Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 191
  1. #41
    Senior Member Three Rings Valentino S5's Avatar
    May 26 2019
    Mexico City
    Quote Originally Posted by bmoreS4 View Post
    Well, the 034 TCU tune only makes the TCU and ECU talk to it can handle the higher TQ, so it is not a true TCU tune yet.
    Oh, got it. I thought it was a formal TCU tune.Thanks for the info
    2019 S5 Coupe Mythos Black. EPL Stage 2 ECU+TCU. APR Intercooler. APR Ignition Coils. AWE AirGate Carbon Intake. Red Star Downpipe HJS 200cpsi. VPS Pre Muffler/Front Resonator Delete. ECS Big Bore Cast Aluminum Turbo Inlet Pipe and Silicon Turbo Inlet Hose. Pedal Commander Throttle Control System. 034 Motorsport Lowering Springs, Front Strut Brace & Transmission Mount.
  2. #42
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Valentino S5 View Post
    The Stage 1 TCU tune that comes included free with our ECU file remaps torque limits and recalibrates the torque safety systems to work with the added power of Stage 1 ECU tuning.
    Later stages of TCU tunes will provide more changes to the Transmissions shift behaviors, but for Stage 1 we were quite happy with the shift points and behaviors.
    -Nick@034
  3. #43
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    SQ5 e85
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
  4. #44
    Sep 17 2005
    Fremont, California
    One of our customers sent us his YouTube review of our Dynamic+ tuning he did on his B9 S5 Sportback. This video was great to watch, and 11.79s @ 116mph with a 3.57s to 60 is definitely cooking on the 93 file! Can't wait to see what it does when it's running our Stage 2 file optimized for hardware upgrades!
    -Sean@034
  5. #45
    Sep 17 2005
    Fremont, California
    In recent times, we have had many customers join the 034Motorsport Dynamic+ Family! If you want to meet and connect with many other enthusiasts with the same great taste as you, check out our 034Motorsport Customer Discussion Group on Facebook!
    This is a great behind-the-scenes pass into 034Motorsport!
    https://www.facebook.com/groups/034customers/
    -Sean@034
  6. #46
    Dec 27 2018
    San Jose
    034 is gonna do it again!
  7. #47
    Sep 17 2005
    Fremont, California
    Now Available from 034Motorsport:
    The X-Clear Driveshaft Tunnel Brace is designed to increase clearance for aftermarket exhausts by replacing the shallow-fitting OEM tunnel brace. This allows for a larger diameter exhaust to be installed without causing excessive rattling or vibration, while also utilizing an aeroflap to maintain OE like aerodynamics.
    The X-Clear Driveshaft Tunnel Brace replaces the factory brace with a CNC Machined Billet 6061-T6 Aluminum brace designed to increase exhaust clearance by 8mm over factory.
    Check it out here:
    https://store.034motorsport.com/x-cl...a5-s5-rs5.html
  8. #48
    Veteran Member Three Rings Dan99's Avatar
    Feb 09 2019
    Chicago Area
    Quote Originally Posted by 034Motorsport View Post
    New Rotor Upgrade, coming soon for B9 S4/S5!
    Any plans for RS5 rotors?
  9. #49
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Dan99 View Post
    Currently in development!
    -Sean@034
  10. #50
    Mar 26 2020
    ODENTON, MD
    When is Stage 2 coming?!
  11. #51
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by nward0107 View Post
    Stage 2 for 3.0T should be coming in just a few weeks!
    -Nick@034
  12. #52
    Mar 26 2020
    ODENTON, MD
    -Nick@034
    Awesome! I have a catless downpipe and need this CEL to go away!
  13. #53
    Sep 17 2005
    Fremont, California
    Available Now from 034Motorsport: P34 Cold Air Intake for B9 Audi S4 & S5 3.0 TFSI!
    034Motorsport has developed this comprehensive performance intake solution for the turbocharged 3.0 TFSI engine found in the latest generation B9 Audi S4/S5. Subsequently, the P34 Cold Air Intake System offers discerning enthusiasts measurable increases in horsepower and torque, sporty induction and turbocharger sounds, and a functional airbox and inlet hose design.
