True story.... The shaft on the input of the rack has a flat on it so you do not have to index the steering wheel to it. As long as the rack is kind of close to centered and the wheel is straight ahead, your good. I'm going out on a limb here.... You should be able to tell if your off a full turn.
Good to know! I thought it was splined. But if it has a flat as you say, then you're right and centering it *should* be obvious.
