Page 15 of 18 FirstFirst ... 51314151617 ... LastLast
Results 561 to 600 of 709
  1. #561
    Senior Member Two Rings jmswashere's Avatar
    Jun 27 2013
    St. Augustine, FL
    Quote Originally Posted by Otis98 View Post
    Attachment 313608
    Look what arrived today!
    Attachment 313870
    Mounted
    Where did you get those from?
    Current: 2023 Audi RS6 Avant - Daytona Grey; CCBs; Carbon Optics; AWE Exhaust; OEM RS6-P Bronze Wheels; APR Intake
    RIP: 2020 Ford Mustang Shelby GT350; 2017 SRT Jeep Grand Cherokee; 2014 Audi S4; 2015 Dodge Charger SRT 392; 2008 Audi S6; 2006 Nissan 350Z
  2. #562
    Apr 12 2011
    Rochester, NY
    Quote Originally Posted by jmswashere View Post
    Great partner to work with:
    https://www.partsbytopher.com/collec...43293398007975
    2021 RS6 Avant Vegas Yellow
    2017 RS7 Mythos Black
    2014 RS5 Nogaro Blue
    2011 A4 Avant Quartz Gray - Daily Driver
  3. #563
    Stage 2 Banner Advertiser Three Rings PartsByTopher's Avatar
    Jan 11 2021
    Westchester NY
    Quote Originally Posted by a10eun View Post
    Attachment 314160
    OEM Performance wheels from Parts By Topher, thanks Chris!
    Came out way better than I hoped. I just wish the rear was more concave.
    Quote Originally Posted by D2G View Post
    Thanks for all the support!
    These wheels have been extremely popular, and for good reason! They look absolutely incredible in all (4) of the finishes.
  4. #564
    Veteran Member Three Rings Ace22's Avatar
    Oct 26 2013
    Ohio
    Quote Originally Posted by Jimminez@Nemesis View Post
    The RS6/7 Performance wheels look so much better than the RS5 ones that look like 5 ladles.
    It appears the RS5 wheel is the same as the RS7 just in 20” vs 22”? The black/polished finish is the same as the RS7, or am I missing something?
    2021 RS7 Unitronic Stage 1+, Akrapovic, Eventuri intake, Performance Wheels, IE lowering links
    2023 SQ8 Stock
  5. #565
    Feb 22 2012
    2017 Audi Allroad, 2018 Audi RS3, 2008 911 Turbo, 1988 911 3.2 Carrera
    CA
    Quote Originally Posted by PartsByTopher View Post
    Any idea what the paint code is for the Neodymium Gold finish?
    Audi Reviews and DIY Guides: https://www.youtube.com/vohoo
    2023 RS6 | AE Goodwood Green | Red Calipers | Cognac | Executive | Driver’s Assistance | Sports Exhaust
    2018 RS3 | Nardo Gray | Black Nappa with Crescendo Red stitching | Dynamic | RS Design | Technology
    2012 S4 Premium Plus | 6MT | Ibis White | Magma Red Silk Nappa | B&O | Rear-side airbags
    2008 911 Turbo Cabriolet | Black | Natural Brown Leather
    1988 911 3.2 Carrera | Guards Red | Black Leather
  6. #566
    Oct 26 2013
    Ohio
    New Performance Wheels installed, will lower at a later date. Will not use spacers for now. Thank you to Chris from Partsbytopher!
    2023 SQ8 Stock
  7. #567
    Sep 29 2008
    Looks great.
  8. #568
    Established Member Two Rings RichardG's Avatar
    Feb 14 2004
    2023 RS6. 2019 RS5 Coupe, 2018 A5 SB
    Phoenix AZ Area
    2023 RS6 Mythos Black | PPF | IE Intake | Cete Active Suspension Control | Cete AVC | 2019 RS5 Coupe Nardo Grey | XPEL PPF | Eventuri | Milltek Non-Res, AVC | BCForged 20x10 | ABT HAS | 034 Adj Upper Control Arms, Trans Mount | ECS Front Strut Brace| IG: @rs4play
    SOLD
    2008 RS4 Phantom Black | Stasis MS | 034 Density adj. Upper Control Arms | StopTech Pads and Rotors | H&R Spacers | ECS Rear Diff Mount | Magnaflow Cat-back | B8.5 Flat Bottom Steering Wheel
  9. #569
    Junior Member One Ring
    Oct 09 2023
    New jersey
    So i browsed this thread and to help some that were questioning this. 295/35/22 will not fit on the rs6. I tried it. The tread rubs against the top of the spindle arm also legitimately 1-2 mm away from the fender liner. Hoping this saves someone the hassle in trying it. I only got one tire and since i have my own tire machine i had to test it.
