That's how the wideband sensor works. The pump current is the measured value. It can be translated to a voltage, as it's a "simple" circuit.
www.youtube.com/watch?v=Dwij_fuceUo
As I already mentioned, this is already pointed out by Bosch themselves.
https://www.bosch-motorsport.com/con...or_LSU_4.9.pdf
Page 2 shows a chart; read the foot note. Our voltage seems to follow the v=8 scaling. The formula for voltage value from IDE00558 is simply 1.5v + 8*61.9*(current value from IDE00559/1000). But that voltage is a computation based on the actual sensor measurement, pump current. The 1.5v base voltage seems to reflect that our ECU must use a CJ125 controller rather than a AWS controller. See Bosch tech doc Y 258 E00 015e. Bosch doc 0 258 017 025 can also be useful, but note that the Block Diagram pin numbers are actually for LSU 4.2, not LSU 4.9.
http://circuitszoo.altervista.org/Bosch_LSU_WB02.html
That might be useful in understanding the circuit layout.
Keep in mind that while LSU4.2 and LSU 4.9 sensors use the same 6 wire connection, the wires are in reverse order between the two. Ip, pump current, red wire, is pin 6 on LSU 4.2 and pin 1 on LSU 4.9. We use an LSU 4.9 sensor.
https://www.scannerdanner.com/media/...sistorchip.jpg
It's kind of interesting. It basically uses a voltage output old style O2 cell to produce a control voltage, the Nernst voltage, which is compared to the 450mV standard, to determine if the content is lean or rich. Then the control drives the necessary current in the pump cell to restore balance to the Nernst cell, 450mV, and the amount of current used reflects the lambda. Or something to that effect.
A proper cat with sufficient OSC is very expensive to build. If you have to care about emissions, you pretty much can't bother with anything but auto manufacturer OE. They are the only ones going to bother with the cost, since the EPA gives them no choice.
The 2013 A4 quick ref spec book says CAEB P0420 = Measured OSC / OSC of borderline catalyst value for main catalyst , <0.90. The 2009 makes reference to <1.00 and <0.90. The EPA docs are all "confidential info", but later EPA docs say <1.00. Probably more of that VAG emissions gray area. For example, there is a TSB for the original Q7 with 3.6 FSI engine for P0420/P0430 (same thing but bank 2). An ECM flash is necessary. Maybe an errant computation, errant lookup table data, or they were just knocking the result bar down a tenth or two.
