Results 1 to 7 of 7
    Junior Member Two Rings BeeSiix's Avatar
    Feb 10 2019
    Wisconsin
    Lost internet connection while tuning
    I was tuning my car and I got to 55% when I lost internet connection. Is my ECU toast now? Or can I reflash?
    Oct 19 2008
    Ontario%20Canada
    Quote Originally Posted by BeeSiix View Post
    You likely want to speak to your tune provider.
    2011 S4 - Ibis White - 3 pedals - daily driver
    2.95 PR, EPL software, Merc Racing HX, Eurocode inserts, Koni Yellows, H&R OE Sports, beefy RSB, homebrew CR15, stainless brake & clutch lines, custom FBSW by FlyDesigns, P3 Multi Gauge
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    try to repeat the reflash, usually it's possible to redo it successfully if it stops midway if it's done via OBD.
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    Oh damn. Let us know what your tuner saids. Never about that when your flashing the ecu.
    we are the borg! resistance is futile.
    Feb 10 2019
    Wisconsin
    Quote Originally Posted by fastboatster View Post
    Okay thank you I will try to do that.
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    As long as you dint turn the ignition off you can re try the flash and it will go through.
    I have seen people have to try 3-4 times.
    However if you turn the ignition off.......
    Jul 11 2020
    Boulder Colorado
    Who’s your tuner? I know on EPL, if it fails midway you can just reflash and no issues
