Page 2 of 17 FirstFirst 123412 ... LastLast
Results 41 to 80 of 655
  1. #41
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by OptimusModulus View Post
    Forgive my ignorance. Assuming we aren't going to be with Sam in person and instead will go to someone else to source the factory scan tool (and windows laptop for good measure), what are we "purchasing" from him? The coding instructions I assume? If that's the case wouldn't a group discount be in procuring the coding instructions? And Leave the labor costs to be dealt with individually? I've refrained from reaching out to him in the meantime while @jetta3vr6 wrangled the group
    I just had Sam flash the matrix lights on my car last night (as well as remove component protection from/calibrate my night vision system, which I retrofitted in). I will post videos and explain more later today, but figured I would just clarify some things now.
    Yes you have to source the VAS5054a yourself (although Sam can connect you with someone you can rent it from). You are not purchasing the coding instructions from him per se. In that case only one person would have to purchase the instructions and then distribute them, honesty notwithstanding.
    What you are paying Sam for is the know-how and labor (as far as I know, nobody else is offering to provide this service remotely). You just give him remote access to your computer, plug the cable in, and watch. He downloads and installs the necessary software onto your computer (which takes time itself given it's a large download) and performs the flash. It is not an extremely straightforward process, and I like the idea that someone who really knows what they are doing is doing it (and Sam definitely does - the night vision coding he did for me was not easy).
    So Sam still has to spend time scheduling with each person, installing the software on each person's computer, and flashing each car. How he wants to work out a possible discount considering that is up to him. But it's not as easy from a time/labor standpoint for him as it might seem. He's probably willing to discount multiple cars in the same location at the same time because he then only has to set up one computer and can knock out all the cars in one block of time.
    I'll ask him what he can do.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
  2. #42
    Junior Member Two Rings
    Jan 25 2021
    Kc
    What is your impression of the working matrix lights?
  3. #43
    Oct 27 2009
    Quote Originally Posted by Ripcordaff View Post
    I'll post more of an explanation tonight when I pull the video from my dash cam showing them working, but I am very happy to finally have it enabled given I live in a very rural area right now.
    I had matrix lights enabled on my F80 M3 and desperately missed having them.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
  4. #44
    Senior Member Two Rings OptimusModulus's Avatar
    May 29 2014
    Chicago, IL
    Nick as always providing the insight that I need. Makes a lot more sense. Let us know what he thinks on that, can probably wrangle some fellow Chicago(and surrounding land)ans
    2024 Ascari []RS6 Performance
    2021 Nardo []RS6 (Sold)
    2013 Ibis White []S5 6MT (Sold)
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.” -- Jeremy Clarkson
  5. #45
    Dec 01 2010
    2008 Jeep Wrangler with a hemi/ 1991 Jeep Grand Wagoner with LSX
    Milwaukee, WI
    I’m located near Milwaukee and I’d make the drive down for it
  6. #46
    Jan 01 2014
    2017 Audi Q7
    Ma
    Sam responded and said if we did a group by they could do 650 per flash.
    Sent from my IN2025 using Tapatalk
  7. #47
    Dec 04 2020
    2019 X7 4.0
    DFW, TX
    In for group buy as well
  8. #48
    Veteran Member Three Rings svra42.8's Avatar
    Oct 11 2006
    Bartlett, Illinois
    I’m in
    2021 Glacier White/Carbon Optic RS7
  9. #49
    Feb 28 2021
    I really want to do this, but my worry is that either an OTA or dealer-installed software update will overwrite it. I had that happen with a BMW on which I had enabled the matrix function (BMW call it anti-dazzle) and I was back to square one and had to pay someone a second time to recode it. For that reason and given the amount that Sam charges, I am hesitating.
    I have had my RS6, my first Audi, since the end of February, so I have no feel for how often Audi does software updates.
    ________________________________
    2021 RS 6 Avant Daytona over Cognac
  10. #50
    Oct 10 2012
    Hamilton / Ontario
    Quote Originally Posted by jetta3vr6 View Post
    I’m in for this as well. Any idea if it matters that I’m in Canada? My good friend is my master tech at an Audi dealership and said I can use his PC, scan tools and cables
  11. #51
    Jan 01 2014
    2017 Audi Q7
    Ma
    Quote Originally Posted by NJA-TRTL View Post
    I can ask Sam if it makes a difference for a Canadian car.
  12. #52
    Junior Member One Ring
    Mar 22 2021
    San Mateo, CA
    Anyone found a video of the instructions for this and/or the difference between matrix or not matrix?
