Page 1 of 3 123 LastLast
Results 1 to 40 of 98
    Junior Member One Ring DSC Sport's Avatar
    Feb 18 2021
    Jessup, MD
    DSC Sport Active Suspension Controller for TTRS
    Transform the handling of your TTRS with the DSC Sport Controller! The DSC Sport Controller is a Plug N Play active suspension controller that replaces your factory DCC control module and works with your factory active suspension. With our revolutionary tuning strategy, DSC Sport provides your TTRS with better track handling and improved daily comfort. DSC Sport will greatly improve your everyday ride, all while offering improved grip and reduced squat, dive, and roll on track!
    By expanding the dynamic range and rate of response, DSC Sport is able to utilize more sensory input data and provide real time damping solutions. By gathering G Force, Brake Pressure, Steering Angle, Speed, Acceleration, Shock Calibration, and Velocity; DSC Sport adjusts each individual damper in real time to provide the most optimum damper performance both on and off the track.
    Our controllers have been proven in the Porsche community for many years, ranging from 100% track cars to those people that just want to have fun on the backroads on a nice weekend. We been expanding our product line consistently since then, including Dodge, Ford, Nissan, Cadillac, Chevy, any many more custom applications running a standalone kit. We have been met with great success in all of these platforms and figured now was the time to move into the VAG community.
    All of our controller come pre-calibrated with a suspension tuning file that we believe will be adequate for most drivers. So if your one of those, its something you can install, get all the benefits and never have to worry about again. But for those with specific needs for the track, wether it be the drag strip or the road course, the controller is 100% tunable on your end. Using the DSC Sport Tuning Software, users can custom tune their suspension to personal preference. Set maximum and minimum damper rates and tuning characteristics for various driving scenarios, vehicle setups, and personal preference. DSC Sport puts the power of a suspension engineer in the palm of your hand.
    Installation for the TTRS is a very simple process and should only take you about 30 minutes, just swap out the factory module for your new DSC controller. The factory module is located under the passenger seat, just unbolt it and tilt the seat back to the rear. A write up for the install will be available on our product page for the controller.
    Our product page for the TTRS can be found here:
    https://www.dscsport.com/product/v4-controller-audi-2/
    Established Member Two Rings nardoRS's Avatar
    Jul 08 2018
    UK
    This is great news! I’ve seen and heard great reports about DSC Sport from the Porsche PASM world.
    Could you go into more detail about the offering for our cars, including:
    - Is the calibration specific to the TTRS and different for the RS3 and S3. I’d expect, but may be wrong, that the calibration in my oem unit isn’t the same as the calibration for the RS3 or S3.
    - How would the two modes be different to oem? Will Dynamic have the potential to go stiffer when needed. Will comfort be softer?
    - What does the DSC do that the oem controller doesn’t?
    - be good to hear some feedback directly from TT/RS3 owners; even better some laptime comparisons oem vs DSC
    Thanks for bringing this to market and I’m very interested in learning more!
    Sean
    2018 TT RS Nardo grey, MSS Track pack, Vagbremtechnic/AP Racing rotors, AP Racing CP9660 calipers, DS1:11 f, DS2500 r, Odyssey 925 battery, rear seat delete, Sparco QRT seats, Schroth 4point harnesses,APR Intercooler, 034 fixed camber plates, Neuspeed RSe11r 18x9.5 45 offset and 034 Motorsports ZTF 18x9.3, Dyno Spectrum DS1 stage 1and2 with 93,100,104 and flex fuel maps, TVS stage 2+ tcu tune, 1340 kg 1/4 tank.
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    Intriguing. It would be interesting to hear what the new shock setting are configured for spring wise. Most performance seekers will want at least 10k springs front and rear. What is the effective range of springs that you can run on the stock magride shocks before they are out of spec?
