote Originally Posted by pwdrskr View Post
    Yes, I have seen your thread about installing the device, but I was hoping to just use software to disable it...
    2017 Audi Q7
    2021 Audi S7
    Aug 21 2010
    Carlsbad, CA
    Ah, that makes sense. it would seem on the C8 there isn't a software/coding fix outside of the one where the AC is on constantly. I didn't like that solution, hence the switch route.
    Veteran Member Four Rings Treeskier's Avatar
    Feb 06 2017
    RS6; SQ5; Q7; S2k; ROW D90
    Philly
    About to (re)start my VCDS coding adventure...anything new and interesting identified that's not listed above for a '21 RS6?
    Veteran Member Three Rings Vampster's Avatar
    Feb 16 2004
    2019 E-tron, 2013 Audi S6, 2013 Audi Q7 Sline, 1973 Morris Cooper
    San Jose
    Quote Originally Posted by Treeskier View Post
    I need to find some time but I’m interested if we can change the height for the “Raise” feature only for RS6s with air suspension. I know the height can be adjusted but curious if just that feature can be coded.
    2013 S6 V8T
    -AWE Tuning S6 Touring Edition Exhaust
    -Glowing Turbos Mod
    Previous Rides:
    2006 Yamaha R6
    -Yoshimura Exhaust
    2004 A4 1.8TQM
    -GIAC,386cc Injectors,NS Short Shift,RaceTec FMIC,EVO DV,AWE Boost Gauge,Custom Exhaust
    1986 Integra RS
    Oct 06 2019
    Charlotte NC
    Has anyone been able to get the tail light animation to work without the HD Matrix?
    Apr 19 2021
    Quote Originally Posted by skids929 View Post
    Unfortunately, it's not possible unless the HD Matrix is retrofitted.
    Oct 06 2019
    Charlotte NC
    Quote Originally Posted by Alex M View Post
    Isn't HD matrix just the head lights? For a 2022 aren't the tails the same for Prestige and PP?
    Apr 19 2021
    I thought that too, but apparently it's somehow connected. I've tried using a one-click app via OBD11 and I even long-coded it. Nothing.
    If you figure it out, let me know, because I'd love to have it set up without doing a headlight and wiring swap.
    Oct 06 2019
    Charlotte NC
    Any idea what the price is on those headlights?
    Aug 15 2021
    Lawrence, KS
    they are a LOT. 5.6k-12k on europrice
    https://europrice.us/audi/a6-s6-rs6/a6-s6-c8--19?p=3
    Apr 19 2021
    Quote Originally Posted by carguyshu View Post
    There it is. Would've been cheaper to spec the car with them.
    Apr 19 2021
    Couple more I did tonight through OCA and confirmed to work on a P+ C8.
    - Central Lock w/ IGN (Lock car while engine running)
    - Acceleration Display (G-Meter)
    Aug 21 2010
    Carlsbad, CA
    Talking
    Think that's generally the case when trying to update/add things after buying the car. When spec'ing a new car there is a "benefit" in that one gets a monetary "credit" when going from one option to another that you don't get when doing it aftermarket. Probably didn't write that terribly clearly. This fact hit me right in the face when I priced out what it would take to convert from Blackline to Carbon option. Yikes! $~14k or so priced through both Europrice and various OEM parts sellers....and yet the ole wheels are turning. There are few options the car I found and bought that are missing compared to the car I'd ordered: Carbon trim, upgraded B & O System, Gray RS Design Pkg. I've posted elsewhere that I wish I'd sought out a car with the upgraded seats. The sales manager at the dealership had called and talked me out of going with the comfort seats. I went along with his recommendations, and when I started searching for a car on a lot, I specifically eliminated cars with comfort seats. He'd told me that the flat bottomed steering wheel only came with the "regular", diamond stitched seats. However, the standard seats don't have passenger side memory, something that confounds me on a $117k and up luxury vehicle. Our 2019 RS5 with std seats has passenger side memory as well as added adjustability (thigh and back side bolsters) and massage feature! How does the RS6 not as well? Caught me by surprise. Also, the seat upgrade has power thigh support. The s seats are manual. Finally, the upgraded seats have greater heat/cooling area.
    I'll say this, its a lot easier, and cheaper, to add a flat bottom steering wheel, that it is to add comfort seats. I'll admit I miss the feelings of luxury I got every time I sat in our '21 Allroad with upgraded seats. There was a clear distinction between lwsaWish I'd thought to ask more questions...
    Apr 19 2021
    Interesting you say this, and I agree. This is one of the reasons I went with the A6 over an S/RS5. I just really loved the the fact that I get all of the creature comforts and a updated infotainment/tech features. Are those cars funner to drive than the A6? Sure, by miles.
    It's a double-edged sword. So I've come to the conclusion that my ideal Audi would be an S6 or S7.
    Oct 06 2019
    Charlotte NC
    I can promise you those cars are still more fun to drive the S6 or the S7. I've had both an S4 and S6. S4 was way easier to whip around, more mods avaialble too. The S6 is a good sweet spot of power and comfort, waaaaaay more comfortable, less fatiguing to drive than the S4. Tech is better obviously as well. The issue with the S6 is it's just shy of the power it needs/deserves.
    Apr 19 2021
    100%, I bought a B9 S5 last week to flip and drove it for a bit. Fun little car no doubt. But coming from Evo's in my younger days and as I get older I find myself leaning more towards 'luxury sports sedans' rather than nimble compacts.
    Oct 06 2019
    Charlotte NC
    Same! I love my S6 regardless of it not being as quick and exhilarating, I too am getting older and just want to relax but still be sexy 🤣. It's ridiculously comfortable and still fun to drive. If Uni or APR cracks the ECU all the better, Im on it.
