Results 1 to 6 of 6
Hybrid View
    Nov 28 2015
    Flemington, NJ
    Fuel fill restrictor removal?
    So recently bought a new to me 2015 Q5 3.0t. I’ve had many Audi’s before but none with the fuel fill restrictor on my vehicle.
    Can this be removed? I clearly know not to fill my vehicle with diesel. It’s more annoying than anything else. I don’t want to remove it if it will cause a problem or ruin my filler neck.
    Anyone ever remove it? Break it out being sure not to drop any in the tank?
    Current:
    2015 (B8.5) Q5 3.0t Premium Plus
    2013 (B8.5) A4 - 2001 (B5) A4 - 2004 (B6) S4 - 2001 (B5) S4 - 2007 (B7) A4 - 2001 (B5) A4
    Jul 31 2016
    PA
    Haven't really seen it mentioned other than some modification for the TDI someone did not long ago? What's annoying about it? I've never really even taken note of it before.
    I'm guessing you'd need to either drill it out or take something apart to get to it but need to be careful not to get plastic pieces in the tank. Seems like a lot of effort for no real benefit.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Nov 28 2015
    Flemington, NJ
    Sometimes the pump doesn’t go right in. I don’t want to have to precisely put in the nozzle when I can just slap it in and pump away. More of a convince factor than anything else.
    Current:
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I think that restrictor plate or flap is there to prevent unauthorized siphoning of your fuel (theft), and as a part of the emission system to reduce evaporation loss. Yes, will stop a diesel nozzle, too. As long as you can get the gasoline nozzle past it, I'd leave it alone.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 31 2016
    PA
    In the 5 years I've owned mine, I've never had an issue with the nozzle, though this isn't the first time I've see this. I wonder if some were just off from a tolerance perspective.
    I looked through the factoryanual quick and didn't really see anything about removing that piece, just the fuel door trim components.
    Nov 28 2015
    Flemington, NJ
    Quote Originally Posted by djn876 View Post
    That’s what I’m thinking. Being slightly off spec wise. I too have searched high and low for this part on all databases. Came up with nothing. Must be part of the fuel neck assembly.
    Oh well. Guess it’s staying in there. Thanks
    Current:
