Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 129
  1. #41
    Senior Member Four Rings
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by cthan3o3 View Post
    Did you have to request the new version from the seller? I can’t tell which ones are the new versions that make the G-Meter work
    Yeah - so if you message the vendor and ask for the g meter they'll tell you to buy the standard one but then send you the newer Pro module.
  2. #42
    Established Member Two Rings cthan3o3's Avatar
    Mar 11 2011
    Colorado
    Installation guide for activating RS Engine Data and Shift Lights on Virtual Cockpit
    Quote Originally Posted by Kondax View Post
    Have they sent you installation instructions? Curious which pins need to be removed with the updated module.
    The older version I just installed did not come with instructions, I had to rely on this thread and Yaode Chen’s video
  3. #43
    Apr 26 2019
    United Kingdom
    Not yet but they've said they will provide them for me.
  4. #44
    Mar 11 2011
    Colorado
    I just installed the “Pro” version of the Rainbow module. G-meter works now but I’m getting a Suspension Malfunction error. May revert back to the old box if I can’t get this figured out.
    UPDATE:
    Just spoke to the seller. Anyone with Adaptive suspension will trigger this Suspension Malfunction fault. Others without Adaptive Dyanmic suspension will not. Guess my “Pro” version will be for sale soon :(
  5. #45
    Nov 03 2016
    CA
    Just noticed on my 2020 S4 that the torque gauge only goes up to 86 percent under full throttle pulls. Power gauge reaches 100 percent?
    Can anyone else share? I do have the APR tune.
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
  6. #46
    Mar 01 2021
    GLC300, CL600, Tundra, Tercel
    Miami, FL
    UPDATE:
    Just spoke to the seller. Anyone with Dynamic suspension will trigger this Suspension Malfunction fault. Others without Dyanmic suspension will not. Guess my “Pro” version will be for sale soon :(
    Let me know, I have been wanting to grab one of these and I have the base suspension.
    '21 S4 Navarra/black, EMD springs, 12mm spacers
  7. #47
    Junior Member Two Rings
    Jun 13 2018
    Colorado
    Anybody buy theirs from Yaode Chan vs Alibaba? Any idea if there are any quality differences? Not sure if they’re all the same or there are slight differences. I was chatting him on IG on the regular and G-meter versions he can get. He hadn’t heard about the suspension malfunction yet, but had only sold a few so far. Really want the Pro version, but don’t want a fault either. Can the OBD11 get rid of it?
  8. #48
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by ukan16 View Post
    I was actually the one who told Yaode about the pro version.
    I'd recommend just getting it from Alibaba, it's cheaper. Yaode is good and provides some support but he's just adding his own markup to the items.
  9. #49
    Mar 11 2011
    Colorado
    According to the seller I chatted with, if you have the Adaptive Suspension, then you will get the fault no matter what.
  10. #50
    Dec 26 2020
    Staten Island, NY, USA
    I recently installed the Rainbow box, not the pro. I'm having a hard time getting the RS mode on?. Vehicle variant is at 14 right now and it's not working. I'm using OBD11 as my tool. Thank you guys
    UPDATE: I guess you have to leave the car for 10 mins or so for the vehicle variant mode to kick in. I left it overnight and when I started the car, it says RS4 on the dash and I have the shift light working.
  11. #51
    Nov 03 2016
    CA
    Quote Originally Posted by brilliant_black View Post
    Can someone do a full throttle pull and see if the same thing is happening to them? My torque gauge only gets to 86 percent while the power gauge goes full 100. My car drives just fine and I don't feel its down on power or anything. I have the apr tune.
    2011 Audi S5
  12. #52
    Junior Member Two Rings jas9's Avatar
    Dec 28 2020
    Orange County, CA
    I just installed the sport box pro and there are two additional wires to connect for the g-meter to function. Here is the full list:
    RPM Module:
    Orange&Brown wire - Pin31
    Orange&Blue wire - Pin13
    G meter:
    Grey wire - Pin49
    Orange&Brown wire - Pin48
    Powering:
    Red&Blue wire - Pin18
    Brown wire - Pin54
    Thanks [mention]Kondax [/mention] and [mention]cthan3o3 [/mention] your guides were extremely helpful.
  13. #53
    Apr 26 2019
    United Kingdom
    Thanks for updating us with the additional wire connections. Glad my post helped out!
  14. #54
    Sep 16 2006
    2001 Audi S4
    VA
    Quote Originally Posted by jas9 View Post
    RPM Module:
    G meter:
    Grey wire - Pin49
    Powering:
    Brown wire - Pin54
    Do you have adaptive suspension?
    Sent from my iPhone using Tapatalk Pro
  15. #55
    Dec 28 2020
    Orange County, CA
    Quote Originally Posted by oxxomxxo View Post
    No adaptive suspension
  16. #56
    Veteran Member Three Rings K1196A's Avatar
    Feb 16 2007
    B9 S4, 2018 Q5, 2012 Tacoma TRD Sport
    DOVER, PA
    I was going to get one of these until the notice was posted about a non-resolvable error code related to adaptive suspension. Reading that saved me the $200 and the aggravation! It's a shame though because I really wish that I could have got that set up.
  17. #57
    Dec 28 2020
    Orange County, CA
    Quote Originally Posted by K1196A View Post
    For adaptive suspension you will need the non pro variant. Luckily, these can be found for cheaper than the pro and 2 less wires to install.
  18. #58
    Feb 16 2007
    DOVER, PA
    Isn't there some functionality/features missing between the two?
