Page 3 of 3 FirstFirst 123
Results 81 to 98 of 98
  1. #81
    Sep 17 2005
    Fremont, California
    034Motorsport Dynamic+ Tuning No Crackle files available upon request
    We understand that crackles are a widely debated topic, and we always strive to provide files that suit the needs of our customers. Up to now, the overwhelming feedback from customers has been that they are liked, so we have focused on providing them with our tunes. From here forward, we will offer our ECU tuning with no crackles upon request at no added cost.
    All files currently with crackles enabled in Dynamic mode are now available without crackles entirely. If you would like a no-crackle file variant added to your flashing portal for your existing tuning, please email [email protected] with your flashing information and the octanes/stages you would like without crackles.
    We will not offer custom crackle adjustments or changes to our existing crackle files. This is solely to provide customers who would like no crackles the option to select that.
    If you have any questions or want to submit your no-crackle request, please email [email protected]
  2. #82
    Sep 27 2020
    Golf TDI
    San Diego
    Awesome news! Now I don't have to sound like someone that just popped their tune cherry. Last thing you want to do is start popping for the Po-Po when you're being enthusiastic.
    2019 TT RS - S2E85 034 Motorsport - If you're gonna go, you gotta whoa!
  3. #83
    Apr 12 2023
    Minot ND
    Can you switch back to crackles whenever?
  4. #84
    Sep 17 2005
    Fremont, California
    Absolutely! You can flash between our crackles or non-crackles files whenever you'd like!
    -Justin@034
  5. #85
    Sep 17 2005
    Fremont, California
    The 034Motorsport Intercooler System is designed to replace the factory, insufficiently sized intercooler in EA888 1.8T & 2.0T equipped MQB Volkswagens & Audis. The 034Motorsport Intercooler System was designed utilizing CAD and CFD software to optimize the high-speed core and cast end tanks to ensure excellent cooling properties and provide the engine with cooler, dense air for maximum performance potential.
    Pressure Drop:
    When it comes to intercoolers, bigger is not always better. Pressure drop is the difference in pressure between the inlet and outlet of the intercooler system. Larger volume intercooler systems typically have minimal pressure drop, take longer to pressurize due to the volume, and have much higher thermal capacity. With a lower volume intercooler, pressurization is fast, the pressure drop is higher, and the cooling capacity is also reduced.
    034Motorsport optimized the pressure drop to create maximum flow but maintain high thermal efficiency, the result is higher boost pressure before and after the intercooler.
    Flow & Efficiency:
    The 034Motorsport Intercooler strikes the optimal balance between pressurization volume, thermal capacity, and pressure drop to offer one of the most efficient intercoolers on the market. The 034Motorsport Intercooler System utilizes a 24.6” x 16.25” x 2.0” core which is 63% larger than the GTI intercooler and 51% larger than the Golf R intercooler, resulting in cooler, denser air making its way into the engine regardless of outdoor temperatures. It could have been bigger, but then the time to pressurize the core would be longer which creates unnecessary lag.
    Tube and Fin Intercooler Core Construction:
    Intercooler cores are designed with two methods; tube and fin or bar and plate. Tube and fin intercoolers utilize lightweight and efficient construction with less material, which can shed heat faster with street, spirited, and track driving. Because intercoolers are placed on the front of the car, tube, and fin intercoolers also allow for the weight over the nose to be significantly lower than if utilizing a bar and plate intercooler, by up to 30lbs or more.
    Bar and plate intercoolers are typically 2-3x heavier, have a higher pressure drop, and have a much higher thermal capacity, though they cannot shed heat as quickly as a tube and fin intercooler due to their mass. Because of this, bar and plate intercoolers will typically have a much higher average temperature over time than the tube and fin, which is not ideal for sustained loads during spirited or track driving.
    The 034Motorsport Intercooler System is engineered with a tube and fin design, like virtually all professional race cars. Combined with the optimal volume and pressure drop, the 034Motorsport Intercooler System is excellent for street, spirited, and track driving alike - providing owners with continuous power without the risk of heat soak. The 034Motorsport Intercooler System is optimized for all vehicles such as those with stock power, stage 1 or 2 tunes, and hybrid turbo systems on the market.