  10. #570
    Veteran Member Three Rings Maitre Absolut's Avatar
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    Quote Originally Posted by Jacktsai24 View Post
    holy monster truck. why would you go from 30 profile to 35? The 295/35 sits almost an 1.5 inches taller than stock 285-30-22
    When you increase the width you either hold the same profile or decrease it, not increase it
    The correct size for 295 would be to hold the 30 profile
    2023 RS6 | GW / ER | CTS res delete | Ghost links | H&R 10/12
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
  11. #571
    Oct 09 2023
    New jersey
    I live in a very pothole filled state along with recessed manhole covers. I tried to cheat and not lower the car either. Still have to put the kw s on. I went with 295/30/22 s.
    My bentley im running 285/40/19 s and i still bent a rays gramlight wheel on it. With a 40 series tire.
    Just not a friendly low profile state. So whatever i can add to sidewall is gonna help
  12. #572
    Aug 06 2009
    RS6, X3 30e
    Montreal/Toronto
    so you're saying you wanted to fill the gap with sidewall instead of lowering the car? Monster truck tires dont help the look dude.
    If you are afraid of damage just go down to 21s
    2023 X3 30e
    2019 SQ5
    2018 M3 CS
    2017 Macan GTS
    2014 S4
    2009 A3 3.2q
  13. #573
    Oct 09 2023
    New jersey
    The stock audi tires had a stretch to them. Not a fan of that look anymore.
    Already put the 295/30/22 s on.
  14. #574
    Oct 09 2023
    New jersey
    This is how the standard 21’’ s come from factory
    I didnt order my rs6. It was someone else s order and they ended up getting a different car so the rs6 was up for grabs
    This is the comparison of factory 21 standard wheel and tire setup to the tire slightly too big.
    My ‘23 is on DRC. I have the KW s sitting at my shop. Just checking to see how much travel i encounter most of the time and if i need to up the swaybars
  15. #575
    Nov 05 2023
    New Jersey
    Hi all. New to the forums and just picked my 2021 RS6 this past weekend. Absolutely love the car :)
    QQ - been reading through this forum. Would RS7 wheels fit the RS6? Looking at 21x9 ET35. This would be for a winter set of tires. Thoughts? I have an Audi tire and wheel plan so would like to use Audi wheels for coverage of damage.
    Account Terminated One Ring
    Oct 07 2023
    Texas
    Quote Originally Posted by tripitz View Post
    you need to delete your sent messages in the folder so you can get a pm, you're only allowed to send a message 4 times and you've exceeded the limit
  17. #577
    Feb 02 2013
    Quote Originally Posted by voodooboy22 View Post
    I am looking for this as well, if anyone knows!
  18. #578
    Jun 27 2013
    St. Augustine, FL
    Got new RS6-P wheels and Michelin 4S's installed today.
    Stoked! Thanks to Chris from Partsbytopher!
  19. #579
    Sep 29 2008
    Looks sharp on Daytona Grey.
  20. #580
    Veteran Member Three Rings lsondubz's Avatar
    Nov 18 2004
    RS5, M4
    Florida
    Cool
    22x10.5 Incurve Wheels IF3-1020
  21. #581
    Aug 06 2023
    I see some like new Vossen HF-7's on the marketplace in 22x10.5 ET 26. Had them on an SQ7. Is that way too much offset for an RS6? Is that going to have them inward way too much? Only really contemplating if I can get a steal on the price.
  22. #582
    Dec 20 2006
    CAN
    Quote Originally Posted by trivex View Post
    Mine are Vossen HF-7 22x10.5 / 5x112 / ET8 / Super Deep Face
    With ET26 you will be NOT concave and about 2cm closer to the strut. Not ideal imho but maybe you can fix some of that with a 15-20mm spacer.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
  23. #583
    Sep 29 2008
    Anyone using Rotiform AVS wheels?
    These are forged, but says they 36lbs. Guess I’ve gotten use to BBS weights for high end forged wheels.
