Results 1 to 11 of 11
    Feb 26 2021
    How do you know you've been flagged by Audi for tuning?
    I just took my car into Audi for its first service. I flashed back to stock (tuned with Unitronic Stage 1+) before going to the dealership. They didn't say anything to me, nor can I see anything out of the ordinary on the service report. For what it's worth, there was no mention of the intake or suspension mods either.
    So I'm wondering for those who have had the unfortunate experience of being flagged by Audi for tuning while still under warranty, how did you know? Did they tell you at the time or did you find out later? I'm trying to figure out if I've gotten away with it or not...
    2025 AE RS6 Performance - Full PPF, Akrapovic exhaust, CETE Suspension module, matrix lights etc.
    2020 A4 Allroad - BBS CI-R Bronze 20x10 265/30R20, Unitronic Stage 1+ and Intake, ABT HAS & 034 rear swaybar with end links
    2010 A4 Avant TDI
    2008 A4 Avant TDI
    Senior Member Two Rings AccordingToAlex's Avatar
    Oct 04 2019
    SF Bay Area
    Quote Originally Posted by jashford View Post
    You're already SOL. As soon as you flash an aftermarket tune on your ECU, your car will forever be flagged TD1. Even if you flash back to stock. Drive carefully!
    EDIT: I should clarify that Audi will be able to detect that tune regardless if flashed back to stock and will flag your car. Sorry if I wasn't clear earlier.
    Sent from my GM1917 using Audizine Forum mobile app
    Feb 26 2021
    OK, thanks for the response.
    Although, what's the point of flashing back to stock when taking it to the dealer as most people suggest if the ECU is going to be forever flagged TD1?
    Just trying to understand the rationale of that recommendation, but I realize that it isn't you making it.
    2010 A4 Avant TDI
    2008 A4 Avant TDI
    Oct 04 2019
    SF Bay Area
    The idea is to not give them a reason to go fishing. If you're going in for warranty work, rule of thumb is to put everything back to stock as much as possible. Intake, rims, the whole works. If they see a "stock" car roll into the shop, it gives them less reason to scan your ECU for tunes. Remember even having an intake or exhaust can get you you a TD1 flag. Audi technically does not allow ANY modifications, or they may void warranty.
    Established Member Two Rings sbell008's Avatar
    Jan 27 2018
    Minnesota
    Quote Originally Posted by AccordingToAlex View Post
    To expound on this -- I've had my car tuned for a while now, and they never said anything to me during any of my warranty work, or services, and proceeded on as usual. The one time I did ask them to dive a bit deeper into a potential differential rumble issue, they then let me know that my car had been flagged as TD1, as they had to do some 'fishing' as Alex has mentioned. Basically, think of it as they 'didn't mind' it being tuned, but as soon as something potentially huge goes wrong, they'll likely let you know at that point that it's not being fixed on Audi's dime. I'm just living with the diff rumble though, as it doesnt seem to throw any codes, and is operating normally.
    Veteran Member Three Rings silver3.8's Avatar
    Nov 13 2019
    DMV
    I was tuned and my car went into service and i was not flagged. The moment a turbo issue happened, causing them to dig deeper, the scan for any changes and I was flagged TD1.
    As sbell said, the moment something potentially big pop up, then they dig and the info goes to mother Audi.
    C7.5 A6 2.0T P+ S - Line:
    Performance :RRR Stg 3 (93 & E30), Mamba GTX 3071R, APR Intercooler, 034 HPFP, APR Coils, HVF TCU, GFB VTA, BMS Pedal Tuner, Injen CAI, Visican gauge, JHM HFC & DP and Cende's Valvetronic Exhaust, Improved Racing's Catch can and 034 dog bone insert.
    Appearance: RS6 front bumper, RS6 Honeycomb grille, Maxton design trunk lip, 19" Niche Rainer
    Feb 26 2021
    Got it, thanks all for the explanations... I understand now.
    So it seems like I might as well go all out with mods if I've already been flagged and there's nothing that I can do about it!
    2010 A4 Avant TDI
    2008 A4 Avant TDI
    Dec 31 2018
    TX
    Just ask your service advisor (SA), seriously. SAs around my part of town are very transparent about it, even hinting that if you are any way tuned to please let them know and their assigned technician will be mindful to not call back to home when it's plugged into the computer.
    So, if you went in for a simple oil change or had basic warranty work that didn't involve days of diagnostic, you should be OK. Build a relationship with your SA and they can tell you if you've been flagged or turn a blind eye to things and give you a heads up.
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Maybe if you're wearing one of these?
    Found it here: Manufactory27
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Mar 13 2018
    Shoot upon knowing this, I know that I would.
    Jul 17 2016
    El Paso, TX
    Thought I might chime in real quick. Just remember that even though a tune may have a few tricks and be “undetectable” after flashing back to stock, when they pull the data logs, it will show alterations in boost and timing that are out of factory specs. That is an instant flag. Now, one thing to note is that even though a vehicle is flagged, it doesn’t mean there’s an automatic no for fixing an issue on the power train. The dealer must still prove that the tune is what directly caused the failure to begin with. The onus is on them. And if they refuse, then get a written statement of them denying the warranty claim and take it up the ladder.
    Now, if that means they are forced to tear your motor apart to diagnose down to the nitty gritty detail of how a failure occurred, and they figure out it was indeed the tune, you are stuck with the bill.
    Bottom line. Pay to play. I don’t fuck around with the service advisors. I actually have a tag on my DME cover that says “do not flash to stock” and in the SA notes it says the same thing and advises the tech to speak with me before performing any reflashing of the vehicle. Costs me $450 and two days down to pull it and ship it out for bench flashing each time. So if it’s something minor, I have them hold off. If they have to diagnose an engine issue, they’re free to flash back to stock so they can work on it and I take a monetary hit. Whatever. Pay to play, right? In my experience, transparency is best. Trying to hide something they WILL find regardless is like smoking crack in front of a cop and when he calls you out you’re like, loh this? Oh man, how’d that get there?! That ain’t mine!” Yeah. Don’t be the crack baby. No one like that and they’re less likely to make your life easy if you try to hide shit.
    Good luck!
