Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
  1. #41
    Jun 27 2011
    B8 S4 seats into B7 Wiring Diagram
    I’ve got 6 on the b8 passenger black plug. Only 5 plugged in to my b7 though. The red one I left hanging though it’s taped up so not shorting or anything.
    Yea I’m really baffled by this issue. I’d ignore it but it’s keeping my airbag light on and that really bugs me.
    Edit: shot in the dark, but maybe the red wire needs to be grounded?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  2. #42
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Na, I didn't use the red wire either.
    Sent from my LM-G710VM using Audizine Forum mobile app
  3. #43
    Jun 27 2011
    Huh. I might pull the seat and inspect my wiring then and make sure nothing is shorting and that the wires in the seat aren’t damaged then. Sounds like it’s probably not an issue with my work and possibly a wiring issue I overlooked elsewhere in the seat then. The seat module itself doesn’t require coding right? Just trying to eliminate all causes here…
    -CP
    2017 Q7 3.0t
  4. #44
    Jan 21 2018
    frackville, pa US
    No, I just swapped mine, no coding. I have thr b8 plugs downstairs, I'll takr pics. I didn't re-pin, I cut and spliced the wires. So the plugs still have length of wire on them. Just to compare, see what varies between you seats and s4 seats. Maybe it'll help?
  5. #45
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    I’ll be swapping S4 B8 seats in to S4 B6 tomorrow.
    This still valid ?
    Good I don’t have occupancy sensor so nothing to swap over.
    A bit different but related topic, is there a DIY for the rear seats ?
  6. #46
    Jun 27 2011
    Just to close the loop on the issue I was having: big thanks to Jay for clueing me in that the b7 passenger seat occupancy sensor has to be swapped into the b8 seats. I no longer had mine as I sold my seats but I found on one eBay for $35.
    The module was plug and play, just had to run a Basic Settings procedure on the occupancy module in VCDS, clear codes, and no more airbag light. So glad I got that dealt with. The airbag light was grating on me having to see it lit up all the time.
    -CP
    2017 Q7 3.0t
  7. #47
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    Switched mine out over the weekend from my old seats. 8E0 Rev B for mine and 8K0* was on the B8. Didn't need to remove seats, re-adapted, and so far no code. 👍
  8. #48
    Jun 27 2011
    I installed an 8E0 Rev D model in mine. It was from an ‘08 and my b7 is an ‘08 so I figured it might be “more better” and the rev B. Probably doesn’t matter…
    -CP
    2017 Q7 3.0t
  9. #49
    Veteran Member Three Rings mr_Law's Avatar
    Feb 13 2014
    bronx ny
    Quote Originally Posted by xRenesis View Post
    Just changed the sensor. What do type in for the readapt?
  10. #50
    Jun 27 2011
    In VCDS you need to log in to the security settings in the airbag module (use the Bosch code in the tooltip) then go to basic settings and select occupancy sensor basic settings from the drop down, then click Go/start/next or whatever it is in the top right of the window. You’ll see the data in the fields change. Then click that top right button again to stop the adaptation then click close the basic settings window. Should be good after that. You’ll probably have to clear codes too.
    -CP
    2017 Q7 3.0t
  11. #51
    Jan 14 2015
    South Dakota
    If you look up nicks4, his was re-apating Recaro, but same process.
    [Select]
    [15 – Airbags]
    [Security Access – 16]
    Enter 30475, to enable the basic setting.
    If you are having problems performing this security access, contact us.
    [Do it!]
    [Basic Settings – 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The reset has been performed.
    [Done, Go Back]
    [Close Controller, Go Back – 06]
  12. #52
    Jun 27 2011
    ^^ yea that’s it. Thanks!
    -CP
    2017 Q7 3.0t
  13. #53
    Jun 10 2013
    United States
    Did you swap just the occupancy electronics module or the entire bladder and module?
  14. #54
    Jun 27 2011
    Quote Originally Posted by glennda5id View Post
    Just the module, the existing bladder is plug and play with the B7 module.
    -CP
    2017 Q7 3.0t
  15. #55
    Jun 23 2008
    Reviving an old thread. B8 S5 seats into my B7 A4.
    Swap went great, except Airbag light.
    Spoke to Jay too (he is awesome), told me a B7 A4 passenger seat occupancy sensor is needed to be swapped over to the B8 seats.
