Results 1 to 11 of 11
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    Question Engine Doesn't Start: Codes P2295 and P129C - Need your help
    Engine doesn't start. It cranks but doesnt turn over/on.
    Pulled codes: P2295 Fuel Pressure Regulator Valve (N276)
    P129C Fuel Pressure Regualtor Valve Bank 2 (N276)
    Also warning on dash: "Maximum engine speed 4000 RPM"
    I checked the fuses and all seem good. I looked at the wiring and the plugs to the HPFP and they look normal.
    I cant run measuring blocks because it doesnt allow me to, the VCDS "Measuring Blocks" button is faded, cant click on it.
    Any ideas? Which HPFP should i replace first? Or can i replace just the fuel pressure sensor and use the same pump? Do you think this is a Cam Follower worn out problem? Please advise.
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Jun 18 2017
    10512 Hunter Trl/Illinois/
    Have you checked the fuel pump relays?
    Mar 15 2012
    Quote Originally Posted by Gwillplays View Post
    hey, thanks for the help.
    Yes, i checked all the relays as per the manual instructions. I gave up so i towed it to my mechanic.
    He discovered that there are more relays on the left side of engine compartment, plastic box. A couple or relays 645 were not operating as they should. so he changed them and now its working great.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Established Member Two Rings orphancrippler's Avatar
    Aug 01 2020
    2018 Nissan Rogue SL, 2016 Nissan Rogue SV
    Telford, Pennsylvania
    Quote Originally Posted by S4_SH1640 View Post
    I realize you've already fixed the issue, but just for future reference, in newer VCDS and for modules that use the UDS protocol, Measuring Blocks has been replaced with the Advanced Measuring Values segment. It should be on the bottom-right of the area where you can choose your functions in the main screen once you select a module.
    Sent from my Galaxy S20 Ultra 5G
    2017 S6 DS1/SRT Custom ECU+TCU "Deathstroke the Terminator"
    SRM +4mm, HPA Street DPs, APR Catback w/X-pipe & 4" Tips, APR HX, MercRacing IC Core, SRM Short Intakes, AWE S-Flo V2, SRM Dual LPFP, Autotech Plungers, SRM FF Sensor + Engine Lines, 4 Bar MAP + Boost Sensors, TiAl WG Actuators, EMP Pump, JHM Oil Screen Kit, 034 Rear Swaybar/Endlinks/Drivetrain Inserts, SRM Driveshaft Carrier, iO2 CatSims, CF Spoiler + Mirrors, RS-Quattro Grille, Black Badging, CeramicPro Gold, 20mm R/17.5mm F Spacers
    Mar 15 2012
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Mar 15 2012
    Can anyone tell me if these numbers checkout okay???
    I got the car back and fixed that issue of no start at all. Drove great while at the mechanics. Drove it all weekend.
    Now it doesnt always start on the first try. It cranks but does start, until i press the gas pedal, then it starts. Once i do this, shut it off, and then try again, then it works. If i go for a ride, and shut it off, wait 10 mins, then it doesnt start on 1st or 2nd try, different everytime.
    Until i press gas pedal as its cranking to make it to start.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Probably hpfp next you should replace. Open the oil cap and smell for heavy fuel smell in the oil. If it does smell like fuel it’s time to replace the pumps.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Mar 15 2012
    Quote Originally Posted by ichi d View Post
    But its strange because they're not throwing a code.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    May 10 2013
    Toronto,ON
    Mine didn't throw a code either. I started getting hard warm starts and like you had to press the gas pedal down for it to start. Once that happen i knew to smell for fuel and long and behold it had a strong smell.
    Replace but hpfp with the latest revisions and the car starts fine now. Hope this help.
    Aug 01 2020
    Most people with hpfp leaks don't have codes, it's mainly the hard starting and fuel smell in oil that tells the tale.
    Mar 15 2012
    Thanks guys! I appreciate the assistance!
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
