Originally Posted by
ywang98
Oh man, it's worse than I thought!
Remember I said that the ECS offering was just an universal one, not application specific? It appears that it is worse then that...
At first I thought that the filter had just been squashed, somehow. But the top of the cone is clearly designed to be this oval shape and after taking a closer look at pictures on the site, the product pictures also show the oval design. I hadn't previously opened the OEM air box to inspect the filter, so when I opened the AFE box, I just assumed the OEM filter would have a similar shape. That is most definitely not the case.
I usually have good luck with ECS Tuning but this is now the 2nd product they've sent me in the last two weeks, which does not fit as specified by their site. As a result, I'm now on my 2nd RMA, for two completely different parts. I don't know who is in charge of updating their vehicle fitment specifications but, needless to say, I no longer trust them.
On another note, I did learn that our OEM filter does not attach to the inlet/airbox like standard filters do. So any aftermarket filters will have to be specifically made with the clip mechanism (like nothing I've seen before) that the stock filter uses. Because of this, as you mentioned, it is unlikely we will have to many filter options. Which is a shame because the OEM filter is one of the most restrictive I've ever seen. For this reason, I am now more than likely going to end up shelling out $$$ for an aftermarket intake, just so I can get a less restrictive filter.
