Results 1 to 9 of 9
    Junior Member One Ring
    Dec 15 2018
    BMX Bike
    Flower Mound Texas
    VCDS from Total Car Diagnostics
    Has anyone bought the vag com tool from Total Car Diagnostics ? I have the loose steering issue in my 2014 S4 and want to deselect the DSR feature to fix it. Before I buy from Total Car Diagnostics, I want to be sure it works. Thanks for your help.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Seems legit, but I don't know if it is eligible for the RossTech software updates which happen several times a year.
    I doubt you can be a registered RossTech user for their free technical support. The support alone has been worth the extra $100.
    I had an error code on the steering angle sensor that required both calibration and module recoding to be able to use launch control on my supercharged Q5 3.0. This loss of launch control and the related soft code happened shortly after I was out of warranty. This issue required research by RossTech tech staff and personal direct recoding instructions. Just changing a single digit in the code fixed the problem. The dealer wanted to charge me $600 for a new module, plus labor to install it. With RossTech VCDS and their tech support, the fix cost nothing.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Dec 15 2018
    BMX Bike
    Flower Mound Texas
    Thanks for the response. I found another thread and everyone recommended Ross- Tech just like you. I will go that route.
    Mar 05 2016
    Quote Originally Posted by MSq5 View Post
    I had an error code on the steering angle sensor that required both calibration and module recoding to be able to use launch control on my supercharged Q5 3.0. This loss of launch control and the related soft code happened shortly after I was out of warranty. This issue required research by RossTech tech staff and personal direct recoding instructions. Just changing a single digit in the code fixed the problem. The dealer wanted to charge me $600 for a new module, plus labor to install it. With RossTech VCDS and their trch support, the fix cost nothing.
    I bought a second hand RossTech cable, am I eligible for the RossTech free technical support or it’s only for original owner?
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by TC_S4 View Post
    Don't know. Check with them. Might have to re-register and pay $99. They have to verify sale from original registered owner (to stop possible use of stolen devices, cloned devices and Chinese rip-offs). This link may be useful:
    https://store.ross-tech.com/shop/VUDOT/
    May 02 2020
    melbourne australia
    i bought the cable from total car diagnostics a few years ago
    they send a link to download programme works great
    but as you thought there is no upgrade
    if you try to upgrade you will lose your programme
    for only roughly $100 is still a very cheap option that will work
    for nearly everything you need
    Mar 05 2016
    Quote Originally Posted by jasonj1965 View Post
    If you can’t upgrade the software as RossTech rollout a new version, what make this cable of 100$ different from 20$ cable from Ebay or Alibaba? I see their website seems pretty professional, but it’s still not a legit RossTech cable. It might be the same dude on eBay selling 20$ and selling the same cable 100$ on Total Car Diagnostics 😲🙄
    May 02 2020
    melbourne australia
    it’s not the cable that is the issue it’s the programme that you are paying for
    Mar 05 2016
    The RossTech cable has a serial number that VCSD recognize, as soon you are connected to the net and the cable is plugged to a computer, it will automatically prompt you the download and updated vscd. At least, that what happen with the second hand RossTech cable I bought. So no it’s not the program you bought but the cable that’s important.
