Results 1 to 12 of 12
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    Is it possible to disable AFS (Adaptive System) on Headlights in VCDS
    I purchased some aftermarket Matrix LED Headlights for my S6
    I bought it from china and they sent me the version with no AFS but my car does have AFS so I get an error.
    Is there a way I can disable the AFS function? They said they cannot send another harness. they gave me wiring instructions to fix it but it did not work and they are really hard to get a response from. I rather disable it completely at this point
    Headlights work great but
    The passenger headlight will flicker the DRL when headlights are on to indicate that theres an issue. It also gives an error on the dash. this is the VCDS code
    01771 - Control Module for Headlight Range (J431)
    008 Implausible Signal
    the cluster says " Audi Adaptive Light System Fault"
    Please let me know if theres coding I can do to fix it. thank you!
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
    Mar 11 2007
    Colorado Springs
    I don't think so.
    There are two distinct part numbers. You will not be able to dial-out the AFS. I'm not 100% on this but I'm pretty sure.
    edit :<I bet if you changed the wiring harness and some coding, you could use the non AFS headlights>
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Jun 28 2019
    California
    Quote Originally Posted by A6sport View Post
    I don't think so.
    thats unfortunate. I tried t see if they could send me the correct ones they swore there wasnt different ones. I may have to purchase the correct ones from another source and sell these to someone without AFS
    IG:@stolens6
    Established Member Two Rings orphancrippler's Avatar
    Aug 01 2020
    2018 Nissan Rogue SL, 2016 Nissan Rogue SV
    Telford, Pennsylvania
    You may want to check this out Disable AFS
    Steps may be a tad different in newer VCDS, but the result should be the same. Hope this helps!
    Sent from my Galaxy S20 Ultra 5G
    2017 S6 DS1/SRT Custom ECU+TCU "Deathstroke the Terminator"
    SRM +4mm, HPA Street DPs, APR Catback w/X-pipe & 4" Tips, APR HX, MercRacing IC Core, SRM Short Intakes, AWE S-Flo V2, SRM Dual LPFP, Autotech Plungers, SRM FF Sensor + Engine Lines, 4 Bar MAP + Boost Sensors, TiAl WG Actuators, EMP Pump, JHM Oil Screen Kit, 034 Rear Swaybar/Endlinks/Drivetrain Inserts, SRM Driveshaft Carrier, iO2 CatSims, CF Spoiler + Mirrors, RS-Quattro Grille, Black Badging, CeramicPro Gold, 20mm R/17.5mm F Spacers
    Jun 28 2019
    California
    Quote Originally Posted by orphancrippler View Post
    Love the futurama reference lol but yeah I tried some things in that thread. Didn’t work. Going to Reanalyze the steps and try to adapt it to the new VCDS again. Thanks!
    Aug 01 2020
    Quote Originally Posted by Audibellybutton View Post
    Thanks! Very few people seem to recognize that it's a reference.
    What particular step(s) were you having issues with?
    Jun 28 2019
    California
    LOL without knowing the Futurama reference it sounds crazy
    Anyways I tried the steps, similar but without pulling the fuse. dont know where its located. didnt know if I needed to for mine. but I will find it. and try everything again with that fuse removed as well
    IG:@stolens6
    Aug 01 2020
    Hahaha yeah I can definitely see how someone would be like "WTF.......?"
    Pulling the fuse is essential to the process, or otherwise disconnecting the system. I'm sure there is another way to do it, but pulling the fuse removes all power from that module, achieving the goal without having to unplug connectors that are probably buried deep in the dash or elsewhere.
    All the coding is doing is telling the car not to expect the system to be there, so that when it is powered down, the car doesn't go nuts thinking there is an error or malfunctioning component.
    I'll see what I can do to help you locate the fuse, and we can go from there. We'll figure it out one way or another!
    Jun 28 2019
    California
    Currently struggling to find out what fuse(s) to pull on my C7 S6 lol let me know if you do know I haven’t found any diagrams that list it. I’m not sure the exact name of the function either haha
    Aug 01 2020
    So it looks like there is one fuse in the passengers side box and one in the drivers side for the actual headlight electronics, and then you also need to pull the one for whatever the main system is which I believe is information electric or possibly central convenience, but probably the former. I will try and find more specific information for you. Just so I'm 100% sure, what exact year and model/trim are we talking about?
    Jun 28 2019
    California
    Okay I’ll try to look as well
    I have a 13 s6 prestige. Had standard looking headlights not the full LED but apparently the ones I had have AFS too
    Aug 29 2017
    Sydney
    Hi @Audibellybutton
    Just wondering if you were able to get your headlights working after pulling the fuse for the AFS and codiing it out?
    I haven't been able to find an AFS replacement headlight (they are scarce, particularly for right hand drives) - but if I can replace with a non AFS, and get a working light (I don't care about the AFS), then there's plenty on offer.
    Thanks in advance
