Results 1 to 3 of 3
    Junior Member Two Rings Avantgears's Avatar
    Jun 02 2019
    91' Jetta Coupe 20VT project
    rough idle on cold start
    So 2.0T Quattro 6spd has a rough cold start issue, where it bucks and chugs... Till it's about 30ish degrees on coolant temp, or before with holding revs around 1000 for min of two ... only when it's cold out
    237xxx km
    Plugs are new
    PCV new and hoses
    Carbon clean done
    Valve cover gasket new
    Next to do soon here is rear timing chain and tensioner.
    No codes, no history or pending codes
    Senior Member Two Rings BradyBoi55's Avatar
    Apr 19 2020
    1994 Ford F-150, 1931 Ford Model A, 2007 BMW 650i
    Manchester/NH
    Cars definitely act weird when it is cold and on cold starts. Our cars especially. Cars are designed to run at operating temperature. Where the metal is expanded and all fluids are heated. Best thing to do would just be to wait until the car is warm before driving it.
    2010 Premium Plus b8 A4 Avant
    Senior Member Two Rings ROH ECHT's Avatar
    Jul 20 2011
    PNW
    Do you only have a code reader or do you have VCDS?
    K04 PLAY...`07 GTI/GIAC H.O. K04 & DSG tunes/Autotech HPFP/S3 INJ./S3&FORGE FMIC's/TECHTONICS TurboBack/AWE DV/Whiteline Performance springs & W.A.L.K./BSH MOUNT's/NEUSPEED INTAKE&THROTTLE BODY/ECS ST3 BBK/H&R RSB&FSB Voting for my Dragtimes; 2007 Volkswagen GTI : 12.823 @ 112.050 MPH...ZOOM DIS!
