Help ! I just got the following in the mail today=>
https://www.aliexpress.us/item/32568...andl_shipto=US
If you click on the link then there is a box that has the more expensive version ~175 USD on it, thats what I got.
Will this work on a 2019 B9 S4 ? Also is this the version with the gmeter ? Before I rewire things I want to be sure.
Thanks to the community for any advise
Update 1 :
I’ve wired based on the previous posts my colors were a bit different.
Now I cant start a car is the best guess is I blue a fuse , ar ethere extra fuses in the fuse box ?
(Previous post/Actual/Manual in Chinese):
Rainbow Box RPM Module from Audizine
Orange&Brown wire - Pin31 (confirmed/same)
Orange&Blue wire - Pin13 (Purple 13/purple)
G meter:
Grey wire - Pin49 (Red/white)
Orange&Brown wire - Pin48 (same/same)
Powering:
Red&Blue wire - Pin18 (confirmed/red)
Brown wire - Pin54 (confirmed/same)
UPDATE 2:
I switched out the 10 A fuse for one 2 down which I think is for the rain detector and car starts !!
Through every error in the book like It did when I tued 034 ecu/tcu, including adaptive suspension error.
I executed the neutral, left turn signal return fix and it worked. Now my obdeleven wont light up in any state …..
I know the gmeter works but cant code the rest, might need to by new obdeleven ?
Update 3: I’ve got my obdeleven working longcoded for acceleration and engine displays and I can see them !
Still no rainbows or rs logo. Instead of hitting the x61 i changed from 12 to 13 variant B9 S4 to B9 RS4 …. Nothing yet
Update 4: i went out to ziptie the box and noticed it had a green light on it. Closed up the backseat, turned it on and wow !!! RS4 logo and rainbow !!!! Havent checked out the torque to make sure they go all the way up and not just 86% will try that out tomorrow