    Throughout the development process, multiple designs were modeled, prototyped, and tested - all to ensure that the P34 Cold Air Intake System delivers measurable performance benefits and superb fitment. The result is a partially-enclosed airbox which uses the factory fresh air inlet duct and heat shield, while housing a massive 5" inlet conical air filter, and a matching CFD-optimized filter tube.
    Minimizing Unnecessary Filter Shrouding
    034Motorsport focuses on optimizing every aspect of the intake system across a broad range of variables and compromises. A critical component of a high-flowing performance intake is the ability for air to flow around and into the filter. If the air cannot flow freely around the filter, it will be restricted from getting into it. Many aftermarket kits fit too large of a filter in an enclosure that cannot accommodate its size, thus choking the filter and reducing its overall flow. This often happens when a product is engineered for one variable at the expense of others. 034Motorsport conducted extensive tests and refined its development of the intake design to allow for maximum airflow surrounding the air filter, allowing for optimal airflow to, and through, the filter. The final result is the right size filter in the right size filter housing, creating maximum airflow and performance with OEM level filtering; the ultimate goal of any intake system. Be cautious of any intake that brags only of air filter size, without taking into account the detrimental effects of shrouding the filter.
    Pressure Drop Improvements
    Pressure Drop is the difference in ambient air pressure and the air pressure measured at the throttle body across the engine's rpm range. The higher the pressure drop at any given rpm, the more restrictive the intake system is, reducing airflow.
    Intake Configuration Pressure Drop
    P34 Cold Air Intake 1.64 psi @ 6500rpm
    Stock Intake 2.22 psi @ 6500rpm
    Dyno-Verified Wheel Horsepower & Torque Gains
    The P34 Cold Air Intake System for B9 Audi S4 & S5 was engineered with performance in mind, and is a free-flowing replacement for the factory airbox and turbocharger inlet hose. As the fruition of this design approach, the P34 Cold Air Intake System yields a measurable reduction in pressure drop at the turbo inlet compared to the factory airbox, with a corresponding increase in horsepower and torque throughout the powerband.
    Peak Gains in Horsepower & Torque:
    • Peak Horsepower Gain: 19 HP @ 4,950 RPM
    • Peak Torque Gain: 20 FT-LBS @ 4,950 RPM
    Features:
    • Developed In-House by 034Motorsport's Engineering Team
    • Dyno-Proven Horsepower & Torque Gains
    • Increased Airflow to Turbocharger Inlet
    • Enhanced Engine & Induction Sounds
    • Improved Throttle Response
    • Superb Fit & Finish to Match Factory Engine Bay
    • Stealthy OEM+ Design Utilizes Factory Inlet & Heat Shield
    • Massive 5" Inlet Conical Air Filter
    • CNC-Machined Billet Aluminum Velocity Stack
    • Large-Diameter CFD-Optimized Turbo Inlet Hose
    • Securely Installs Using Factory Mounting Grommets
    • Simple, Straightforward Installation Instructions
    APPLICATION GUIDE
    • 2017 - Present Audi S4 (B9) 3.0 TFSI
    • 2018 - Present Audi S5 (B9) 3.0 TFSI
    What’s Included:
    • OEM Quality Plastic Airbox
    • 5" Inlet Conical Air Filter
    • Reinforced CFD-Optimized Silicone Turbo Inlet Hose
    • CNC-Machined Billet Aluminum Mounting Buttons to Reutilize OE Rubber Mounts
    • Misc. Hardware
    CHECK IT OUT HERE!
  14. #54
    Sep 17 2005
    Fremont, California
    Now Available from 034Motorsport: Printed Cut-to-Fit Windshield Banner
    The 034Motorsport Windshield Banner is the single most substantive way to represent the best name in Volkswagen & Audi aftermarket. Not only does this banner provide you a unique way to tell others they are about to receive the gap, but also has a transformative amount of sun blocking.
    This cut-to-fit windshield banner is perfect for reducing some sun glare on your drive and repping 034Motorsport!
    Note: If you have a windshield sensor for auto wipers or auto headlights, you will have to trim a hole in the banner to accommodate, or don’t; we’re your tuner, not your father ¯\_(ツ)_/¯
  15. #55
    Sep 17 2005
    Fremont, California
    Available Now from 034Motorsport: Dynamic+ Billet Adjustable Front End Links for Audi B9
    Replace your flimsy, imprecise OEM sway bar end links with these performance engineered Dynamic+ Billet Adjustable Front Sway Bar End Links from 034Motorsport!
    Designed to improve handling, road feel, and steering response, 034Motorsport's Billet Adjustable Front Sway Bar End Links allow for instant transfer of suspension movement to the sway bar. These end links are also length adjustable to eliminate preload on the sway bar.
    Features:
    • CNC Machined 6061-T6 Aluminum Bodies (Anodized Black for Durability)
    • Zinc Plated Steel Ball Joints
    • Rubber is Vulcanized to the Steel for Extra Strength and Durability
    • Maximized Diameter of Threads into End Link Shaft for Increased Strength
    • OEM+ Quality with Adjustability
    • Quieter with Less Maintenance than Spherical Motorsport End Links
    • +/- 0.75" of Adjustability (1.5" Total Adjustment Range)
    • Direct Drop-In Replacement for Factory End Links
    • Sold In Pairs
    Functions:
    • Adjust Sway Bar Preload - Essential When Corner Balancing Lowered Vehicles
    • Increased Strength for Stiffer Sway Bars, Heavier Loads and Aggressive Use
    • Improved Sway Bar Reaction Time & Accuracy
  16. #56
    Aug 18 2016
    RIP: 2011 SI, 2019 Type-R
    Tejas
    Nevermind they got back to me :)
    B9 S5 Sportback - Glacier White Metallic - Prestige - Black Optic - S Sport
  17. #57
    Sep 17 2005
    Fremont, California
    034Motorsport is proud to formally announce Dynamic+ Performance Stage 2 Software for the Audi B9 Audi S4, S5, & SQ5 equipped with the EA839 3.0T TFSI engine and AL552 ZF8 transmission! Make up to 510 Horsepower and 616 FT-LB of Torque with our comprehensive ECU & TCU flashes and required hardware! 034Motorsport Dynamic+ tunes are flashed directly through the factory OBD-II port using the 034Motorsport Dynamic+ End User Flashing Kit, and offer dramatic increases in horsepower and torque throughout the powerband.
    Stock: 350 HP / 391 TQ
    Stage 1 91: 397 HP / 491 TQ
    Stage 1 93: 431 HP / 567 TQ
    Stage 1 E85: 486 HP / 601 TQ
    Stage 2 91: 454 HP / 542 TQ (+57 HP / +51 TQ)
    Stage 2 93: 476 HP / 576 TQ (+45 HP / +9 TQ)
    Stage 2 E85: 510 HP / 616 TQ (+24 HP / +15 TQ)
    Stage 1 ECU + TCU: $850
    Stage 2 ECU + TCU: $950
    Upgrade Stage 1 -> Stage 2: $100
    https://store.034motorsport.com/b9-b...-software.html
    Upgrading your existing 034Motorsport Dynamic+ tune to a higher stage is easy. Simply choose 'Upgrade Stg1 > Stg2' from the list of tuning options on the product page. After your purchase, install any additional required hardware, download your new tune, and flash your ECU using the Dynamic+ End User Flashing Kit.
  18. #58
    Sep 17 2005
    Fremont, California
    Looking for an easy, cost-effective solution to tighten up the drivetrain of your B9? The 034Motorsport Billet Aluminum Rear Subframe Mount Insert Kit is designed to limit movement in the factory rear subframe mounts to maintain proper suspension geometry when cornering, and improve the responsiveness of the rear suspension and differential.
