Results 1 to 7 of 7
    May 10 2021
    Southport
    Remap not working? Limp mode?
    Hi guys, I recently bought an Audi A4 B7 2.0T FSI FWD and decided to get it remapped, when I took it on a test drive it went into limp mode and would go over 3/4K and struggle to gain speed, it was like the turbo wasn’t working. I checked the error codes and I got this:
    16618/P0234/000564
    Which suggests a faulty N75 or G31, does this sound like this could be causing the issue or could it be something deeper like the ECU? Thanks
    May 10 2021
    Southport
    Anyone got any ideas?
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Who is the tune from?? But yes, overboost is normally bad n75(boost control solenoid). Can check it by checking resistance between the pins. 25ohms,iirc, is what ya want. Or very close. Also check none of the vac lines for it are damaged. Also could be a bad map sensor, but not as common. Have you done any boost logs to see exactly whats going on?
    Sent from my LM-G710VM using Audizine Forum mobile app
    May 10 2021
    Southport
    Hi,
    The N75 valve was just tested and was apparently fully functional, the boost sensor was changed, no boost leaks and it doesn’t boost without the map until 3.5k revs is that normal?? With the map there is no boost whatsoever, the map apparently is a dyno tested plug and play one from online so it COULD be the issue but what else can I test?
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by Bultano View Post
    Hi,
    I don't know how it would act without a map sensor. What map sensor you install? Aftermarket?? Ya didn't mention who tuned it..are you able to flash back to stick, to see if the issue is hardware related, or software related? Do you have a boost gauge, to see if your getting low boost, or no boost? And do ya have something to log with? Vcds, Obdeleven pro, etc.
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Hi,
    Quote Originally Posted by Jayz691 View Post
    Agreed, we need more information here. P0234 is NOT a good code to have... But if I may chime in here, the tune most likely isn't the problem. (Also FWIW, technically all "Dyno tested plug and play" tunes are pretty much EVERY tune out there available for this platform).
    Check that N75, and if you replace it don't get a cheap knockoff one. Also as @Jayz691 said above, check the line going from the high pressure port from the turbo to the N75, make sure the tube isn't cracked/split/leaking.
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Jan 21 2018
    frackville, pa US
    Ahh, read that wrong. You said the tune is a "plug and play" tune, guessing one of those $200 tunes off ebay?? I mean it "shouldnt" be the issue, but wouldn't rule it out. I wouldn't trust one of them personally. Just check all your hardware first. And def get yourself vcds, Obdeleven pro, etc. Gonna wanna do some logging at one point. Even if you fix this issue. Id wanna know how the tune is functioning..
