Results 1 to 10 of 10
    Veteran Member Three Rings AudiC7Owners's Avatar
    Jan 14 2016
    Wilmington, NC
    Vibration when turning to the left & decelerating
    Just curious if this issue sounds familiar to anyone.
    I have a vibration that only occurs when my car is on a left hand turn (between 1/2 to a full turn) and decelerating. I feel it if the car is engine breaking, and even more so when I apply the brakes. As soon as I give it gas, it goes away.
    Occasionally I feel it when changing lanes.
    Once, I felt it for about a second when starting the car (car was warm).
    I never feel it going straight or in a turn to the right.
    The sound reminds me of wheel hop mixed with rubbing.
    This started about 4 days ago out of nowhere.
    Has anyone experienced this?
    Sent from my Llama using Tapatalk
    Kwikstix DIY Video Thread
    //2013 A6 Prestige 3.0T |IE Stage 2 Single Pulley | Berk TCU Tune | Injen Intake | Cende Valvetronic Full Exhaust | Gutted OEM Catalytic Converters | Merc Racing HX | H&R Sport Springs | 034 Motorsports Control Arms & Engine Mounts | Eurocode Drivetrain Mount Inserts | Eurocode Front & Rear Sway Bars + End Links | P3 Multi Gauge | StoneCarbon2009 RS Style Grille //
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    Could it be a wheel bearing?
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Junior Member Two Rings Kawasakijim's Avatar
    Nov 25 2018
    Boston
    It does sound like a wheel bearing. I had to replace my front passenger's a while back.
    Jan 14 2016
    Wilmington, NC
    Checked my wheel bearings. No play at all
    Apr 06 2018
    Alberta
    I had a chunk of road grit build up in my rims from freeze thaw conditions, had to physically scrub it off. It behaved exactly like this, car was undrivable at highway speed.
    Jan 14 2016
    Wilmington, NC
    Quote Originally Posted by RattRandee View Post
    When I'm going in a straight line I have zero issues. Only at low speed in a left turn while decelerating.
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    I say lower control arms
    Jun 02 2019
    Danville, CA
    Quote Originally Posted by 430hps4 View Post
    I highly doubt it I'm pretty sure this is the c7 owners guy and he's done a video on using density line control arms so unless they're already worn out no way
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    id look into axle i had this issue on my b5 s4 and was that
    Jan 14 2016
    Wilmington, NC
    Figured it out.
    Part of my mid muffler was rubbing a heat shield underneath when I got into a hard left turn.
    We adjusted everything & the vibration is gone.