    By filling small voids in the four factory mounts as well as limiting vertical movement, this insert set eliminates the associated slop to ensure that you experience a more refined, connected driving experience, especially when driving at the limit. These billet aluminum parts will not pack and wear over time and offer a lasting performance improvement.
    These are currently in stock and ready to ship!
    https://store.034motorsport.com/bill...9-audi-a4.html
  19. #59
    Junior Member Two Rings
    Feb 08 2021
    SC
    Any substantial increases in NVH with these?
  20. #60
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by sloppymax View Post
    The beauty of many of our Billet Inserts is that there is no/extremely minimal NVH added. This is because the insert sits freely in the bushing until loaded, where it takes up the slop. These rear subframe inserts in particular do not introduce any perceivable additional NVH.
    -Sean@034
  21. #61
    Sep 17 2005
    Fremont, California
    The Correlation Between Boost & Timing - Many folks wonder why some tuners choose E40 versus E85 for the B9 3.0T EA839.
    Every week, 034Motorsport hosts a live stream inviting our customers to ask any questions to our director of software engineering and CEO. This video below dives deeper into why we choose to calibrate for full ethanol.
    -Sean@034
  22. #62
    Oct 03 2018
    Romania
    Turbo inlet pipe and charge pipe for the RS5 B9? Come on guys, I doubt it`s that hard to make and people won`t buy them, when nobody makes them! It`s already 3 years since the car is on the market...I can`t believe parts area so scarce for this car when for other models everyone pumps up parts after 2 months.
  23. #63
    Sep 17 2005
    Fremont, California
    A sneak preview of what's to come with an upcoming update for our B9 S4, S5, and SQ5 ECU and TCU tuning! Fastest trap speed of any Stock Turbo B9 3.0T, all while full weight on street tires. This platform is shaping up to be quite the performer!
    How much deeper do you think we'll go?
    Mods:
    • 034 Stage 2 E85 ECU
    • 034 TCU Tune
    • 034 X34 Intake + Inlet
    • 034 Catted Downpipe
    • Wagner Intercooler
    • 265/35/19 Michelin PS4S Tires
    • Full weight!
    #dynamicplus #drive034
    -Sean@034
  24. #64
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Hope you figured out the customer problems in the sq5 forums. He said he had no response.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
  25. #65
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Bezlar View Post
    We did not have a record of that customer's inquiry, but have reached out to get his info and help determine what is wrong with his car.
    -Nick@034
  26. #66
    Sep 17 2005
    Fremont, California
    A New ECU Tune Revision is Now Available for your B9 3.0T EA839 from 034Motorsport! Simply log into your 034Motorsport flashing portal, select the latest revision, and flash!
    R2.0 Notes:
    Performance Enhancements:
    Increased Launch Control Ferocity
    With this update, your car will launch with a significant increase in force, allowing you to get off the line as fast as possible.
    Improved Drag Racing Performance
    We have optimized and improved the shifting strategies during the launch control sequence along with increases in launch control torque, making AMAX shifts even faster!
    Faster Shift Speeds
    Shift speeds are now increased across the board in all drive modes, with Dynamic mode having the fastest shifts of all the drive modes.
    "Stage 1+" Optimizations Added to All Stage 1 Files
    All Stage 1 files will now have the ability to accommodate and compensate for added hardware, increasing performance! If you are running an upgraded Intake and Intercooler, you can expect gains of roughly 20-30hp over base Stage 1 figures! Simply flash to the updated Stage 1 file and these changes will be in effect!
    Crackles in Dynamic Mode
    Crackles can be toggled on or off via Drive Select. They will be on in Dynamic and off in Comfort. In Individual, crackles can be toggled on or off via Engine Sound.
    NOTE: Launch Control Only Works in True Dynamic Mode.
    Free Revving in Neutral and Park
    The rev-limiter is now removed while in Neutral and Park. Impress friends and annoy those around you with limitless ease!
    Exhaust Flap Open All the Time in Dynamic
    When set to Dynamic, the exhaust valves will now stay constantly open.