  13. #53
    Oct 27 2009
    As promised, here's a video I pulled from my dash cam and my experience with Sam.
    Right now, I do not believe there's any other option to enable this without going through him (I believe Pacific German is using him as well).
    Apparently the firmware file to enable matrix functionality was difficult for him to obtain. This isn't just a change a few things with vag com process.
    Sam installs a virtual computer onto your computer which has the necessary software (download is ~40gb). You need to buy or borrow a VAS5054a cable.
    The actual flashing process doesn't take very long. I believe around 20min (Sam did a couple other things for me which took much longer, but the matrix part of it was pretty quick).
    As I stated earlier, the price he's charging may seem high, but you're paying him for his time and the ability to do this right now. Currently, this isn't something you can do yourself and there are no "instructions" on how to do it.
    He needs to schedule time with each person separately, take the time to download and set up the software on your computer (takes a bit of time because of the size of the download), and then likely schedule another time to actually perform the flashing process on your car.
    As for the functionality of the matrix lights: this is absolutely how the car should've come stock, and it's apparent it was meant to come this way. I've found the low beams pretty lackluster on dark roads, but the high beams are pretty decent. Without matrix, you are stuck with all or nothing high beams, so if there's any amount of traffic around you are left without them. In reality, our high beams are actually a matrix of light beams that the car can selectively enable/disable. With matrix lights enabled, the car basically leaves the high beams on all the time and selectively turns off the beams where another car is present. I haven't had much time to see it in action so far, but first impression is very positive. Time will tell how well it actually works/if I ever get high beamed, but so far so good.
    Photos/videos:
    Calibration process showing how the car can project the high beams into pretty narrow beams
    New high beam animation
    Driving on a dark road (I manually turn off the high beams at the 8sec mark so you can see the difference having matrix enabled makes)
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
  14. #54
    Nov 08 2019
    Houston, TX
    Photos/videos:
    You need the whole 5054a unit as well as the cable ?
  15. #55
    Oct 27 2009
    Quote Originally Posted by Corgiman30 View Post
    the 5054a is the cable. There's nothing else to it
    You don't need to worry about software either as Sam takes care of that
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
  16. #56
    Veteran Member Three Rings RTW S4's Avatar
    Jan 24 2012
    Philly/South Jersey
    Awesome. Thanks for following up with the info and video!
    IG: rx_hx
  17. #57
    Established Member Two Rings furleeA4's Avatar
    Feb 08 2007
    san diego
    Take my money
    IG: @sir619
    2010 Audi A4
    2021 Audi RS6
  18. #58
    Jul 20 2021
    Los Angeles, CA
    Quote Originally Posted by furleeA4 View Post
    Take my money
    Pacific German will code it for you. Probably not too far from SD
  19. #59
    Feb 08 2007
    san diego
    Quote Originally Posted by Daniel L View Post
    Thx. I will make an appointment with Tyler as soon as I'm done with PPF. Should be done by end of next week.
    IG: @sir619
    2010 Audi A4
    2021 Audi RS6
  20. #60
    Stage 3 Forum Advertiser Four Rings Shawn@PacificGerman's Avatar
    May 07 2007
    20' Urus, 21' 718 GTS, 20' C4S, 20' R8, 19' RS5, 16' TTS
    Laguna Hills
    We've done a bunch so far (three this week, three scheduled for next week)
    Let me know! Saves the local guys the hassle of downloading a huge file, setting up the battery maintainer, buying the VAS clone tool, etc. We use the genuine tool at our shop so there is no risk of failure.
    Pacific German | [email protected] | Porsche, Volkswagen, Audi, Lamborghini, Bentley, BMW Service, Tuning, Repair | Located in Laguna Hills, Ca
  21. #61
    Mar 18 2011
    Denver
    Quote Originally Posted by Shawn@PacificGerman View Post
    You guys want to open a franchise in Denver? 😉
  22. #62
    Mar 22 2021
    San Mateo, CA
    anyone doing this in the San Francisco Bay Area?
  23. #63
    Senior Member Two Rings BklynSQ5's Avatar
    Mar 02 2018
    Manhasset, NY
    Don’t forget about us New Yorkers too!!
    2021 Audi SQ5: Mythos Black/Red, 22" ABL19 wheels, AWE Exhaust, MTM links (wife's)
    2021 BMW Alpina XB7: Blue/White, 23's, Rear entertainment, captains chairs
    2017 MB C63S: Matte White/Brown, Edition 1, Performance seats,
    IG: Bklyngarage
  24. #64
    Junior Member Two Rings rev_hi's Avatar
    Feb 09 2018
    IA
    Does anyone know what version of Windows OS you need for this?