    Any feedback on their quality, finish and price???
    https://www.rotiform.com/wheel/68552.../?styleID=8027
  24. #584
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    Quote Originally Posted by STALKER View Post
    Check the FB group. There are a few and I’m definitely thinking about them too because of how great they look.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
  25. #585
    Sep 29 2008
    Quote Originally Posted by KRS Aaron View Post
    Thanks but I’m not on FB.
  26. #586
    Jan 25 2011
    Evanston, IL
    It happens. The pic of them on Nogaro on the Rotiform website is what sold me on them.
    M2 CS Racing
  27. #587
    Sep 29 2008
    I think there is a local AE RS6 that runs them in winter. Might try finding the owner online and getting his/her thoughts.
  28. #588
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Quote Originally Posted by Bitdrive View Post
    I picked up my '21 RS6 last week and I immediately found this thread. Your cars are amazing.
    Before the deal was done I fell in love with the Rotiform AVS, I reached out to Martin and he scored up a set, just as Rotiform announced them. He turned them around lightning fast. Thanks Martin!!!
    Attachment 306829Attachment 306830
    are you guys looking for this
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
  29. #589
    Sep 29 2008
    Quote Originally Posted by Gunnarrrrr View Post
    Looks great.
  30. #590
    Sep 28 2010
    NW NC / DE
    The Roti-Spec wheels are great. I've had a 21" TUF set for nearly two years, and we've run the LTN as well. @Jimminez@Nemesis can provide the AVS if needed. 👍🏼
  31. #591
    Sep 29 2008
    Thanks for the info.
    I’ll hit him up for more info.
  32. #592
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    anyone know how much if any difference in height of tires can be run on our rs6's? Would like to run 285/30/22's in the front on 10.5" rims and 295/30/22" on 11' rears. But I'm thinking the awd wont like it.
  33. #593
    Registered Member Four Rings Jimminez's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    Quote Originally Posted by brad65ford View Post
    Why not just run 11” with 295/30R22 up front too?
  34. #594
    May 30 2005
    fl
    Thinking about it more it seems the right direction. Not sure which tires to go with , normally always pick PS4S's as our go to tire. This time I'm thinking I want to change it up, any suggestions?
  35. #595
    Dec 02 2020
    Tampa Bay
    Just as an FYI... Those wheels you got from me are same size as the factory. 22x10.5". The only difference between the factory wheels and yours are the offsets. Both the front and rear are pushed out to have them fit flush without spacers, with the rears being setup to have the appearance of being wider, but they're not. The rear lips are bigger than the fronts.
    But the front and rears are 10.5" and the stock tire sizes, since it's the same width as the factory, fit perfectly.
    23 Cayenne GTS
    21 Daytona Grey RS6 (gone)
    12 Cayman R (PCA GTB1 club racer)
  36. #596
    May 30 2005
    fl
    Thanks Andrew, I thought they were 11" in the rear!!!!
  37. #597
    Dec 02 2020
    Tampa Bay
    No problem. Check out the receipt in the FS thread. It has the exact sizes and offsets if you need them as a reference. Personally, I would run stock tire sizes on that setup. There's no real advantage to going larger and the fit is perfect.
    23 Cayenne GTS
  38. #598
    May 30 2005
    fl
    Quote Originally Posted by DeputyDog95 View Post
    Glad you saw this post lol. Thanks again!
  39. #599
    Veteran Member Four Rings MerlinS3's Avatar
    Aug 04 2010
    2023 SQ7, 2021 Exclusive SQ5, 2022 Exclusive RS6
    Frisco, Tx
    Audi C8 RS6 Avant Wheel Thread
    Not exactly RS6 stuff lol.
    Picked up another set of RS-P wheels in grey and putting them on the new SQ7.
    Now the RS6 and SQ7 will be matching
    Obligatory RS6 picture
    [CENTER]CURRENT | RS6 Avant | Audi Exclusive | Uni Stage 2
    CURRENT | 2021 SQ5 Prestige | Exclusive Paint | Sport Exhaust | Black Optic | Dynamic Steering | Sport Package | BC Forged
    CURRENT | 2023 SQ7 | Stealth PPF | Lowered |
  40. #600
    May 30 2005
    fl
    Anyone know what the stock RS6 22" wheels weigh and or what the stock P-Zero 285/30/22 tires might weight?
