What can cause the following symptoms:
- sometimes overheating (fans turned on with switch), but vents blowing cold; easy coasting on highway
- a few minutes later, temperature drops (even below operating temperature), and vents blowing hot
- water pump (German Graf) has 6k miles. Removed for inspection, impeller not slipping on shaft
- no coolant in oil
- no oil in coolant
Notes:
- rule out stuck thermostat (stuck close (overheating) would still blow hot air)
History:
- SNOW water/meth solenoid leaked water into intake pipe overnight, engine start hydrolocked
- 20 psi lower compression on cyl 2
- found one slightly bent exhaust valve in cyl 2, replaced.
- piston no real signs of damage. Removed and new rings installed
- cyl 2 still shows higher leak down numbers (currently sent out again for inspection)
- APR head studs
Any suggestions?
Could head gasket leak cause the above symptoms?
Crack in block?
Crack in head?
