Results 1 to 15 of 15
    Senior Member Two Rings BradyBoi55's Avatar
    Apr 19 2020
    1994 Ford F-150, 1931 Ford Model A, 2007 BMW 650i
    Manchester/NH
    Full manual brakes after vacuum pump gasket replacement.
    I recently just replaced my vacuum pump gasket and no longer have boosted brakes. There are no leaks around the pump. I’m wondering if I have a vacuum hose hooked up incorrectly. I removed the pump completely off to clean it so that is why I had the lines off. Thanks!
    Feb 15 2016
    Cambridge,Ontario
    Well the main purpose of that pump is to provide vacuum for your brakes so I would recheck your work.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 19 2020
    Manchester/NH
    I did recheck it and I didn’t notice any problems. After driving it home I am currently throwing a code for running lean. I checked the vacuum line from the brake booster and it is on correctly but has not vacuum whatsoever. I pulled the line off while at idle and there was no vacuum.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by BradyBoi55 View Post
    Then recheck your work.
    2019 Audi A4 Quattro Premium Plus | Manhattan Gray | APR Stage 1 | ECS Intercooler Kit
    *goodbye sweet prince* 2009 Audi A4 Quattro Premium | Ibis White | CTS K04 Hybrid | 034 Motorsports HFC | REV9 Intercooler | Ward Performance Tuning
    Visit us on FB @ Audi B9-B9.5 A4 Owners Official Group
    Apr 19 2020
    Manchester/NH
    The line the continues past the big line from the brake booster that connects to the passenger side of the vacuum pump moves to a 3 way split. To make sure I have it right where does the lines continue? I have one hooked up to the small plastic connecter on the back of the cylinder head near the coolant flange and the other one is plugged into the purge valve by the intake manifold(I believe)
    Feb 15 2016
    Cambridge,Ontario
    See if you are generating from the pump first. Should be crating vac even at idle.
    1976 Yamaha XS 360
    Apr 19 2020
    Manchester/NH
    Will I be able to feel the vacuum at idle? Also where should I test the vacuum on the pump to make sure it is functioning properly.
    Feb 15 2016
    Cambridge,Ontario
    The nipple that comes right out of it .
    1976 Yamaha XS 360
    Apr 19 2020
    Manchester/NH
    What is the operation of the vacuum pump? Is it always running or just running while the car is in boost? Also how does is it correlate with the HPFP? I know the hpfp is spring loaded and driven off of the cam and the vacuum pump spins from the camshaft.
    Apr 19 2020
    Manchester/NH
    So now I’m leaning towards the vacuum pump is bad. There in no vacuum at idle coming from the nipple. Could a bad pump cause the car to run lean at idle?
    Nov 20 2016
    Yes because you are sucking in fresh air into the crankcase through the vacuum pump seals now.
    Jul 16 2018
    Atlanta
    Pierburg video, you have to crank the volume - https://youtu.be/mp3NeWuEDk8
    Actual unit - https://youtu.be/fWATwtqCEXw
    But neither of those actually explain anything. This video was the actually informative one - https://youtu.be/toursbNKM90
    Interesting that it talks about the pump mixes the air and oil and then dumps the oil to the oil separator. I always assumed the oil port to the vacuum pump was just for lubrication of the vane and HPFP tappet. But that would explain the single air port and single oil passage; they combine and are dumped back out the center to the head on to the oil separator? That probably works, because once evacuated, how much air will really be pulled out of the system? (well, unless you have OP's situation of a possible air leak)
    Apr 19 2020
    Manchester/NH
    I was able to do some tests today. I think the gasket might not be sealing 100%. I felt ksome vacuum around the gasket and I put my finger over part of the gasket and my other finger over the black nipple on the passenger side of the vacuum pump and felt a very slight vacuum.
    Feb 15 2016
    Cambridge,Ontario
    That's exactly what it is.. the wiper has to make a perfect seal.. and all has to be perfect . Take it all off and do it over.
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    The pump is very simple.
    1976 Yamaha XS 360
