034Motorsport Tuning and Hardware Information + New Product Info
In this post, we will talk about the products that 034Motorsport offers for the B9 S4/S5 platform to enhance the performance of the 3.0T engine, and the chassis as a whole. We are here to offer an extensive product catalog of Substantive, quality parts that provide measurable improvements to your enjoyment of your car, so that you can kick ass at a drag strip, track day, or autocross event, and drive the car to work the next day with comfort and confidence. Below will be some links to the products we offer, as well as upcoming products you can expect to see in the future. If anyone has questions about products, feel free to use the comments as a place to discuss.
PRODUCT LINKS
TUNING
034Motorsport Dynamic+ ECU + TCU Bundle for Stage 1: CLICK HERE
034Motorsport Dynamic+ ECU Tuning for Stage 2: CLICK HERE
034Motorsport Dynamic+ ECU Tuning for Hybrid Turbo: CLICK HERE
034Motorsport Dynamic+ Stage 2/3 TCU Tuning: CLICK HERE
TURBOCHARGERS
TTE710 Hybrid Turbocharger Upgrade: CLICK HERE
TTE810 Hybrid Turbocharger Upgrade: CLICK HERE
Pure750 Hybrid Turbocharger Upgrade: CLICK HERE
4 Bar Map Sensors: CLICK HERE
POWERTRAIN
034Motorsport Acceleration Packages: CLICK HERE
034Motorsport X34 Carbon Fiber Intake: CLICK HERE
034Motorsport X34 Carbon Fiber Intake Air Duct: CLICK HERE
034Motorsport X34 Carbon Fiber Intake (Full System): CLICK HERE
034Motorsport X34 Carbon Fiber Air Scoop: CLICK HERE
034Motorsport P34 Cold Air Intake: CLICK HERE
034Motorsport S34 Carbon Fiber Intake: CLICK HERE
034Motorsport Turbo Inlet Pipe: CLICK HERE
034Motorsport SüperDüper Turbo Inlet Pipe: CLICK HERE
034Motorsport Stainless Steel Racing Catalyst: CLICK HERE
034Motorsport Carbon Fiber Radiator Support Cover: CLICK HERE
034Motorsport Carbon Fiber Engine Covers: CLICK HERE
034Motorsport OE Replacement Motor Mounts: CLICK HERE
034Motorsport High Pressure Fuel Pump Upgrade Kit: CLICK HERE
034Motorsport Boost Tap Kit: CLICK HERE
Pauter 4340 Chromoly Cross-Beam Connecting Rod Set, Audi EA839 3.0T Turbocharged Engines: CLICK HERE
Wagner Tuning Pro Series Head Stud Set: CLICK HERE
JE Forged Piston Upgrade 10:1: CLICK HERE
COOLING
034Motorsport Radiator Upgrade: CLICK HERE
SUSPENSION
034Motorsport Handling Packages: CLICK HERE
034Motorsport Dynamic+ Lowering Springs (For Sport & Non-Sport Suspensions): CLICK HERE
034Motorsport Dynamic+ Sway Bar Kit (Front & Rear): CLICK HERE
034Motorsport Dynamic+ Adjustable Rear Sway Bar: CLICK HERE
034Motorsport Motorsport Front Sway Bar End Links: CLICK HERE
034Motorsport Dynamic+ Front Sway Bar End Links: CLICK HERE
034Motorsport Motorsport Rear Sway Bar End Links: CLICK HERE
034Motorsport Dynamic+ Billet Adjustable Rear Sway Bar End Links: CLICK HERE
034Motorsport Density Line Adjustable Rear Toe Link: CLICK HERE
034Motorsport Motorsport Adjustable Rear Toe Link: CLICK HERE
034Motorsport Density Line Control Arms: CLICK HERE
034Motorsport Density Line Lower Control Arms: CLICK HERE
034Motorsport Density Line Rear Shock Mount: CLICK HERE
WHEELS
034Motorsport ZTF-01 Forged Wheels in 19x9.3 ET35: CLICK HERE
034Motorsport ZTF-LP01 Flowform Wheels in 19x9.3 ET38: CLICK HERE
CHASSIS
034Motorsport Billet Aluminum Front Strut Brace: CLICK HERE
034Motorsport Billet Aluminum Transmission Mount Insert: CLICK HERE
034Motorsport Billet Alumunum Rear Subframe Mount Insert Kit: CLICK HERE
034Motorsport Billet Aluminum Rear Differential Mount Insert Kit: CLICK HERE
034Motorsport Street Density Transmission Mount Upgrade: CLICK HERE
034Motorsport Stainless Steel Tow Hook: CLICK HERE
BRAKING
034Motorsport Dynamic+ Braking Package: CLICK HERE
034Motorsport 2-Piece Floating Front Brake Rotor Upgrade: CLICK HERE
034Motorsport 2-Piece Floating Rear Brake Rotor Upgrade: CLICK HERE
Stainless Steel Brake Line Upgrade: CLICK HERE
EXHAUST
034Motorsport Res-X Resonator Delete & X-Pipe: CLICK HERE
034Motorsport X-Clear Driveshaft Tunnel Brace: CLICK HERE
UPCOMING PRODUCTS/TUNING OPTIONS
We will use the comment section to share photos of upcoming products as they go through development, and add the links to the main post once they become available.
034Motorsport Billet Aluminum Engine Catch Can *Coming Soon*
