Results 1 to 19 of 19
    Junior Member One Ring
    Dec 30 2018
    WA
    A4 Control arm replacement
    The upper control arms on my 2004 Audi Avant with about 150K are beginning to go. I hear a groaning sound when turning at slow speeds. I am looking for advice on whether to just replace the 4 upper control arms and the sway bar ends with OEM parts as these are showing signs of wear currently. Or should I perhaps replace the upper + lower control arms and sway bar ends with a Meyle kit.
    Is it better to go OEM or are the Meyle parts equally good? If I just replace the upper, are the lower likely to start failing soon given the age/mileage? The Meyle arms are apparently all metal unlike the OEM and so I am not sure if the car will feel any different with them and also if the Meyle ones are as reliable as the OEM ones which have lasted all this time.
    The cost to replace just the upper with OEM is about 20% less than doing all of them with the Meyle kit. Would appreciate any advise/recommendations on which way to go.
    Thanks.
    Senior Member Four Rings Deerhurst's Avatar
    Jul 22 2019
    1986.5 SE-V6 4x4 Nissan D21
    Oregon
    I'd just do the entire thing. Why only do half the job? I assume the rest of your suspension has the same miles on it.
    I use a Delphi kit from rock auto. Under $200 for all 8 arms, tie rod ends and sway bar links. No more noises, clunks, rattles or groans.
    2003 A4 Avant 3.0 6MT Quattro
    2003 A4 Avant 3.0 6MT Tuned, TTV SMF, RS4 Clutch, Joey Mod, Clear Corners, Mini H1 7.0, Xtrons, Skar Audio, Panda Subs
    1986.5 SE-V6 4x4 D21 Cammed, Long Tubes, VG33 swapped
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Agree with Deerhurst; do the entire set of arms/links. And while you are that far into it, check the wheel bearings for noise when you spin the hubs. They won't get any more accessible than this. I changed all four a couple of years ago, and the resulting quietness is surprising. Naturally, check the CV boots and disk condition. I used a Valeo kit, about six years later I have some dust boot failure, and the sway bar links were defective, otherwise OK. Uro sells a B6 kit for $250 I see.
    Active Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Those pinch bolts never want to come free. They are always seized in the knuckle make sure you have a spare on hand if needed.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles, Odometer matching, SKC/Pin retrieval services/ Component Protection/Module Coding/Diagnosis Services and repairs.RB4/RB8 Specialist cloning and repairs. Located in Northern NJ. For inquries pm for details or contact me via Whatsapp
    Ziddy Autowerks
    Jul 22 2019
    Oregon
    Quote Originally Posted by EuroxS4 View Post
    I've never had this issue. Mine fall out as soon as the pinch bolts come loose. 167k miles on the car. It sees rain, slush, snow, mud. Not sure why some stick and others don't.
    Veteran Member Four Rings Kevin C's Avatar
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    OP is in WA state, most likely he wont have a problem with the pinch bolts since it probably has not seen road salt. Meyle kit should be solid, I went with Lemforder ( second time around). The Febi kit I bought got noisy / creaky on really hot days.
    2003 02X Six speed swapped, RS4 RSB, H&R FSB, B7 brakes, 2.0T stroker, DSMIC's, B7 CTS K04 turbo.
    Dec 30 2018
    WA
    Sounds good. I'll go ahead and replace them all. Thanks everyone.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I'd recommend the Density Line 034 kit. Stronger bushings and better response. If you're lowered, their upper adjustable arms are also a good option to prevent inner tire wear due to negative camber:
    https://store.034motorsport.com/cont...a4-s4-rs4.html
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Veteran Member Three Rings fabric8's Avatar
    May 14 2013
    US
    I replaced all front control arms and end links on my A4 with Delphi parts from FCP Euro and they're working well.
    My dad decided to give a set from an eBay seller a try. The arrived yesterday and they look identical in quality to the Delphi. I'm planning to install them on his car this weekend. For $128, it was worth trying.
    HIS - 2016 Golf R 6MT
    HERS - 2002 B6 A4 1.8TQM Avant | Motoza Stg.1.5 | OEM A6 4.2 17" forged fat fives
    Nov 03 2010
    Fallbrook, CA
    That picture looks familiar. Years ago I ordered a set from "CXRacing", which arrived in a no-name box without instructions. But the parts looked as nice as OE, everything fit, the new bolts were thoroughly Zinc plated. I installed that set on our B5 Passat, later another on my B5 A4, and never had a problem. I'm only half-kidding when I say that all of these sets are made in one big factory, and just go into different vendor cartons, including Audi Factory Parts.
    Jan 24 2010
    Paramus,NJ USA
    The only issue ive run into with the cheaper kit is that the taper on the lower control arm ball joints did not match the factory arms. Just make sure it all matches.
    Ziddy Autowerks
    May 14 2013
    US
    Thanks for calling this out. I'll pay close attention to this.
    Mar 28 2015
    Quote Originally Posted by fabric8 View Post
    It happens if you get early arms designed for the cast iron uprights used in the previous generation platform. Also, if you look closely at the kits you will notice that the parting lines and shapes vary a lot brand to brand. That tells me that they are not all coming from the same factory.
    Nov 03 2010
    Fallbrook, CA
    One thing to watch out for is the size of the 18mm hex nuts, which secure the lower arm ball joints. Be sure that they are made with a large flange at the base, or have a suitably large washer. The Aluminum uprights have a steel insert where the ball joint stud attaches; that slipped on my car due to the supplied nut not covering the steel insert.
    Jan 24 2010
    Paramus,NJ USA
    Correct B5 a4 and late b5 s4's had cast iron uprights but early b5 s4 1999-2000 had alloy uprights similar if not the same as the b6 a4 ones. I think this would only apply if they sent you a b5 kit instead of a b6. They are very similar with minor differences one being the taper of the ball joint.
    Ziddy Autowerks
    Senior Member Three Rings jj94tt's Avatar
    Feb 24 2011
    Pittsburgh
    The lower strut bushing on the front lower control arm is usually the first to go... I bet yours are shot. +1 on a doing all 8. Also, +1 for Lemforder (you can see where the 4 rings were ground off the castings so they could be private labeled).
    2005 A4 B6 3.0L 6MT USP Ocean Blue
    USP CLUB MEMBER #230
    Feb 10 2011
    MI
    If you are keeping the car for a while, FCP Euro kits are lifetime. I'm getting ready to do my car a second time at 300k, its nice the parts are already paid for.
    2004 Audi A4 Quattro 3.0 6sp Ultrasport
    2002 Audi A4 Quattro sport "development" car
    2005 Passat TDI Wagon 6 m/t
    1996 Audi A4 Quattro 2.8 (daughter)
    And all the Ford trucks you could want
    Established Member Two Rings yanni6556's Avatar
    Jul 03 2016
    Sydney Australia
    I got the a kit from Rock auto can't remember the name but they were pretty cheap. They are a pain to do though if the sleeve doesn't want to stay down. Be prepared for some headaches
    May 14 2013
    US
    I finally got around to installing the set my dad got from ebay on his car yesterday. All the bushings and ball joints looked to be of equal quality to the Delphi ones I got from FCP euro. Of course, time will tell.
    But considering he drives his A4 less than 5k per year, and the car never sees snow or harsh conditions, I expect the bushings to last quite a while. 4 upper control arms, 4 lower control arms, 2 sway bar end links, 2 outer tie rod ends and all new hardware (nuts and bolts) for $128 is a steal. YMMV.
    Oh by the way, I followed advice and re-used the original lower ball joint nuts with built in washers.