    RS-Style Startup Rev Enabled
    Enjoy a nice start-up rev when turning the car on with our new RS-Style start-up program!
    Drivability Improvements:
    With any file created by 034Motorsport, we strive to make it perfect out of the box. That being said, when our customers provide feedback, we listen. In R2.0, we continued to improve and refine our files by taking your feedback and adjusting accordingly.
    Fan Control Adjustments
    A handful of users reported their fans running longer than expected, so we have made the necessary adjustments to the affected box codes to ensure this is no longer an issue.
    Cruise Driving Refinements
    Some users reported a light load oscillation issue that was present when cruising at highway speed. In this update, we have made adjustments and have resolved this.
    Cold Start Idle Improvements for Stage 1
    Some users reported idle speed fluctuations during cold starts. This has now been resolved.
    Secondary Air Injection Disabled on Stage 2 Files
    We have turned off the Secondary Air Injection (catalyst heating) as it is unnecessary with a high-flow or catless downpipe. NOTE: Your car will still start and heat up without issue in cold temperatures.
    We always recommend running the most up-to-date file available for your box code, as they are the most optimized variants available!
    For further information, check out the full release: https://mailchi.mp/034motorsport/r20...-034motorsport
  27. #67
    Sep 17 2005
    Fremont, California
    The 034Motorsport 2-Piece Floating Brake Rotor Upgrade Kits for the B9 & B9.5 Audi S4/S5 are complete replacement brake rotor kits, designed to work flawlessly with the factory calipers found on the B9/B9.5 Audi S4/S5. While reducing weight, the rotor retains proper thermal mass in the rings to adequately capture heat, while utilizing 72 directionally curved vanes to forcefully flow cool air through the rotor to dissipate heat.
    The central hat portion of the 034Motorsport rotor is made of 6061-T6 aircraft specification aluminum. The disc is constructed out of a proprietary metal alloy that can withstand immense braking temperatures while holding form. From the factory, the same straight-veined rotor is used on both sides of the S4. The 034Motorsport rotors utilize 72 directionally curved vanes to forcefully flow cool air through the rotor to dissipate heat and are unique to the left and right axle to provide a substantial increase in cooling efficiency over the factory rotor design.
    The face of the rotor utilizes J-Slot slots to clean the pad and surface of contaminants and allows hot pad outgassing, all while reducing overall braking noise compared to a traditional slotted rotor.
    The rotor and hat have a floating mount system that utilizes high-strength alloy steel bobbins. The pins take the load from braking events while maintaining the axial and radial float between the hat and disc, allowing for safe expansion and contraction from heat.
    Weight:
    Front
    • 034Motorsport: 21.25lbs
    • OE: 27.90lbs
    Rear
    • 034Motorsport: 12.15lbs
    • OE: 16.65lbs
    Features:
    • Lightweight Construction
    • Floating, 2-Piece Design
    • Aerospace Grade Aluminum Hats
    • CM-250 Special Alloy Rotor Rings
    • J-slotted Friction Face
    • OEM Fitment & Functionality
    • 72 Curved Vanes Force Cooling Air through Brake Disc
    • Directionally Curved Cooling Vanes vs OE Straight-Veined Rotors
    • Floating Bobbins Mounting System
    • Replaceable Rotor Rings
    • Lower Long-term Maintenance Cost
    Check Out Front Rotors
    Check Out Rear Rotors
  28. #68
    Apr 26 2021
    San Francisco
    Weight:
    Front
    • OE: 27.90lbs
    Rear
    • OE: 16.65lbs
    Features:
    Any plans on a brake kit for the b9 rs5?
  29. #69
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by ToroTheShibe View Post
    We are currently testing a set of B9 RS5 stock-sized rotors. No ETA on release at this time.
    -Sean@034
  30. #70
    Jul 21 2020
    F80
    Omaha, NE
    Quote Originally Posted by musculobog View Post
    musculobog I agree.
    Will 034 be making charge pipes? Any updates on the inlet for us 2.9TT guys?
