Results 1 to 6 of 6
Threaded View
    Jun 06 2017
    Connellsville PA
    Transmission Malfunction Codes and Related Issues
    Hey everyone, first off, thanks for looking.
    Backstory:
    Bought our 2013 Q5 3.0T Premium Plus S-Line 3 years ago. (01/2018). It had 99k miles on it at purchase. (Unknown to me if the OEM trans fluid was changed prior.)
    Drove the car and loved it for the past 3 years.
    Recently we have started to develop transmission issues and ended up buying a 2019 Q3. To keep the story short, it's quite lackluster going from the 3.0T to the 2.0T. My wife primarily drove the Q5, and it was our family vehicle. I travel out of town for work so I can't risk her being in a vehicle that would potentially leave her and my children stranded somewhere.
    So here's the current issue.
    When starting the vehicle, and this seems more prevalent when it's cold, if you shift to drive or reverse, the transmission doesn't engage though the MMI shows it as such. Putting it in D, sometimes it will show it shift directly to 3rd gear (I have the gear display enabled in vagcom). The car sits still as if it's in neutral.
    Also, we would get error messages saying "Transmission Malfunction. Limited Driving Functionality" followed by "Transmission Malfunction. No Reverse Gear Available."
    The only way to resolve the issue was to shift to park and shut the vehicle off. Upon restarting, 90% of the time it is fine. More recently it has continued to act up more and more though, with the above errors and issues repeating themselves 4-5 times before being resolved by shutting it off and restarting. (EDIT: It only ever does it when cold, only in our driveway. Never once when it was anywhere else, only after it sits overnight and on the first initial start up after an extended time of being parked. We have a remote start installed and used that a lot to start it and get it up to temp, and that seemed to alleviate the issues for the most part.)
    It's also important to note that the car currently has 133k miles on it, and at around 130k miles I did a transmission fluid change and filter change. We were getting the occasional rough shifting when cold and that was about it. The error had occurred a few times prior to the fluid change but now it is coming back more and more frequently. I had used the Liqui-Moly fluid and Meyle filter available in the trans service kit from ECS. Now I'm slightly regretting that decision, curious if it has caused more issues than good.
    Upon scanning with vagcom, the following automatic transmission codes were present. (I have the full scans available on my laptop if anyone would like to help and see them, I'm posting from my phone currently and retyping the info.)
    3 fault codes found:
    -P2701 Transmission Friction Element / Clutch B
    -P0730 Incorrect Gear Ratio
    -P0780 Shift Error
    I have searched and tried reading what I could about these three codes in conjunction with the ZF8 transmission but with no luck specifically to those codes especially together and in any way related to the Q5 platform.
    Lastly, for fear of potentially overfilling the transmission, I jacked the vehicle up and got it to 40°C and pulled the plug on the trans to check the fluid level. Only about half a cup of fluid came out, but what did had what looked like a fair amount of metal shavings in the fluid. I'm afraid that either the new fluid agitated the metal shavings that were potentially trapped in the transmission and dislodged them, causing more issues, or that not using the ZF LifeForce 8 fluid and instead, the Liqui-Moly version had caused issues.
    Ultimately, the vehicle was set to be traded in, and I opted not to as I still have a loan out on the vehicle. I daily a B8 A4 and would prefer to sell the A4 (which is paid off and would cover the remaining amount due on the Q5) and keep the B8.5 Q5 if possible, but fear there's too much transmission damage done already. Im fearful of needing to sink $2-$3k into buying a used transmission/having our transmission rebuilt for a vehicle only worth around $8k currently. My A4 is bagged and I had planned to swap the airride to the Q5 and drive it to and from work instead.
    Does anyone have any experience with the codes above or knowledge about similar transmission issues/failure? What would you do if you were in my shoes?
    Sorry for such a long post. Anyone who read it all, thanks for reading. I genuinely appreciate any help I get.
