Results 1 to 3 of 3
    Junior Member Two Rings
    Feb 21 2021
    Pasadena md
    Location on knock sensors
    08 Audi A4 b7 throwing codes $7e8 $7e9 which I going our is knock sensor but can’t find them anywhere no pics help
    Senior Member Two Rings Epic-A3's Avatar
    May 05 2019
    Pennsylvania
    They are buried unfortunately, but should be colored plugs. On my 06 A3 they are green and brown. Located on the front of the block around the oil filter housing if that helps. They are a pain to get to. If your getting those codes for both sensors though. Dig in deeper to make sure it's not serious mechanical issues.
    Sent from my SM-G950U using Audizine Forum mobile app
    Senior Member Two Rings BradyBoi55's Avatar
    Apr 19 2020
    1994 Ford F-150, 1931 Ford Model A, 2007 BMW 650i
    Manchester/NH
    Ive dealt with knock sensors. There is only one on our engines and it is behind the lower part of the intake manifold. The plug is right below the intake manifold. To get to it you will have to pull off the intake manifold and coolant pump if you are looking to replace it. Usually knock sensors never go bad.
    2010 Premium Plus b8 A4 Avant
