Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
    Sep 17 2005
    Fremont, California
    034Motorsport B9 A4 Parts, Tuning, and Upcoming Product Thread!
    034Motorsport Tuning and Hardware Information + New Product Info
    In this post, we will talk about the products that 034Motorsport offers for the B9 A4/A5 platform to enhance the performance of the 2.0T engine, and the chassis as a whole. We are here to offer an extensive product catalog of Substantive, quality parts that provide measurable improvements to your enjoyment of your car, so that you can kick ass at a drag strip, track day, or autocross event, and drive the car to work the next day with comfort and confidence. Below will be some links to the products we offer, as well as upcoming products you can expect to see in the future. If anyone has questions about products, feel free to use the comments as a place to discuss.
    PRODUCT LINKS
    TUNING
    034Motorsport Dynamic+ ECU + TCU Bundle for Stage 1: CLICK HERE
    034Motorsport Dynamic+ ECU Tuning for Stage 2: CLICK HERE
    034Motorsport Dynamic+ ECU Tuning for Hybrid Turbo *Coming Soon!*
    034Motorsport Dynamic+ TCU Tuning: CLICK HERE
    POWERTRAIN
    034Motorsport X34 Carbon Fiber Intake: CLICK HERE
    034Motorsport P34 Cold Air Intake: CLICK HERE
    034Motorsport P34 Cold Air Intake (ROW): CLICK HERE
    034Motorsport X34 Carbon Fiber Intake Air Duct: CLICK HERE
    034Motorsport Silicone Turbo Inlet Hose: CLICK HERE
    034Motorsport X34 Carbon Fiber Air Scoop: CLICK HERE
    034Motorsport Stainless Steel Racing Catalyst: CLICK HERE
    034Motorsport Carbon Fiber Radiator Support Cover: CLICK HERE
    034Motorsport Turbo Muffler Delete: CLICK HERE
    034Motorsport Billet Aluminum Rear Main Seal: CLICK HERE
    034Motorsport Street Density Motor Mounts: CLICK HERE
    SUSPENSION
    034Motorsport Dynamic+ Handling Packages: CLICK HERE
    034Motorsport Dynamic+ Lowering Springs (For Sport & Non-Sport Suspensions): CLICK HERE
    034Motorsport Dynamic+ Sway Bar Kit (Front & Rear): CLICK HERE
    034Motorsport Dynamic+ Adjustable Rear Sway Bar: CLICK HERE
    034Motorsport Motorsport Front Sway Bar End Links: CLICK HERE
    034Motorsport Dynamic+ Billet Adjustable Rear Sway Bar End Links: CLICK HERE
    034Motorsport Motorsport Rear Sway Bar End Links: CLICK HERE
    034Motorsport Density Line Adjustable Rear Toe Link: CLICK HERE
    034Motorsport Density Line Lower Control Arms: CLICK HERE
    WHEELS
    034Motorsport ZTF-01 Forged Wheels in 19x9.3 ET35: CLICK HERE
    CHASSIS
    034Motorsport Billet Aluminum Front Strut Brace: CLICK HERE
    034Motorsport Billet Aluminum Transmission Mount Insert: CLICK HERE
    034Motorsport Billet Alumunum Rear Subframe Mount Insert Kit: CLICK HERE
    034Motorsport Billet Aluminum Rear Differential Mount Insert Kit: CLICK HERE
    034Motorsport Street Density Transmission Mount Upgrade: CLICK HERE
    034Motorsport Stainless Steel Tow Hook: CLICK HERE
    EXHAUST
    034Motorsport Res-X Resonator Delete & X-Pipe: CLICK HERE
    034Motorsport X-Clear Driveshaft Tunnel Brace: CLICK HERE
    UPCOMING PRODUCTS/TUNING OPTIONS
    We will use the comment section to share photos of upcoming products as they go through development, and add the links to the main post once they become available.
    Oct 11 2016
    Massachusets
    I can't wait for the ECU / TCU tune. I'll be installing that the day you guys release it.
    Junior Member Two Rings
    Mar 11 2021
    Cincinnati
    Can you guys provide a little more clarity on what the Turbo Muffler delete is?
    Is it a blow-off valve?
    Is it non-recirculating?
    Just trying to understand here...
    Sent from my Pixel 2 using Tapatalk
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by wraedeohed View Post
    The OEM piece is designed to reduce the level of sound generated by the turbocharger. The 034Motorsport Turbo Muffler Delete replaces the internal baffles of the OEM part with a sealed, smooth-walled, machined billet design, allowing the driving enthusiast to hear more of those wonderful turbo sounds.
    -Sean@034
    Senior Member Two Rings Vinhouw's Avatar
    Jan 14 2014
    my two feet
    Tampa, FL
    what is a good wheel spec combination with the lowering springs that you guys offer? How is the ride quality in comparison of the stock non sport suspension on a 2020 A4 premium?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Vinhouw View Post
    We recommend our 19x9.3 ET35 Forged ZTF wheels while running our lowering springs. Our 034Motorsport Springs are the perfect choice for hitting the three points of a good daily drivable suspension: Comfort, Performance, & Stance. These springs were developed to be perfectly matched with stock A4 struts and were developed through thousands of miles of road and track use to ensure that they are perfect for our customers.
