Engine doesn't start. It cranks but doesnt turn over/on.
Pulled codes: P2295 Fuel Pressure Regulator Valve (N276)
P129C Fuel Pressure Regualtor Valve Bank 2 (N276)
Also warning on dash: "Maximum engine speed 4000 RPM"
I checked the fuses and all seem good. I looked at the wiring and the plugs to the HPFP and they look normal.
I cant run measuring blocks because it doesnt allow me to, the VCDS "Measuring Blocks" button is faded, cant click on it.
Any ideas? Which HPFP should i replace first? Or can i replace just the fuel pressure sensor and use the same pump? Do you think this is a Cam Follower worn out problem? Please advise.