    Feb 18 2021
    Jessup, MD
    We have been testing calibrations for the last year on multiple RS3 and TTRS's. We have found a middle ground that works for both cars amazingly out of the box. But as with any of our controllers, it is 100% customizable and can be tuned to any users liking and needs. As for your question about the variations between modes, we change the dampening curve, rebound, and stiffness of each corner in simple terms. Unlike the factory, Our module utilizes the factory sensors to monitor G Force, Brake Pressure, Steering Angle, Speed, Acceleration, Shock Calibration, and Velocity, and the tuning for each mode will read these inputs and adjust accordingly. The factory module does adjust dampening but it is only semi active. Meaning it does set a different dampening in each mode, but it won't be fully active, where ours will stiffen up one corner and soften another depending how hard you take a turn and then continuously do that the entire way around a track
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Quote Originally Posted by DSC Sport View Post
    I can speak from personal experience that the DSC module is a game-changer in terms of improving the suspension. I have one in my 981 GT4 (that's a Cayman for the unenlightened), and it improved the ride quality of the regular mode, and greatly increased the car behavior in PSM Sport Mode. For the regular mode, it made the car more streetable, tuning out the inherent stiffness or bang to the frame that the car has from the factory when one rolls over small bumps. And for Sport mode, it greatly reduced dive and body roll upon hard cornering, allowing for faster lap times, and better wear on the tires. I tend to think of it as a coilover cheat, as it provided my already great car with even better drivability and handling without having to shell out dough for coilovers + labor + suspension dialing (which takes a while and eats up track time). Their support is also great, as Tom always makes himself available to me.
    So, in terms of the TT-RS, can you guys share what we could expect from the COMFORT and DYNAMIC Modes? Is Comfort plushier, less bouncy maybe? And is Dynamic softer sprung in a straight-line but tightens up when lateral load is placed on the corners? Might your tune help mitigate some of the inherent PUSH?
    PLEASE SHARE!
    Established Member Two Rings DKo5's Avatar
    Aug 25 2014
    Despite the lack of TT-RS info I went ahead and ordered a unit. As much as I dislike how "4x4" the TT-RS looks on stock suspension, I really don't want to go back to the days of scraping on every bump or driveway - so I'm hoping the DSC controller will improve handling enough to keep me from throwing on some MSS springs. Unit should arrive on Monday and I'll be going Uni stage 2 on Wednesday before hitting the track on the 30th. I'll try and write up my impressions, but be warned that I am not a highly skilled driver (this will make track day #4 for me) so my review might not be all that interesting.
    Veteran Member Three Rings kevin#34's Avatar
    Aug 11 2019
    Rome, Italy
    is the DSC available for TTS too?
    2020 TT- RS
    ex 2018 TTS
    Junior Member One Ring James06sti's Avatar
    Apr 16 2021
    Quebec
    Quote Originally Posted by DKo5 View Post
    did you try the DSC controller finally ?
    Envoyé de mon iPhone en utilisant Tapatalk
    Nov 03 2014
    BMW i3, Golf 1.4T, TT RS 8S
    Mexico
    +1
    Dec 02 2020
    TTS - 370z - RSX-S Racecar
    Qatar
    Quote Originally Posted by kevin#34 View Post
    Same question, is the TTS supported?
    Established Member Two Rings MESOGLEA's Avatar
    Feb 17 2021
    2018 Lancia Ypsilon
    Scauri, Italy
    Received, installed and tested a DSC Sport Controller in my 2019 TT RS with OEM mag ride suspension and OEM 20's with non run flat Pilot Sport 4S
    Ladies and gentlemen, this is the real deal.
    I started with comfort mode. It was a noticeable different driving down the hill from our neighborhood 1.25 miles to the main road. Around town at 45 MPH and below, its very compliant. It surprised me, really does ride better.
    Road noise is the same and you still feel the little bumps. It's a sports car. However, the suspension articulates way more than OEM. At higher speeds, it "floats" as some say.
    It feels like it squats under braking. Speed bumps at parking lot speeds are no where near as harsh.
    I could tell the difference between comfort and dynamic.
    Dynamic mode feels similar to OEM comfort but with more suspension travel.
    I have more miles to drive to evaluate and acclimate to the differences. To me, it's worth it for the ride improvement alone.
    Jun 30 2020
    2018 TTS, 15 S1000r, 14 Z1000, 1990 ford festiva
    Southern Indiana
    Quote Originally Posted by MESOGLEA View Post
    Is there a race setting or something like that? I have look at this a few times but never pulled the trigger. If it can add to comfort and make lap times better im game.