    These springs are not harsh by any means and many customers will state they ride like stock.
    -Sean@034
    Jan 14 2014
    my two feet
    Tampa, FL
    Sounds good! how about the drop? is the gap in front lower than the rear, equal, less?
    thank you for your input, will most likely order soon! =D
    Sep 17 2005
    Fremont, California
    The drop is equal from front and rear.
    B9 Audi A4 Base Suspension
    Front - Approximately 2.0" Lower
    Rear - Approximately 2.0" Lower
    B9 Audi A4 Sport Suspension
    Front - Approximately 1.1" Lower
    Rear - Approximately 1.1" Lower
    -Sean@034
    Senior Member Two Rings misanorotrs4's Avatar
    Jul 10 2015
    2018%20Audi%20SQ5%2C%201997%20Audi%20A4%201.8t%20Quattro
    Glendale, CA
    These springs are a wonder, I was lucky to get a ride in their TTRS and had the chance to drive both their A4 and S4 with the Dynamic+ Springs. They’re as close as you’ll get to a solid set of coilovers without the price tag and are very responsive to input and demonstrate great control.
    IG: @ahmautos
    Jan 14 2014
    my two feet
    Tampa, FL
    Thank you for the feedback! i appreciate it! I will order then soon, that wheel gap that i have currently is killing me!
    Sep 17 2005
    Fremont, California
    This past Friday we traveled down to Willow Springs in Southern California for a track day to further the tuning development on our B9 3.0T platform as well as B9 2.0T tuning with assistance from one of our sponsored customers, Moss Auto Sports in his 6MT B9 A4 running our Beta Dynamic+ Stage 2 file.
    Check out some of the cool shots we got while we were there!
    Aug 27 2013
    Philly
    Looking to snag a resonator delete, but I dont want to order another part thats on backorder. Any idea when these might be back in stock/start shipping? (Ive been waiting for 3 months for suspension parts that are back orders for my truck and just don't want to keep on waiting)
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by SJorge3442 View Post
    Based on the information available to us currently, 5/7 is the estimated date of which we will have these back in stock and ready to ship. Email us at [email protected] for any future updates!
    -Sean@034
    Senior Member Two Rings AudiSportDre's Avatar
    Mar 14 2020
    B5 1.8T track car (soon to come)
    Worcester, MA
    I've been holding out on a tune for my A4 because I'm curious to see what you guys have in store. So I'm losing my mind in anticipation! It certainly helps that you will also have future hybrid turbo support. It doesn't seem that many tuners have that in the works. I have even emailed some other tuners and my email's have been ignored. Eventually stage 2 gets boring and a hybrid turbo will need to come into play. You can thank Moss Auto Sports youtube and instagram for making me hold out so long lol. Unlike most Audi owners hes not afraid to thrash his car out on track like I would. I love that 034 products are actually put to the test.
    2018 B9 Audi A4 P+ S-Line Quattro Mythos Black
    Stance is dumb performance is fun.
    Oct 30 2018
    Will your 034Motorsport Dynamic+ TCU Tuning be compatible for the B9 Q5 2.0 as well?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Audi Sport B5 View Post
    Thanks for the support! He definitely drives his car harder than most! Rumor has it he is testing our Density Line Motor Mounts :)
    Quote Originally Posted by Rising_sun View Post
    That is the plan!
    -Sean@034
    Established Member Two Rings stevenpelle20's Avatar
    Nov 26 2017
    New York
    do you guys have an estimated time that the tunes will be released?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by stevenpelle20 View Post
    Planning for a Summer release!
    -Sean@034
    Apr 15 2021
    Quote Originally Posted by 034Motorsport View Post
    -Sean@034
    Are these tunes only for Quattro version B9 A4's?
    Sent from my SM-G998U1 using Audizine Forum mobile app
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by jmoline228 View Post
    We will have to do Box Code scans of the Ultra versions to see if our tuning will be compatible.
    -Sean@034
    Apr 15 2021
    -Sean@034
    Gotcha. Well I hope it will be compatible with the 190HP Ultra version of the B9. A tune for this model is hard to find, and reviews of them even harder lol. And I've only heard good thing about 034 so would definitely be looking forward to it. Also, are the Dynamic+ springs available with the Ultra version?
    Sep 17 2005
    Fremont, California
    Dynamic+ Springs are able to fit the Ultra Version of the A4.
    Jul 10 2015
    Glendale, CA
    The B9 2.0T continues to receive the abuse she doesn’t deserve. All the data logging and fine tuning on this file is worth the wait for release. Nothing rushed to market is ever good, and this BBQ is being perfectly smoked for your enjoyment lol.
    Enjoy this video from out track day with a slightly different perspective.
    https://youtu.be/m1sNchcIbN0
    IG: @ahmautos
    Jul 02 2020
    South OC, CA
    Any updates on the tune, specifically TCU tune? I'm already tuned with a JB4 (E30), but do guys have any plans on supporting E85 blend with your ECU tune?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by clixt View Post
    The TCU Tune is still in development, as is the ECU tune. We will be evaluating ethanol (blended) maps.