    APR intake goes in tomorrow, can't wait for that. Hoping I don't sound like a kid with a Civic and fart cans. Cabin in the S6 is so quiet I doubt it will be an issue.
    Aug 21 2010
    Carlsbad, CA
    Nice! I've been waiting for the APR RS6 intake. There are other options out there that look better, see Eventuri, but APR is the only one that submits for California emissions (CARB) approval. I don't want to have to swap in the OEM intake when emissions testing is due. If the install difficulty of the APR RS6 intake is anything like the APR B9 RS5 intake, then, yeah, definitely don't want to be swapping back and forth. Which reminds me, time go see if CARB has approved the APR RS5 intake yet.
    Jan 14 2019
    Ludington, Michigan
    Not sure what I did wrong but for some reason my Adaptive lights say they are malfunctioning, and now my DRL AND regular lights are on at the same time, not just my DRL during daytime. If anyone has any advice I'd appreciate it. 2021 S6.
    Oct 06 2019
    Charlotte NC
    went to a local shop today experienced with the VCDS tool and they weren't able to lower my 2022 S6 on Air. Audi Apparently changed some things in the menu and he couldn't access the menu needed to lower it without spending at least a day on it. No thanks.
    Kind of a bummer
    2025 SQ7
    Eventuri
    APR Stage1 93
    Ghost Links
    Matrix Activated
    It will eat your Children
    Veteran Member Three Rings bobamoo's Avatar
    Jul 15 2014
    Greensboro, NC
    Just got my OBD11 a couple weeks ago, have made several changes, works great. But to OP, yes, I tried gear display D on/S on as well, only displays gear in S mode. This worked on my A5 Sportback, maybe just not on the A6?
    Apr 19 2021
    Quote Originally Posted by bobamoo View Post
    Yeah it's strange why it won't work on D on the A6. I revisited it again last week to be sure and it still won't display the gear in D.
    Jul 15 2014
    Greensboro, NC
    I tried again the other day. Now it says DSG transmission only. Hmmmmm
    Apr 19 2021
    Yeah, I don't get it. The car has a DSG so no reason as to why it shouldn't work.
    I can try long-coding it. Maybe the one-click app is coded incorrectly?
    Dec 25 2022
    Bluffdale, Utah
    -Can anyone explain what "balanced seat heating" is when enabled?
    -Anyone know how to enable the *drivers* mirror tilt when car is in reverse rather the passengers mirror? Even selecting drivers with the mirror switch it will not do this.
    -Lastly, anyone know how to adjust the time when locking the vehicle and the headlights and taillights shutting off at night? I see in videos online that they immediately shut off when locked however my new 2023 S6 Prestige (US) has them staying on for 30 seconds before they do the animation and shut off after I walk away.
    Dec 20 2006
    CAN
    Hey, just wondering if a new vcds cable is required. I have one from 10 years ago, will it still work? Have an a6 allroad coming in one month and have been dabbling in Porsche, coming back to Audi.
    This is the cable I have. https://www.ross-tech.com/vag-com/ol...rfaces/huc.php
    Are there any differences between this old one and the new V2 version? Other than limiting the number of vehicles you can use it on by VIN?
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by CanuckRS View Post
    You’ll need a newer cable.
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Established Member Two Rings Twotonicnite's Avatar
    Mar 21 2016
    NW Indiana
    Big props for sharing this Alex M! I used a few of these on my A6 Prestige. However, when trying to do the RS taillight animation, instead of a checkbox, my bit 4 shows this:
    Twotonicnite
    *2015 S5 Prestige, black optic, manual, GIAC Stage II Tune, Vorsteiner V-FF 104s, Bilstein B16 w/ IRC Ride Control coilovers, Milltek exhaust, 034 rear swaybar, endlinks, differential, & transmission mounts, ECS carbon intake
    *2016 Q5 Premium Plus 3.0T, S-Line, Exclusive Derby Green Pearl
    *2019 A6 Prestige, Mythos Black, Night Vision
    *2008 Toyota Tundra SR5, bone stock
    Senior Member Two Rings RLwantsS5's Avatar
    Jul 11 2014
    2022 Lexus Ux200 (wife)
    Bonita Springs, FL
    Quote Originally Posted by Twotonicnite View Post
    I can only see one pic. The other link is broken.
    Just an FYI, the tailight animation will not work without the specialty rear tail light housings. Unless something has changed someone let me know...
    Sent from my SM-F926U using Audizine Forum mobile app
    Oct 29 2021
    Fuquay-Varina, NC
    Where it shows 0F at the top, you have to change that to 1F. I couldn't figure that part out, so I got some assistance on the Ross Tech forum.
    Sent from my SM-F721U using Audizine Forum mobile app
    '19 A6 Prestige 3.0
    Apr 19 2021
    Quote Originally Posted by RLwantsS5 View Post
    Correct. Only the prestige headlights and taillights can have the RS animation enabled unfortunately.
    Jul 15 2014
    Greensboro, NC
    I still could not get this to work using OBDEleven. Shawn at Everything Euro in Winston Salem, NC, got it to work using Carista. Now I have it in the display. Carista seems to have better coding change ability, but will not work with the OBDEleven dongle, you have to get a different one.
    Junior Member Two Rings
    Oct 22 2022
    Andover, MA
    Can confirm, could not get this to work with OBD11 (NB: One click app did not try through long coding) but got it to work with Carista in both D/S
    Feb 02 2013
    The C7 platform has like a bible of available mods....is this gen just more locked down or has no one put in the time to figure out what else we can do?
