Results 1 to 24 of 24
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    I'd recommend an upgraded Heat Exchanger well before any suspension mods.
    The 034 RSB + Moog End Links have done really well for me. I took it up to the mountains the other day, and the thing is tight! Admittedly I did the 034 insert kit at the same time.
    034 Springs are next. I want an H&R Sport level drop; but, going with 034 (0.5" less of a drop) because the ride quality is basically OEM with the benefit of additional handling.
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
    Nov 18 2014
    I'm putting in the 034 RSB but haven't opted for end links. My current links are in good condition. Thoughts?
    I also am having the CTS Turbo Heat Exchanger put in, as well.
    Jul 31 2016
    PA
    Quote Originally Posted by s42014DSG View Post
    Personally rear end links are kind of a waste for me, they are so short you just aren't going to get any significant change in stiffness. I tried the Moog ones too and couldn't get it to line up right. This was on a lowered SQ5 though so slightly different setup.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Nov 08 2020
    Atlanta, GA
    The End Link upgrades were a "while we're in there" type of job. I only paid $30 for them, so why not.
    I hear the stock end links are fine.