  19. #59
    Dec 28 2020
    Orange County, CA
    I believe the g meter is the only missing feature.
  20. #60
    Feb 16 2007
    DOVER, PA
    That's right... TY! I wanted the pro version because I wanted the full functionality, but I can't have it without the error code so it just makes sense for me to pass.
  21. #61
    Jun 14 2018
    Dallas/TX
    I do have a APR tune on my 2018 S4. I have same problem like you! I was not alone lol
  22. #62
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by myleehwa View Post
    This is probably due to how APR have bypassed the factory torque limits in the ECU and would require them to fix it on their end. I can't see them doing this though.
  23. #63
    Dec 15 2020
    Romania
    I have APR Stage 1 93 Octane on my 2018 S5 Sportback and I don't have this issue.
  24. #64
    Established Member Two Rings TGabriele's Avatar
    Jan 08 2007
    Any indication that they can get the g-meter working with the adaptive suspension in the future?
  25. #65
    Junior Member One Ring
    May 06 2018
    Glen Burnie, MD
    I have the 034 ECU/TCU 93 octane tune - same issue: torque gauge maxes out at 86%.
  26. #66
    Established Member Two Rings Rad_Logan's Avatar
    Apr 26 2016
    B9 Q5, Mk3 Jetta, First Gen. Cummins
    Portland, OR
    Quote Originally Posted by TGabriele View Post
    Same question. I have a 2021 S5 and really want to add this but only if I can get all features to work properly.
    Thank you everyone who made this thread, very helpful
  27. #67
    Dec 15 2020
    Romania
    Quote Originally Posted by JasonKrywicki View Post
    Had the same issue and the vendor sent me these instructions
  28. #68
    Mar 11 2011
    Colorado
    Quote Originally Posted by s5.project.2020 View Post
    Did it work? Is the ‘return’ button the one with the arrow below ‘view’?
  29. #69
    Apr 26 2016
    Portland, OR
    Yes.
    I'll provide the wiring and coding info for the Pro version once I've got it.
    Any fix for those of us with adaptive suspension on the Pro version?
    Has anyone run this on a 2021 b9.5 post facelift car? Furthermore 2021 s5?
  30. #70
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by Rad_Logan View Post
    Not that I'm aware of. I didn't get the pro in the end as it causes issues with the OBD port, and makes it unusable if you don't have your hazards on.
  31. #71
    May 06 2018
    Glen Burnie, MD
    Did anyone ever get this to work? I tried what I think it was describing and nothing happened.
  32. #72
    Apr 26 2016
    Portland, OR
    Besides this Rainbow Box, has anyone looking into the factory options that give these abilities to the RS cars? Is there a factory RS module that does this same thing? Just curious how the RS cars can do this factory, but for “A” & “S” models you need a non factory module. Just curious.
  33. #73
    Jan 26 2022
    UK
    UPDATE:
    Just spoke to the seller. Anyone with Adaptive suspension will trigger this Suspension Malfunction fault. Others without Adaptive Dynamic suspension will not. Guess my “Pro” version will be for sale soon :(
    Are there any updates since May Last year was the issue fixed with Adaptive suspension and "Pro" version any work arounds?. I had to cancel my order on aliexpress as I didn't want something which will not work 100%.
  34. #74
    Jul 18 2021
    2021 Kia Telluride
    Clemmons, NC
    Quote Originally Posted by Ic3m4n View Post
    I found one that has this picture noting the fault code and a way to turn it off. I messaged the seller, but basically got an out of office message for the Chinese New Year.
  35. #75
    Jan 26 2022
    UK
    In the image its mentioned about electromagnetic suspension which I believe A8 have not S5 B9. I've messaged them also but have to wait past 8th of Feb.
  36. #76
    Jul 18 2021
    2021 Kia Telluride
    Clemmons, NC
    Oh okay, I wasn’t sure if the adaptive suspension on the S4 was the same and they were just calling it something different. I’d really love for this to work for us too!! I might just bite the bullet and get the non pro version.
  37. #77
    Nov 20 2021
    United Kingdom
    I haven't seen any reports of people successfully using the pro without some sort of issue.
    Even if you manage to sort the adaptive suspension issue, good luck using your OBD port unless you have the hazards on.. makes datalogging, tuning, and running a P3 guage incredibly tedious.
  38. #78
    Jan 26 2022
    UK
    Quote Originally Posted by AldermanToffee View Post
    This is the answer from seller on AliExpress "Hello. Suspension system failure. Match as in the comments. Can be solved." this is one of the comments "I can confirm The G Meter Pro version worked on my 2018 FY SQ5 with air suspension. The seller is really great and helped me with the installation. Just a heads up If you buy this with an air suspension car, there will be a air suspension fault and it’s normal. To get it working you need to this.. 1. turn your car on and put it in NEUTRAL 2. Turn your left blinker on 3. Press and HOLD the return button on your wheel for around 15 seconds. While you’re holding the button after 15 seconds the needle will automatically point to 1400RPM when you let go the car is coded to no show the suspension fault. Enjoy! G Meter works, Rainbow works and Torque/ Power works! 12 Aug 2021 05:55"
    I think I will bite the bullet and buy the pro and see what's what with it. Will report back in around a month or so.
  39. #79
    May 06 2018
    Glen Burnie, MD
    Does anyone know if there is a similar procedure for the non-Pro box to fix the torque gauge maxing out at 86%?
  40. #80
    Nov 20 2021
    United Kingdom
    Keep in mind that despite having overcome the suspension issue (in theory), you'll still run into the OBD issues I mentioned above.