    Sep 27 2020
    Golf TDI
    San Diego
    If you don't want to switch to coil-overs the DSC controller is a great improvement over the stock controller.
    I'm using this on a 2019 TT RS with 265/35/18s on 034 forged rims, 034 springs and all other 034 suspension parts installed. I'm working on a street tune file for my setup, suggestions from others have worked well. For me I drive in Dynamic only and have yet to adjust the DSC "comfort" mode to my liking, so it's disabled for now. After dialing in more rebound control the faster you go the smoother things get (without losing feel of the road), road imperfections here in So-Cal are not so much of a problem anymore.
    The improvement of anti-dive and selective "stiffening" of a corner(s) based on load/speed is transformative on the street. There is a launch mode too. There are a lot of video explanations and instructions on the DSC site. If you go with this controller and don't utilize its tuning ability better to stay stock.
    Senior Member Three Rings 8STTRS's Avatar
    Jul 28 2021
    Navarre, Florida
    Thanks for the feedback there, DrMerl. I had a DSC Sport on my C7 Z06 and I loved it. I also increased the rebound and found it to be much improved. I may be in contact with you in the future about your setup and the adjustments you made to your settings. Are you running aggressive camber at all?
    2018 Audi TT RS
    JDY Next Gen 6670 coming soon (shooting for 975-1kwhp on low boost).
    Sep 27 2020
    Golf TDI
    San Diego
    Quote Originally Posted by 8STTRS View Post
    I'll be happy to share a config file or data set. There's great deal of data available for Porsche and the Corvette, but I can't find much specific for the RS3/TTRS yet.
    I am using the 034 front camber plates.
    Current alignment is for street w/ some braking stability -
    Front -
    Camber : -3.0 deg
    Caster : 7.1 deg
    Toe: .6mm (in)
    Rear -
    Camber: -1.5 deg
    Toe: .8mm (in)
    Excellent improvement for me and the 034 parts combo. More confidence on accel and braking, "flickable" in transitions, rear end follows nicely but is not jumpy. Pretty darn good for a FWD based chassis IMO and not going crazy with suspension.
    My current DSC file has -
    Under Velocity +5% under Zero, +10% for Reb-Low, Reb-Med, Reb-High
    G Comfort - G Rate Max is 0.0
    These settings have made 70-120MPH cruising effortless on the bouncy, unpredictable freeways around here. Other cars are basically pylons.
    It is not soft by any means, more like very, very sporty, you're gonna need to hold your Starbucks cup for some freeway bumps. Going to Comfort setting in Audi Drive now is worthwhile when cruising local streets.
    I'm going to test out slightly less compression to see if I can smooth things out a little more without resorting to G Comfort.
    Goal is to absorb bumps the same way a cat or a Baja truck lands.
    Jul 28 2021
    Navarre, Florida
    Is your camber in the rear neutral?
    2018 Audi TT RS
    Sep 27 2020
    Golf TDI
    San Diego
    There's a bit of negative (-1.5) to lean towards cornering grip (for street). To utilize I've stiffened up the rear with 034 RSB (soft setting), 034 spherical end links, 034 spherical trailing arm, 034 street density rear shock mounts. After I added the rear trailing arms I think the ride improved nicely (no additional noise), more predictable under load. Audi did an amazing job keeping things tame, comfy and quiet, but so much is left on the table if you're an enthusiast.
    Senior Member Three Rings McTTRS's Avatar
    May 09 2017
    Alabama
    It does. If you check out the software settings (this is stock), you can see the difference in front and rear shock settings under braking. DSC Stock TT RS Brake Settings
    2022, 2021, 2020, 2019, 2018 TT RS - 2016, 2010, 2019 TTS - 2006 Porsche Cayman - 2001 TT Quattro
    Feb 17 2021
    2018 Lancia Ypsilon
    Scauri, Italy
    Someone said a DSC unit is like an ECU/TCU tune.
    I agree.
    May 09 2017
    Alabama
    I agree.
    Seems to have that impact on the suspension but you are replacing a dumb as a barrel of rocks untunable computer that controls all the suspension corners the same based one ride height sensor with a user tune-able computer that controls each corner of the suspension independently based on a full array of sensors. To me its more like going from points and a distributer to a tunable ECU based ignition system.