    B9 RS5 stuff is slim to none.
  31. #71
    Apr 26 2021
    San Francisco
    Quote Originally Posted by Deezbluballz View Post
    musculobog I agree.
    I’m an rs5 owner and I’ve noticed the same thing. The 2.9tt just doesn’t get much support. Looks like most rs5 owners are keeping their car stock but it also seems like the 2.9tt platform isn’t really mod friendly as well. There was a user who did stage 3+ On the 2.9tt rs5 with upgraded turbos and only got into the high 10s. On the other hand 034, just released a stage 1 tune for the 3.0t with stock turbos pushing the same 10s.
    Best to wait for their stage 1 tune towards the end of the year that they’ve been working on. When that gets released, I’m sure there will be more supporting mods. No point for them to develop all these supporting mods with no tunes to utilize em.
  32. #72
    Senior Member Three Rings ninjamanRS5's Avatar
    Oct 26 2021
    Washington
    Looks like I’ll hold on to the RS5 for a year and pick up a C8 Z06 or lightly used McLaren lol. The RS5 has potential but with the lack of aftermarket support, this isn’t the car to have if you desire to customize it on many levels. So boring!
  33. #73
    Nov 07 2021
    Cincinnati
    absolutely
  34. #74
    Sep 17 2005
    Fremont, California
    Our B9 RS5 program is in full swing and will have the same level of support and offerings as our B9 3.0T program. As with anything at 034Motorsport, we spend copious amounts of time refining and perfecting our products, which inherently takes time. We're confident that the products we release will be transformative for the RS5, and that you guys will love the improvements they provide.
    -Nick@034
  35. #75
    Dec 07 2020
    orlando fl
    Quote Originally Posted by ninjamanRS5 View Post
    i have owned a few c7s working on getting a c8 Z06 my self, rumor has it could be up to 3 years until you get it =<
  36. #76
    Jun 27 2021
    Netherlands
    Great Nick. Really looking forward to some upgrades for the RS5/RS4 B9
  37. #77
    Oct 26 2021
    Washington
    Quote Originally Posted by solarrs5 View Post
    Phew! 3 years is unreasonable. Let’s hope those rumors are false.
    OP, look forward to the products you have available. I hope you plan to offer a TCU tune soon. The RS5 can use one.
  38. #78
    Sep 17 2005
    Fremont, California
    B9.5 3.0T owners: The wait is over! 034Motorsport Dynamic+ EA839 Stage 1 and Stage 2 ECU tuning and Stage 1 AL552 TCU Tuning is available now on sale at 10% off thru 12/6 for Black Friday!
    Stage 1 ECU + TCU: $765
    Stage 2 ECU + TCU: $855
    Upgrade Stage 1 -> Stage 2: $90
  39. #79
    Sep 17 2005
    Fremont, California
    The 034Motorsport Dynamic+ AL552 ZF8 TCU Tune is Now Available for the B9 S4, S5, & SQ5! Dynamic+ Tuning for the AL552 ZF8 safely and effectively optimize its operation for Stage 1 or Stage 2 Dynamic+ Performance ECU Software. The result is a noticeable improvement in acceleration without sacrificing comfort or reliability. This tuning is only available for the B9 S4/S5/SQ5 and is not currently available for the 2021+ at this time.*
    If you have purchased the 034Motorsport Stage 1 or Stage 2 Performance Bundle on/before 12/22, you will be eligible for a $200 tune discount towards the purchase of this Stage 2 TCU tune. To take advantage of this, email us at [email protected] BEFORE purchasing!
    Check Out The TCU Tune Here!
    Check Out The Tune Bundle Here!
    Features:
    Optimized Shift Points
    In order to take advantage of the increased powerband from the turbocharger, Dynamic+ Tuning optimizes the shift points in Sport Mode to maximize acceleration while retaining smooth drivability.
    When purchasing the Stage 2 TCU Tune, you will be offered specific calibrations for either E85/Race Gas and for 91/93 Octane (Pump Gas) when flashing! Both TCU calibrations are included free of charge. Each specific TCU variant sets shift points to correspond to the optimal RPM for the powerband that your car now has from your upgraded ECU tune.
