2014 Q5 2.0L with 131K miles recently started to show intermittent Stability Control Failure followed by TPMS light. Stays on for a short period ( typically < 2 minutes) then goes off. Understand TPMS is part of the ESC. Multiple codes are set when scanned (I didn’t scan, shop did). Check engine light eventually comes on.
Independent shop did smoke test and found leaks in the upper timing chain gasket and losing pressure so was replaced. Had been telling me for a while this was going to need to be done at some point. Did not correct.
Tried replacing the MAF sensor along with retesting for leaks after replacing, checking for loose/broken wires and such with no success. Put old MAF sensor back and didn’t charge for that since didn’t resolve. Suggested taking it to dealer.
Dealer is saying replace the PVC valve first as that is the cause of the check engine light and might then be causing the ESC warning. Said it was "lean fuel". Would not do anything else until this was done (wanting nearly $1000 including the $220 “diagnostic” fee to tell me my brakes, tires and such were all good but my washer fluid level was low).
Independent shop is suspect if the PVC would address the issue as he didn’t see that as a concern, but will replace for much less than the dealer. Understand they can fail, especially in an older, higher mileage vehicle. Car seems to be running fine, not hesitant and such.
Looking for thoughts on if the PVC replacement would address the issue or other items to look for. Independent also suggested it could be a software issue, but dealer dismissed that due to the PVC issue they saw.
Replacing the PVC looks fairly straightforward, but I’m not typically one who would do this type of work myself although I have done brakes and such on other vehicles in the past.
Somewhat hesitant at this point to just start throwing parts at it which is what I’m starting to feel like is happening.
