This past weekend, I rented a U-Haul pickup truck and 4-wheel car hauler, grabbed a friend and made the drive to Tampa. After meeting the seller and chatting with him about the car for a couple minutes, we started to load up the car. During our negotiations, I'd secured the car for $500 with the provision that the seller would keep the wheels, turbo, intake & exhaust manifold, and cylinder head (he mentioned it was a ported AMB head) - basically all the bits I didn't want/need. For this to work I had put my convertible on stands, pull off the wheels and bring them with me to put on the yellow car. With my wheels on the yellow car, we pushed it as far as we could onto the car hauler, and then finished winching it onto the trailer with a comealong. Somewhere along the chain of previous owners, someone had chopped the front springs, so the front was incredibly low. Fortunately the car fit on the trailer without scraping, so we tied it down, paid the seller, and drove back home.
Arriving home during a cold rain shower (okay, okay, 50* isn't that cold, but FL), we decided to just drop the car off in my backyard, and wait for a drier day to pull the wheels. The following day was bright and sunny, with a high of 65*; perfect for figuring out the headache which lay before me. Until the car was sitting in my backyard, I hadn't considered what an enormous pain in the neck it would be to lift the front end with the suspension slammed so low. Using a combination of 2x12' footers, some bricks and spare block laying around, I alternately jacked up the front from the frame rail, then blocked the front subframe, jacked up from under the sway bar bushing, and was finally able to get a jack stand and footer under the pinch weld behind the front tire. From there, the tire dance began. First the front wheel came off the donor car, and was installed on my convertible. The jack stand which was freed by installing a wheel was moved to the yellow car so I could take off another wheel, and the process continued for all four wheels until my convertible was once again driveable, and the yellow car stood on stands in my backyard.
This is the end of step 1: acquire a donor car. Step 2 is to pull parts from the donor car, and will be started as I have time this week, or (most likely) this weekend.
Taking the drivetrain from the yellow A4 on the left and putting it in the blue A4 on the right:
