Edit: Prices updated to show true price without the VAT tax
So, I just had the new upgraded clutchpack from TVS Engineering in the Netherlands installed on my 2016 S6 this past week. I had significant clutch slippage in 4th gear during 4th gear pulls, which is why I had it done. TVS alsp has a good track record with DSG clutches for VW/Audis, a reason why I went with them.
This clutch pack is rated for 1000 nm (737 ft-lbs of torque), compared to OEM, which is rated for 800 nm (589 ft-lbs).
I also had the TVS TCU tune remotely installed, as they will warranty the clutch pack if you have a TVS dealer do the installation and if you use their TCU tune.
First, off, driveability during normal driving is outstanding- I'd say even better than OEM- none of the jerkiness I'd often experience in the lower gears.
Like most TCU tunes, you can have custom shift points made for any of the gears and even have them separate from manual vs automatic gear shifts. You can also have them change launch control rpms easily.
Just as important to me, I'm not experiencing any clutch slippage during 4th gear pulls.
I still need to have custom ECU tuning completed now that I can actually log 4th gear pulls.
I had Achtuning, in Redmond WA do the work, as they are a TVS dealer and are great to work with.
The clutch pack itself is expensive, (right at about $3,020), and the TCU software is extra ($1502).
Labor depends on whether you are also adding anything else. I also had a new mechatronic unit installed, so total labor came out to 17hours.
I'll post back more when I get a chance to do more pulls and get the ECU tune dialed in, and also have a chance to see how launches go as well as 1/4 mile times. I currently only have OEM RS7 turbos, but plan on upgrading these in the future. I have DS1, upgraded inlets and air intake, as well as AMS intercooler and downpipes, Tial wastegates, upgraded fuel lines, 4 bar MAP sensors, and currently running e50.
I know several users on here have had tough experiences with DEKA clutch packs, and I know SRM (where I've sourced many of my upgrades, and who is working on my ECU tune) has an upgraded clutchpack in development, although I don't think yet ready for retail just yet.
I'm not looking to set any records, just looking to make the car both repeatedly and reliably powerful/fast, and hoping to have hp in the 700's and torque in the 700's, but still have the car with good driveability on the roads in normal conditions.
https://tvsengineering.com/en/perfor...rbox-hardware/
