Results 1 to 6 of 6
    Mar 31 2013
    Trunk Lid Liner Removal
    Hello,
    I have a B8.5 S4. My trunk won't open, the motor just makes noise and doesn't open. I tried to remove the lid liner to see what parts are there that may be problematic, so will just order a latch as that seems to be the only part available.
    That said, I can't remove the liner. There's the emergency lever that I can't seem to remove and something is stuck behind there. I can feel behind it, there's some curved piece of plastic, which I assume is the housing for the cable. It doesn't look like the emergency release plat comes off at all. There's just soft felt when I try to pry it, so I'm reluctant to try and force it.
    Has anyone removed this, what needs to be done? I can remove everything else, it's just stuck on this one area.
    TIA!
    Mar 05 2016
    Avoid buying the aftermarket door latch from ebay or Amazon. Just get the OE from dealer. I learned my lesson, changed it like 3-4 times.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Mar 05 2016
    Also need to unclip the cable holder.
    Mar 31 2013
    Thanks! I didn't even see the screw there! I assume the unclip cable holder parts are with the liner dangling down to be able to see behind it? I don't think I can do that without line of sight.
    I ordered the OEM from ECS Tuning, from a google search.
    Mar 05 2016
    Quote Originally Posted by 91z28-350 View Post
    The most difficult part is to unclip the cable in the back of the panel. And clip it back is another challenge. In my case, after 3, 4 installed I can do with my eyes closed😅
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Audi403 had a great writeup several years ago with test and pics -- unfortunately, the pic hosting site deleted everything although his text associated with the pics may be helpful. I don't think he is active here on Audizine anymore either. Anyway, here's the link to his post: https://www.audizine.com/forum/showt...1#post12774582
    Just found this short YT video on removing the trunk lid liner. Hopefully it will be helpful!
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