    Established Member Two Rings Cyttorak's Avatar
    Jul 29 2017
    2018 TTRS
    Dallas
    @DSC Sport - Was about to pull the trigger today when I discovered this by mistake. Put the controller in the cart, shipping zip and got $38.65 in shipping then realized I forgot to add the signature required for $0 and recalculated. The shipping cost increased @50% to $57.79.
    Is this accurate? Or a website glitch?
    Thanks in advance.
    May 09 2017
    Alabama
    Give them a call at 410-789-7798 and get an explanation.
    Jul 29 2017
    2018 TTRS
    Dallas
    They got it fixed, website glitch. Ordered mine.
    Established Member Two Rings dWiGhT's Avatar
    May 27 2010
    Chevy Volt
    San Antonio, TX
    how hard is the installation and where is it in the TTRS?
    May 27 2010
    Chevy Volt
    San Antonio, TX
    Quote Originally Posted by dWiGhT View Post
    Google-fu to the rescue!!!!
    https://www.dscsport.com/wp-content/...er-Install.pdf
    Sep 29 2021
    Berlin Germany
    dont forget to connect a usb cable and let it lay under the seat :-)
    Aug 14 2020
    Springfield MO
    Quote Originally Posted by DrMerl View Post
    Front -
    Camber : -3.0 deg
    Caster : 7.1 deg
    Toe: .6mm (in)
    Rear -
    Camber: -1.5 deg
    Toe: .8mm (in)
    Would you mind sharing your file with me?
    I just got the dsc sport controller and feel like I can improve on some aspects of it. Something that really bothers me is the overall bouncing after harsh bumps. Did you experience the same?
    Jul 29 2017
    2018 TTRS
    Dallas
    I’m experiencing the same thing in comfort mode. Like a bounce house
    Sep 27 2020
    Golf TDI
    San Diego
    Quote Originally Posted by Cyttorak View Post
    Add +5-10 in the G-Comfort > Default Rate. This should help with the bounce when you're cruising with zero G. Load the latest config file from their website. A totally different way to control things as far as settings. It's good so far after several hundred miles, but I've still added to the Default Rate to help with bounce (added +5 so far).
    Aug 14 2020
    Springfield MO
    What file are you referring to? I have tried both the stock spring file and the mss spring file.
    May 09 2017
    Alabama
    Quote Originally Posted by slammin86 View Post
    The original config files were dated in 2021 but OEM damper file was updated on 4/8/22 and is a lot better starting point. I then added +5 g-rate and +5 sensitivity and like the result - less floating.
    Sep 27 2020
    Golf TDI
    San Diego
    Quote Originally Posted by McTTRS View Post
    Yep! I went through lots of fiddling with numbers on the previous files, the new file is a way different approach. It works better than before regarding control at high speed, with G force and hard braking.
    I right away did the same additions to the settings, I do not like the floaty Caddy feel when just cruising. The roads and freeways around here are not good for a hobbie-horse ride.
    This is the file to get -
    https://www.dscsport.com/wp-content/...only.pdts_.zip
    I'm using 034 Motorsports everything for suspension bits on my TTRS, the new file handles the quicker response from the hardware in a nicer way. This is sharing from a street only car.
    Aug 14 2020
    Springfield MO
    This is the tune I tried. So you think the bounciness is tied to the comfort setting? I was going down the path of it being compression and rebound related?
    Sep 27 2020
    Golf TDI
    San Diego
    Try both, there's no real set "way" to tune this. It's fairly new for the RS crowd so whatever we can contribute will help.
    You can increase rebound control, that will help with the lift you off the seat kind of bounce at speed. Keep in mind zero G comfort and what happens when you start to put .1 G on the car. The system changes. It's very good on the new config file when you start applying G's to the car. It's just a little off (a little too bouncy for most), depending on personal preference, when at steady state - zero G.
    May 09 2017
    Alabama
    If you have not done so already, I would suggest you watch the DSC support video https://youtu.be/vK2E6D0B9os starting at 10 minutes after start. It explains the "go to settings'" to tighten things up.
    Sep 27 2020
    Golf TDI
    San Diego
    Just did a loop drive I usually do, it's about 200 miles.
    Using the latest DSC config file from 04/08/22, I applied +5 Default Rate and +5 Sensitivity under G Comfort Parameters for all three tables (Normal, Sport, Track).
    I rarely use Comfort or Auto or Individual settings, 95% Dynamic mode.
    My route is San Diego > 5 North > Highway 1 through the OC to Newport > 91 East > 215 South > 15 back to SD. The roads and freeways can go from glass to ass one mile to the next. When the 5 is open Northbound it's great, there's a lot of construction and speed monitoring areas, the freeway is 80% smooth with a few places I use to test settings. New settings gave a little more controlled ride (nose can bounce) at Zero G, wasn't as bouncy as initial file settings. It was close but I prefer a stiffer ride at zero G with the DSC.
    I added a little more to Default Rate and it helped very nicely with a firm, sporting ride. The 91 is a horrible freeway in some areas, most of time the concrete patches are cupped (do the Porpoise dance) , with sh1tty repairs, height differences between patches can be a few inches and big grooves to catch your tires for tram-lining (that is not fun at WOT when you're suddenly being yanked left or right). If you can get a decent ride on a sports suspension over this freeway, you're doing pretty good. Adding a bit more to Default Rate worked well.
    Here's what I have now -
    Sport table - Default Rate:18, Offset:30, Sensitivity:17, G Rate Max:18
    There are ton of ways to adjust, with many that do not seem related, but it's all a system with tables building on tables, the new file is a pretty different way to achieve good/different results. I like the direction of the config file changes, lots more to learn though.
    265/35/18s on 034 rims, PS4S, 38psi F/33psi R (cold). 034 RSB soft, 034 spherical endlinks, 034 trailing arms, 034 rear shock mounts, 034 subframe collars, 034 camber mounts, F/R 034 floating rotors. Stock alignment except for the added camber from the 034 mounts. Had a bit more toe earlier and it was way too squirrely for higher speeds, but perf for canyon carving.
    On order is a 034 FSB with spherical links and the new camster mount pair (a bit of fixed caster and camber). Also going try out 275/35 Conti shoes, they are lighter than the 265/35 PS4S's. Love to ditch unsprung weight when it's available.
    Sep 27 2020
    Golf TDI
    San Diego
    Going back over the DSC config video. I think I'll go back and reduce the Sensitivity number, I want it to change more quickly from G Comfort to standard G force based rates. So I'll go back to the original number for Track. May reduce G Rate Max to 15 or 12 - that's .15 and .12 G's on the Audi meter, a small direction change at speed is .1G.
    Jun 11 2012
    2021 Audi SQ5 | 2019 Audi TTRS | 2004 Audi S4 (parted out) | 2000.5 Audi S4 (sold) | 2001 Audi A4 1.
    Corona, CA
    You’re not kidding about 91. The first time I drove on it with e85 the other day was quite the experience just keeping it straight while wot. As you said, I was getting pulled to either side and it was pretty violent too. It actually scared me and I quickly slowed down. Can only imagine what that’d be like with an upgraded turbo.
    Sep 27 2020
    Golf TDI
    San Diego
    Quote Originally Posted by mtwallace85 View Post
    I'm glad I'm not the only one feeling this, yeah, setting things up for street takes another approach on this chassis. 500-600HP is pretty stoopid for such a small vehicle. The stock alignment settings are tolerable, it's nice to have an active and responsive suspension, but there's a limit for street and the crazy roads. Removing unsprung weight helps a lot. More fiddling with DSC gives a very nice, steady WOT at any speed - but again, those damn ruts. I'm going to add more punishment by trying out wider (275/35/18), but lighter tires. Hoping the new 034 "camster" shock tops will help with straight line stability.
    Jul 29 2017
    2018 TTRS
    Dallas
    Doubt if it’s related but can’t help to have that feeling cause only thing I did was update my DSC controller as suggested by DrMerl. To get that bounce/caddy out of the comfort made.
    Then within 5 minutes of the update, was going WOT to get on the tollway by my house and seemingly every warning light/message came on.
    Steering malfunction, speed control systems, safety systems, esc, abs, headlights, homelink didn’t work to get back in my garage.
    Lol, not a Sunday funday for me.
    I take it nobody has experienced any of this after updating?