    Have CODE 02511 ONLY.
    Bought a 2007 Audi A4 Passenger seat occupancy sensor off Ebay for $40.
    Swapped right over, did the re-adaptation steps outlined below and STILL HAVE THE AIRBAG LIGHT! Any ideas? Jay has been awesome with help as well; anyone else have ideas?
    Basic Setting
    Seat Occupied Recognition Control Module (J706)
    If the Seat Occupied Recognition Control Module (J706) or the seat itself have been replaced, the basic setting has to be performed.
    [Select]
    [15 - Airbags]
    [Security Access - 16]
    [Do it!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    [ON/OFF/Next]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Special Procedures
    Seat Occupied Recognition Control Module (J706): Reset
    If a repair on the Seat Occupied Recognition has been performed, a reset has to be performed too.
    Prerequisites:
    Seat in normal position.
    Seat must NOT be occupied during the whole procedure.
    Seatbelt must NOT be plugged in.
    No faults in the system.
    Interior temperature must be between 0 °C and 37 °C (32 °F and 98 °F).
    [Select]
    [15 - Airbags]
    [Do it!]
    [Adaptation - 10]
    Channel 000
    [Read]
    [Save]
    [Done, Go Back]
  16. #56
    Jun 27 2011
    Edit: misread, nevermind.
    What codes do you have? Just adding the proper controller and recoding it solved my airbag light.
    -CP
    2017 Q7 3.0t
  17. #57
    Jun 23 2008
  18. #58
    Established Member Two Rings hectorrocha1's Avatar
    Jul 18 2022
    California
    Can someone describe how to swap the passenger occupancy sensor or the module. Everyone says to simply swap it over but not what it is, where it is, or how. Is it simply plug in play?
  19. #59
    Jul 18 2022
    California
    I’ve also seen one thread saying that you have to remove the memory control harness and unit from the S4 seats before installing, even if you don’t have memory seat in your b7
  20. #60
    Jan 14 2015
    South Dakota
    When you look under and at the bottom of the seat, you should see either a black or grey box that you swap over
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
  21. #61
    Jul 18 2022
    California
    Just swapped the magma red s4 seats in my b7. I see what you meant about swapping the occupancy module, I was overthinking it. It was beyond easy. Thanks man.
  22. #62
    Sep 19 2023
    Cali
    In VCDS you need to log in to the security settings in the airbag module (use the Bosch code in the tooltip) then go to basic settings and select occupancy sensor basic settings from the drop down, then click Go/start/next or whatever it is in the top right of the window. YouÂ’ll see the data in the fields change. Then click that top right button again to stop the adaptation then click close the basic settings window. Should be good after that. YouÂ’ll probably have to clear codes too.
    Reviving a revived post, anyone know if you can reset the occupancy sensor using OBDeleven?
    Or some other less expensive OBD2 interface.
  23. #63
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by b7sticky View Post
    Should be able to..
    Sent from my LM-V600 using Audizine Forum mobile app
  24. #64
    Sep 19 2023
    Cali
    Alright, gonna give it a shot. I’ll report back with info
  25. #65
    May 10 2014
    16 A6 3.0T S-Line
    Atlanta, GA
    Has anyone gotten the memory function to work and would like to share how? I am starting with dual power standard seats and no memory. Due to rust, I have had to swap out all 4 doors and got some off of an S4 which does have the memory buttons and module. I recently decided that I wanted new seats and picked up some S5 seats off of ebay. I plan on getting the memory function working on the stock A4 seats first so that I know that I have a working base setup, but would like to know how that is going to xfer over to the S5 seats being I have read various things and just wanted a clearer picture of what I am up against as I didn't see anyone mentioning the memory module working before this thread fell silent. Thanks for everyone's hard work and research putting this together just looking to get that last bit in place for this retrofit.
    2016 A6 3.0T ZF8, S-Line Moonlight Blue, 57K, IE Stg 2 E85, JHM Race Pipes & Catted Down Pipes, AWE Touring, JHM Intake to RS7 Airbox, MERC Racing HX, CWA150, S6 Calipers, Crossdrilled Adams Rotors, EBC Yellow, Goodridge Lines, H&R Sways, ECS & 034 Endlinks, 20x9.5 Neuspeed Gunmetal RSF72, MPSS, RS Nav
    2008 A4 2.0T 6MT, S-Line Dolphin Gray, 96K