    Kickdown Switch Disabled in Manual Mode
    When in Manual mode, you no longer need to worry about accidentally pushing through the kickdown switch on the throttle pedal!
    Improved Shift Speeds
    To further enhance the acceleration of your Audi, the ZF8 shift times are dramatically decreased in all driving modes, which ultimately results in quicker acceleration.
    Shift pressures are also increased in Sport Mode to maximize performance. In Sport Mode, you will notice less lazy shifts, more firm shifts, which ultimately results in quicker acceleration.
    AMAX Shifting
    AMAX Shifting is a shifting strategy that stands for “Acceleration Maximum.” These gear shifts are the fastest and quickest possible for optimal acceleration. These are activated in shifting after launching your vehicle from a stop using launch control.
    AMAX shift points are now optimized for specific RPM setpoints for Pump Gas ECU tunes, and Race Gas/Ethanol ECU tunes. Select the specific TCU file to match your current octane when flashing your TCU!
    The S4/S5 has AMAX now activated in the 4>5 and 5>6 shifts where it was previously disabled from the factory.
    The SQ5 now has AMAX activated in all shifts from 1st through 6th where it was previously disabled from the factory.
    Improved Torque Management
    As with any automatic transmission vehicle, the ECU and TCU computers work synchronously to properly apply torque to the vehicle's drivetrain in a safe and reliable manner. Within both the ECU and TCU, there are factory safety tables that limit overall torque output based upon what the factory first tuned the car for. The ECU reports the output of torque from the engine to the TCU, and the TCU decides if this is suitable, or too much. If it is too much, the TCU will command the ECU to reduce torque output based upon its safety tables.
    034Motorsport takes a holistic approach with its Dynamic+ Tuning and aims to retain as many OEM safety protocols as possible. While it is possible to tune around the factory TCU torque limiters from the ECU side, this is done at the expense of torque safety features that are integral in keeping your transmission running safely. 034Motorsport’s calibrators tune the ECU to work with the TCU to provide accurate torque values and recalibrate the appropriate safety ranges for the TCU. Taking these extra steps to retain OEM safety systems on the ECU and TCU side is just one of the many reasons that Dynamic+ software provides substantial yet reliable performance increases.
    034Motorsport B9 Audi S4/S5/SQ5 AL552 ZF8 Stage Descriptions:
    STAGE 1 (INCLUDED WITH PURCHASE OF 034MOTORSPORT EA839 ECU TUNING):
    034Motorsport Stage 1 Transmission Performance Tuning Software for the AL552 is included in the Dynamic+ Tuning Bundle with our Stage 1 & Stage 2 ECU software.
    The Dynamic+ ECU Tuning accurately reports torque values to the TCU to ensure that all safety systems are intact in both control units, and the added torque from tuning is properly adjusted for when driving/shifting, including all safety systems designed to protect the engine and transmission. This results in better shift quality as the transmission is not having to reduce engine torque or having to adapt to misreported inputs.
    STAGE 2:
    The 034Motorsport Stage 2 Transmission Performance Tuning Software for the Al552 is designed to further improve the drivability and performance of your Dynamic+ Tuned Audi B9 S4, S5, or SQ5. Dynamic+ Stage 2 TCU Software can be used with our Stage 1 OR Stage 2 ECU software.
    034Motorsport Stage 2 TCU Tuning further improves shifting performance and speed for casual and track driving in all driving modes. Dynamic+ Tuning also activates AMAX shifting in more gears to ensure the quickest and most efficient shifting strategies while launching your vehicle. Kickdown in Manual Mode is also removed.
  40. #80
    Junior Member Two Rings chineseunicorn's Avatar
    Apr 14 2019
    I have the 034 Stage 2 Tune with the ECU tune from IE. Is there any difference between the 034 TCU tune and the IE TCU tune? Wondering if the switch is worth it or not.
