Results 1 to 9 of 9
    Sep 17 2005
    Fremont, California
    034Motorsport Dynamic+ Tuning for B8 Audi A4, A5, & Q5 2.0T Now Available!
    034Motorsport B8 Audi A4/A5 & Q5 2.0 TFSI (EA888 Gen 2) Performance Software Now Available & at 10% Off!
    Check It Out Here!
    Product Description:
    The 034Motorsport Dynamic+ Stage 1 Tuning Software for Audi B8 A4/A5/Q5 (Not B8.5) equipped with the EA888 Gen 2 2.0T inline four engine is designed to transform the driving experience of your vehicle! Flashed directly through your vehicle’s OBD-II port, 034Motorsport’s proprietary calibrations for the ECU safely and effectively increase the power output of the turbocharged inline four in a refined manner. The result is a significant improvement in acceleration and throttle response, without any sacrifice in driveability or reliability.
    034Motorsport Audi B8 A4/A5/Q5 EA888 Gen 2 2.0T Dynamic+ Performance Software was developed entirely in-house on 034Motorsport's Development B8 A5. The calibrations were then refined on multiple enthusiast-owned beta tester cars around North America.
    034Motorsport engineers develop special inhouse tools that allow us to access the firmware and maps inside the factory ECU, this level of engineering is required to prevent work-arounds and bandaids that many aftermarket companies resort to. 034Motorsport engineers and optimizes the ECU calibrations just like Audi engineers would, but accessing the source of how the ECU controls the engine and making changes at the base level.
    This is the ONLY way 034Motorsport can ensure our calibrations meet our high standards for ultimate power with smooth drivability, perfect function, reliability and added functions and features even beyond what the factory programming can provide.
    NOTE: The E85 calibration is not a flex-fuel style tune. The tune will work with E85 directly from the pump, both summer and winter blends (ethanol content can vary from E60-E85). This tune requires only E85 be pumped into the fuel tank. Gasoline blends and race fuel mixtures should not be used, and engine damage could occur if the incorrect fuel or octane is used. We strongly recommend an ethanol content gauge be used so that you can monitor the actual ethanol content at the pump you are using.
    When switching fuels, it takes about 20-30 minutes of normal driving for the new tank of fuel to fully circulate through the system when filled at E. Please minimize load (don’t floor it!) until you have driven the car for at least 30 minutes. Ethanol content analyzers installed close to the fuel rail will also help you see when the ethanol has fully run through the system.
    Crank Power Figures. See Webpage or attachments for Wheel Horsepower figures as measured on our in-house dynamometers
    STAGE FUEL MAX HP MAX TQ MAX HP GAIN MAX TQ GAIN REV LIMITER SPEED LIMITER
    STOCK 91 OCT (AKI) 213 HP 259 TQ NA NA 6,800 RPM 127 MPH
    STAGE 1 91 OCT (AKI) 252 HP 291 TQ 41 HP @ 6,400 RPM 41 TQ @ 3,200 RPM 6,800 RPM
    STAGE 1 93 OCT (AKI) 270 HP 310 TQ 72 HP @ 5,100 RPM 92 TQ @ 3,200 RPM 6,800 RPM
    STAGE 1 E85 (AKI) 281 HP 349 TQ 72 HP @ 4,600 RPM 100 TQ @ 2,500 RPM 6,800 RPM
    Dynamic+ Tuning Features for the Audi B8 A4, A5, & Q5
    • Increased Horsepower and Torque Through the Powerband
    • Improved Power Delivery, Acceleration, and Driving Characteristics
    • Refined Throttle Mapping for Improved Throttle Response and Precision.
    • Modified Thermal Management Safety Strategies
    • Fuel System Optimization for Ethanol
    • Left Foot Braking Enabled
    • Track-Tested Calibrations Ensure Consistent Power Delivery
    • Speed Limiter Removed for Higher Top Speed.
    • Flashed Directly via the Factory OBD-II Port.
    THERMAL MANAGEMENT SAFETY STRATEGIES
    With increased power, comes increased heat. With increased heat, comes the need for additional management. For charge air temperature, 034Motorsport has implemented key safety features to keep your engine running optimally and safely in virtually any condition - just like the OEM calibration. Substantial effort was spent on balancing the trade off of charge temp for power, and improving the compressor efficiency so that it doesn't generate too much charge temp.
    Charge Air Temp: When the charge temp exceeds 80*C there is a reduction in power output. When the charge temp exceeds 85*C there is a more significant reduction in power output. This charge temp limitation is there to prevent knock events from excessive charge temps, which can severely damage a motor. With these safety measures in place, you can confidently drive your car, from the top of Pikes Peak to Death Valley, knowing the factory ECU has optimal performance and safety covered.
    FUEL SYSTEM OPTIMIZATION
    While E85 provides substantial increases in power, it requires about 30% more fuel than standard pump gasoline per ignition cycle. Utilizing a variety of fuel stratified injection strategies, 034Motorsport calibrators have further optimized the factory fueling system to be able to adequately support full E85 on factory hardware for Stage 1 and Stage 2 tunes.
    Check It Out Here!
    034MOTORSPORT B8 AUDI A4/A5/Q5 EA888 GEN 2 2.0T STAGE DESCRIPTIONS
    STAGE 1
    034Motorsport Stage 1 Performance Software for the EA888 Gen 2 2.0T engine running pump gas or ethanol is engineered to safely increase the horsepower and torque with no additional hardware required.
    In addition to power improvements, 034Motorsport's engineers spent a significant amount of time refining the throttle mapping in order to provide improved throttle response and allow for more precise throttle modulation and further control of the vehicle when driving on track. Due to the limitations of the stock turbocharger on the EA888 Gen 2, the rev limiter was not adjusted.
    034Motorsport EA888 Gen 2 2.0T Performance Software is flashed via the factory OBD-II port, and does not require any physical modification of the factory ECU. Stage 1 is available in 91 Octane, 93 Octane, and E85. ALL FILES ARE US (MON+RON) RATING, ROW OCTANE RATINGS MAY DIFFER. IF YOU ARE A UK/ROW CUSTOMER, PLEASE EMAIL [email protected] FOR ASSISTANCE ON FUEL MAP SELECTION.
    034MOTORSPORT B8 AUDI A4/A5/Q5 EA888 GEN 2 2.0T PERFORMANCE SOFTWARE HARDWARE REQUIREMENTS
    034MOTORSPORT DYNAMIC+ END USER FLASHING KIT
    034Motorsport's Dynamic+ End User Flashing Kit allows customers to install their 034Motorsport Dynamic+ Performance Software themselves. In addition, End User Flashing allows Dynamic+ Performance Software customers to receive and install software updates and revisions, flash back to stock, or upgrade to the next stage of performance software for their vehicle.
    Requirements for End User Flashing:
    Windows 10 Laptop with Available USB Port
    Power Supply for Laptop
    Secure Wired (Or Very Stable WiFi) High-Speed Internet Connection
    Battery Charger, 20AMP minimum (CTEK Brand recommended)
    Available Electrical Outlets
    034Motorsport End User Flashing Kit Contents:
    034Motorsport OBD-II Adapter
    USB-A to USB-B Cable
    Carrying Case
    User Credentials (Provided Via Email)
    EMISSIONS DISCLAIMER
    This product is sold for racing use as well as use on vehicles not registered for on highway use.
    By purchasing this product, you understand that this product is sold for racing use as well as used on vehicles not registered for on highway use, and that it is not legal for use on highway or street vehicles.
    May 29 2015
    Montreal
    I have a 2014 b8.5 a4 with a gen2 motor when will this software be released?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Nick27 View Post
    This is currently in development and should be available later this year.
    -Nick@034
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Full E85 for a B8? 🤔
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Nano909 View Post
    Correct. With proper calibration and fuel control strategies, this is achievable and safe.
    -Nick@034
    May 10 2015
    Pittsburgh PA
    Would this software be compatible with an early 2013 B8.5 6MT with 6-speed and CAEB engine rated to 211hp (compare to 2014+ 220hp cars) ?
    Established Member Two Rings Himsweet66six's Avatar
    Mar 07 2016
    2011 A4 Avant , 2009 S5
    Mundelein, IL
    Will there be a stage 2 /K04 in the works? Also looking to for a Trans tune. Any chance this is in the works?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by 19birel View Post
    I do not believe so as the box codes covered are currently B8 box codes, but feel free to shoot us an email at [email protected] and we can confirm your box code!
    Quote Originally Posted by Himsweet66six View Post
    We are actively doing market research regarding K04 tuning. Simply put, if there is enough interest we can look into creating a K04 file. Currently, we are actively developing a Stage 2 file, as well as a ZF8 TCU tune.
    -Sean@034
    Veteran Member Four Rings Shane Horning's Avatar
    Nov 16 2018
    2012 A6 Prestige IE dual pulley. custom trans tune. mercracing hx. autotech hpfp.
    Upstate. New York.
    Quote Originally Posted by 034Motorsport View Post
    -Sean@034
    Do a strong k04 e85 file for the b8 and I'll buy it! I'm sure there would be a demand