    Features:
    • 034Motorsport's Transverse 1.8 & 2.0 TSI Intercooler Utilizes a 24.6” x 16.25” x 2.0” Core, Providing a Larger Frontal Area and More Capacity Compared to the Factory Intercooler.
    • 63% Increase in Volume Over Mk7 GTI
    • 51% Increase in Volume Over Mk7 Golf R/8V S3
    • Cast Aluminum End Tanks with a Tube and Fin Core Results in Excellent Performance While Maintaining a Lightweight Construction of Only 17.6 Pounds.
    • Optimized Utilizing CAD Software and CFD, The High-Speed Core and Cast Aluminum End Tanks Give This Intercooler Excellent Cooling Properties.
    • Flow Analysis and Simulations Were Created to Optimize the Design.
    • Proven Performance Gains
    • Lowers Intake temperatures, Without Sacrificing Much Airflow to the Radiator.
    • Compatible With Replacement Upgraded Radiators
    • Relatively Simple Installation
    • Easy as Replacing the Factory Intercooler.
    NOTE: Trimming of the radiator support is required to fit this intercooler. A similar amount of trimming to the other aftermarket intercoolers on the market.
    Check It Out Here!
  6. #86
    Sep 17 2005
    Fremont, California
    The 034Motorsport Vacuum Pump Kit for Volkswagen and Audi EA888 2.0T Gen 3 can be used to replace an OEM 2.0T vacuum pump or to be used as an upgrade on 1.8T vehicles that require 2.0T fuel pump upgrade options to meet higher fueling demands for ethanol, pump gas, and bigger turbo setups.
    Volkswagen and Audi EA888 1.8T Gen 3 owners can benefit from this kit as a direct drop-in upgrade for tuning applications requiring 2.0T fuel pump options. The 034Motorsport Fuel Pump Upgrade can easily be paired with this upgrade, allowing for 38.6% more fuel flow than the standard OE 2.0T pump. This increased flow allows the fuel system to meet the higher demands for ethanol, race gas, more pump gas and pairs perfectly with ECU software that requires a larger 2.0T High Pressure Fuel Pump setup!
    FEATURES:
    • Run Upgraded Fuel Pump (034-106-6060) on EA888.3 1.8T Motors
    • OE Vacuum Pump from EA888.3 2.0T
    • Includes an OEM Replacement Gasket
    • Genuine VW Parts
    • Direct Replacement
    NOTE: This will not work with stock 1.8T fuel pump.
    OE PART NUMBER INTERCHANGE:
    • 06K 145 100 J
    • 06K 145 100 B
    • 06K 145 100 BB
    WHAT’S INCLUDED:
    • 1x) OEM Vacuum Pump (06L 145 100 K or M)
    • 1x) OEM Vacuum Pump Gasket (06H 103 121 J)
    Check It Out Here!
  7. #87
    Sep 17 2005
    Fremont, California
    While it isn't specific to the TTRS, we thought we'd share some testing we did on our 8Y S3 - comparing the performance differences between OE rotors and our 2-Piece rotors.
    Some things this data highlights:
    • Data collected as 14 consecutive 60-0mph stops (ABS)
    • Incorrect veining on left and right rotors (The same rotor is used on both front axles, same as the 8S TTRS). This is seen as a performance deficit with the front and rear having a sizable temperature difference on the same braking event.
    • Once the 034Motorsport rotors come to temp, they stabilize at the temperature and gradually climb in temperatures, rather than the steeper slope of the OEM rotors.
    Interested in transforming the braking performance of your TTRS? Grab a set of brake rotors today:
    https://www.034motorsport.com/2-piec...i-8s-ttrs.html
  8. #88
    Sep 17 2005
    Fremont, California
    REMINDER: All 034Motorsport Hardware and Dynamic+ Tunes are 10% off MSRP during our Summerfest Sale!
    Save Now during the Summerfest Sale, ending Friday, August 18th. During this time, ALL 034Motorsport hardware products & Dynamic+ Tuning will be on sale - No Promo Code Needed!
    SAVE TODAY using this link!
  9. #89
    Sep 17 2005
    Fremont, California
    NEW ITEMS JOINING THE 034MOTORSPORT UNSPRUNG SALE!