    All final octanes & features of both our ECU & TCU Tunes will be available upon release.
    -Sean@034
    Mar 11 2021
    Cincinnati
    Any cases of your Dynamic springs having any reverse rake, or sagging?
    Sep 17 2005
    Fremont, California
    We have not had any cases of reverse rake or sagging on any of our Dynamic+ Lowering Springs. These typically will have a slight positive rake.
    -Sean@034
    Apr 22 2021
    san diego/ ca
    -Sean@034
    summer is right around the corner!
    ECU/TCU tunes coming early, mid or late summer?
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by jbap29 View Post
    Mid to late summer release.
    -Sean@034
    Sep 17 2005
    Fremont, California
    For all of our B9 folks eagerly awaiting tuning or have an interest in tuning their car, please fill out our Dynamic+ interest form! We'll use this form to reach out when files are available, as well as to gauge interest in some files we're thinking of providing!
    Please only respond if you own a B9 Audi, Thank you!
    https://forms.gle/Njid58s8xudFxQuVA
    -Nick@034
    Jul 02 2020
    South OC, CA
    -Nick@034
    Done! My warranty will expire in 1,500 miles so looking I'm forward to the TCU tune.
    Mar 14 2020
    Worcester, MA
    -Nick@034
    Done. I’m so pumped for this. The anticipation is killing me lol
    Sep 17 2005
    Fremont, California
    Available Now: Billet Aluminum Rear Main Seal, 2.0T TSI
    034Motorsport’s Billet Aluminum Rear Main Seal is designed to replace the failure-prone stamped steel factory Rear Main Seal on your 2.0T Audi. This Billet Rear Main Seal is CNC machined from 6061-T6 Aluminum and features an OEM Viton Elring seal with an integral tension spring to ensure a tight seal to the crankshaft.
    The OEM rear main seal utilizes a poorly designed PTFE “sealing lip” which over time leads to an oil leak between your engine and transmission. The failure of a rear main seal can also cause crankcase pressure issues and possibly even misfires.
    The 034Motorsport Billet Aluminum Rear Main Seal has been tested and proven to last under high heat and intense abuse and is an excellent upgrade for replacing your leaking rear main seal. It is also an outstanding preventative maintenance modification that can save you from future headaches of oil leaks, stained driveways, and reduced performance that a leaky OEM rear main seal brings with it.
    FEATURES:
    • CNC Machined from Billet 6061-T6 Aluminum
    • Gloss Black Anodizing
    • OEM Elring FPM flurorelastomer Viton Seal With Integral Tension Spring
    • New Hardware (Grade 8.8)
    • Direct replacement to OEM Part Numbers 06K-103-171G
    Check it out HERE
    Sep 17 2005
    Fremont, California
    The factory Audi strut brace is made of thin stamped aluminum, allowing for lateral deflection of the strut towers and chassis flex under hard cornering. This deflection can be observed as imprecise steering input and a vague, disconnected feeling from the front end.
    The 034Motorsport Strut Brace replaces the flimsy individual factory braces to improve the B9 A4's steering feel and handling performance. This robust chassis reinforcement is machined from T6-6061 billet aluminum, and engineered to be a comprehensive upgrade by limiting lateral strut tower deflection and maintaining proper suspension geometry under heavy cornering. The incorporated center brace ties together both left and right strut tower to provide precise, consistent feedback from the front end and ensures that you enjoy a more connected driving experience.
    Features:
    • Engineered to Enhance Handling Dynamics and Performance
    • Improves Steering Feel, Consistency, and Precision
    • Bolt-On Upgrade for Factory Front Strut Braces - Easy, Straightforward Installation!
    • T6-6061 Billet Aluminum Construction with Clear Anodized Finish
    Fitment:
    • 2017 - Present Audi A4 (B9)
    • 2018 - Present Audi S4 (B9)
    • 2018 - Present Audi A5 (B9)
    • 2018 - Present Audi S5 (B9)
    • 2018 - Present Audi RS5 (B9)
    • 2017 - Present Audi Allroad (B9)
    Sep 17 2005
    Fremont, California
    Just a reminder, for all of our B9 folks eagerly awaiting tuning or have an interest in tuning their car, please fill out our Dynamic+ interest form! We'll use this form to reach out when files are available, as well as to gauge interest in some files we're thinking of providing!
    -Sean@034
    Jul 10 2015
    Glendale, CA
    Filled thanks for this!
    IG: @ahmautos
    Sep 17 2005
    Fremont, California
    👀👀👀 A new product coming soon which will look great on the A4!
    -Sean@034
    Jan 21 2021
    Queens, NY
    Assuming this will work in an A5 Sportback?
    Nov 26 2017
    New York
    With the Stage 2 and TCU tunes, come out at the same time as the Stage 1 tune, or at a later date apart from the Stage 1?
    Sep 17 2005
    Fremont, California
    Release dates for Stage 1, 2, and TCU are still being finalized, so I cannot provide info on that today.
    -Nick@034