  25. #65
    May 07 2007
    Laguna Hills
    Quote Originally Posted by yas View Post
    Quote Originally Posted by shiftypowers View Post
    I have a guy driving down from NorCal and another guy from Arizona this week. One being sent from Oregon currently in route. Put some miles on those beasts!
  26. #66
    Established Member Two Rings US1787's Avatar
    Jun 28 2020
    Joy
    Virginia
    Anyone available to do this in Washington DC area?
  27. #67
    Oct 27 2009
    Sam now has the ability to enable a blue accent LED on the laser light design element. It is illuminated with the daytime running lights as well as when the headlights are on. Before and after pics (and video) below:
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
  28. #68
    Stage 2 Banner Advertiser Four Rings Miranda@Nemesis's Avatar
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    So cool and so silly why this is this not enabled in NA.
    Sent from my Pet Rock
    [email protected]
    Nemesis Flickr | C43 Build | IG
  29. #69
    Apr 23 2021
    Montreal
    Thanks for sharing, pure car porn with those blue eyes.
  30. #70
    Jan 24 2012
    Philly/South Jersey
    Nice! The blue light is worth the cost by itself lol
    IG: rx_hx
  31. #71
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Matrix Headlights Fully Enabled
    This ol’ thang?
    Quote Originally Posted by Miranda@Nemesis View Post
    Stupid DOT regs since emergency vehicles have blue lights and passenger vehicles are not permitted to have blue lights. Agree it’s silly. Not like EU countries don’t have emergency vehicles with blue lights
  32. #72
    Oct 27 2009
    Quote Originally Posted by Jimminez@Nemesis View Post
    This ol’ thang?
    All I see is orange :P
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
  33. #73
    May 16 2007
    Ottawa CA / DE USA
    Hate u
  34. #74
    Apr 15 2020
    24' Q5e & '18 TTRS
    Nueva York
    [email protected]
  35. #75
    Sep 24 2020
    Sacramento CA
    Man I cant wait to get this done on mine!
    2022 AE Java Green RS6
    @tokensjgrs6
    2006 Volvo V70R, Kt4 Hybrid Turbo, Stage 3 HiltonTune ,TME DP, TME full race exhaust
    2000 Lightning Blue Saab Viggen, Stage 1 Mods
    1985 Toyota Supra w/2JZ single Turbo, 610hp- 592 ft/tq, heavily modified
  36. #76
    Jul 20 2021
    Los Angeles, CA
    I can see these being super helpful on a 1-2 lane road but how is it on a freeway in an urban or suburban environment? How many cars can the matrix headlights shield simultaneously?
  37. #77
    Veteran Member Four Rings GlazierGlaze's Avatar
    Nov 10 2012
    La Grange, IL
    Will be interested in doing this once I get my car. My M4 had the Euro Anti-Dazzle coding on it and it was really wild to watch the car move the lights around at night with oncoming traffic and such.
    That said, $700 for coding is laughable. I think I paid someone $100 and they coded like 15 things on my M4. Audi tuners need to get their shit together.
    2022 Audi RS6 Avant - Glacier White on Cognac (Exec Pack, Black Optics, B&O Advanced Sound, Sport Exhaust, Side Assist)
    2021 Audi Q8 - Glacier White on Black - Premium Plus (Exec Pack, Black Optics, Convenience Pack, Towing Pack)
    Past: FBO 2015 BMW M4, 2010 Audi S5, 2019 X4 M40i
  38. #78
    Established Member Two Rings Alex M's Avatar
    Apr 19 2021
    Off-topic sorta, but does this mean A6 guys can somehow enable RS tail light animation without actually having the HD Matrix variant?
    2024 Florett Silver A8L D5.5 | Black Optics Plus + Executive Pkg
    ECS Tuning | 034Motorsport | BMC | Ghost | AudiSport
    2021 Ibis White A6 55 C8 | P+ Black Optics, Executive + Luxury Pkg
  39. #79
    Jan 25 2014
    NoVA
    Quote Originally Posted by US1787 View Post
    Second
  40. #80
    Dec 10 2011
    Cambridge
    Quote Originally Posted by Addicted View Post
    Second
    I'm on the Eastern Shore if you guys want to do a road trip. Think I was the 2nd or 3rd car in North America, Pacific German beat me by a day or two.
