Results 1 to 7 of 7
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Flushing Brakes - Best Brake Fluid For Street Use?
    Hey Guys,
    Per the subject, I am looking for some recommendations on quality brake fluid to use for my upcoming brake flush. If I recall correctly, the last time I did a flush I ended up using Motul RBF600. However, I am open if there is new recommended fluid by most people.
    Usage:
    My car is a daily driver / street-car. No track or super crazy driving usually.
    Any recommendations for a quality brake fluid to use? TIA.
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    I'd just buy a quart of Valvoline or other name-brand DOT4, and call it a day.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by Turbo510 View Post
    Yea, Pep Boys sells a good German DOT 4 by the liter. Buy two just in case. But honestly, any DOT 4 from a fresh sealed container is what you want.
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Senior Member Four Rings Deerhurst's Avatar
    Jul 22 2019
    1986.5 SE-V6 4x4 Nissan D21
    Oregon
    This. For the most part DOT fluid is DOT fluid. You only pay more for the name as they all have to meet the same requirements. "street" isn't exactly taxing on a vehicle. You have bigger problems if you manage to get brake fade during your drive to work or the store.
    Use fresh stuff from a reputable company. Brake fluid is hydroscopic and will draw in moisture from the air around it. Water boils lower than brake fluid and that's not good when you need brakes.
    2003 A4 Avant 3.0 6MT Quattro
    2003 A4 Avant 3.0 6MT Tuned, TTV SMF, RS4 Clutch, Joey Mod, Clear Corners, Mini H1 7.0, Xtrons, Skar Audio, Panda Subs
    1986.5 SE-V6 4x4 D21 Cammed, Long Tubes, VG33 swapped
    May 23 2019
    Charleston SC
    Bosch is pretty good $15/qt.
    Bosch ESI6-32N Brake Fluid (Direct Replacement for DOT 3, DOT 4, and DOT 5.1) https://www.amazon.com/dp/B07338GQM8...ing=UTF8&psc=1
    Active Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    DOT5.1 for the win!
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles, Odometer matching, SKC/Pin retrieval services/ Component Protection/Module Coding/Diagnosis Services and repairs.RB4/RB8 Specialist cloning and repairs. Located in Northern NJ. For inquries pm for details or contact me via Whatsapp
    Ziddy Autowerks
    Mar 05 2013
    CA
    uh
    Pentosin DOT4
    wasting money on RBF600 on a street car = Mental Tarded
    I bet a new RS6 comes with DOT4.
    But you're always gonna have that one guy "Muh 20 year old $3k base model. Power doesn't activate until 3600 RPM. My engine is smaller than a soda bottle. The car is heavy and understeers. I Need Track Parts."