    Save 10% on Dynamic+ Tuning for your Audi or Volkswagen, Dynamic+ Lowering Springs, and Billet Lowering Links during the Unsprung Sale - ending April 15th!
    These items are joining our ongoing Unsprung Sale, where you can save up to 10% on:
    Save Today!
  10. #90
    Sep 17 2005
    Fremont, California
    Are you looking to improve your handling, stance, or just replace your worn-out OEM suspension components? ALL 034Motorsport Hardware is currently up to 15% off MSRP during our Fourth of July Sale!
    Our Fourth of July Sale is live through Monday, July 15th, so take advantage of these savings while you still can!
  11. #91
    Sep 17 2005
    Fremont, California
    Looking for a Flowform wheel that offers great looks, incredible strength, affordable pricing, AND 50% off replacements if you curbrash one? Look no further than ZTF-LP01 Flowform wheels!
    ZTF-LP01s are currently on sale at up to 15% off and are available for all significant VWs and Audis. They offer great fitment and a gorgeous motorsport-inspired design in multiple colors, all backed by our Lifetime Damage Replacement Program! If you manage to damage your LP01 wheel from too much sendage, imprecise parallel parking, or anything in between, you’ll receive a 50% rebate on a replacement wheel!
    Find the perfect wheel for your Audi: Click Here
  12. #92
    Sep 17 2005
    Fremont, California
    From now thru July 15th, you can Save 034Motorsport up to 15% on Hardware and 10% on Dynamic+ Tunes during our Fourth of July Sale!
    034Motorsport will be closed tomorrow, Thursday, July 4th, in observance of the National Holiday.
    Click Here To Transform Your Ride!
  13. #93
    Sep 17 2005
    Fremont, California
    Wishing you a Happy & Safe Fourth of July from us at 034Motorsport! Save up to 15% on Hardware and 10% on Dynamic+ Tunes during our Fourth of July Sale!
    Click Here and Save Now!
  14. #94
    Sep 17 2005
    Fremont, California
    Save Up to 15% on Control Arms during the 034Motorsport Fourth of July Sale - Ending July 15th!
    The factory front control arms are an integral part of your suspension but can start wearing out as early as 40,000 miles - especially on enthusiast-owned vehicles that are driven hard on the street or track. As the rubber bushings degrade and ball joints develop play, alignment is compromised, and steering becomes less precise.
    034Motorsport Density Line Control Arms are designed to be a performance replacement, featuring high-durometer rubber bushings and high-quality ball joints. Density Line Control Arms are engineered to limit unwanted deflection in the suspension, resulting in tighter handling and more precise steering response than even brand-new factory control arms can offer!
    Click Here to Save on Control Arms!
  15. #95
    Sep 17 2005
    Fremont, California
    Fill the void in your driving experience with 034Motorsport Billet Aluminum Drivetrain Inserts! Engineered to limit movement without sacrificing ride quality, 034Motorsport Billet Inserts provide you with crisper shifts, tighter handling, and a substantially more connected driving feel overall.
    ALL inserts are currently 10% off during our Fourth of July Sale! - ending 7/15!
    Save 10% on Billet Inserts Here!
  16. #96
    Sep 17 2005
    Fremont, California
    The 034Motorsport Billet Aluminum Engine Catch Can Kit is the most comprehensive and effective PCV System solution for the Audi 8S TTRS and 8V.5 RS3! It is engineered and designed to provide optimal crankcase ventilation while keeping oil and water vapor out of the intake tract.
    Any oil that is collected in the catch can drains back into the engine via the turbo oil return line and the engine block, allowing for service-free use!
    Click Here To Learn More!
  17. #97
    Junior Member One Ring Reason92's Avatar
    Apr 05 2023
    2021 TTRS, 2024 Q5
    Austin, TX USA
    Does stage 1 93 have crackles?
    Edit: referencing the post on no crackle files being available
    2021 TTRS
    2024 Q5
    Gone: 2019 S5 SB
  18. #98
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Reason92 View Post
    For the TTRS, crackles are present on Stage 1 and are enabled in Dynamic mode.
    -Justin@034
