Hello all -
Like many with early B8 S4s, I've got the SAI codes for both banks. My car was cleaned just before 50k miles and now appears to be asking for it again at 134k - so driving it harder has extended the time between issues.
I pulled the TSB with the procedure and figured I'd go through the diagnostic portion to be sure before planning a DIY project like this since the local dealer ballparks $2500, the local indy shop won't do it, and the tool is going to cost a grand by itself.
Using vagcom I performed the "Checking Secondary Air System" procedure and then checked the values stored in the MASS_SA_REL[0] and MASS_SA_REL[1] blocks as per the TSB. The diagnostic procedure states that if the values are between 0.1 and 0.7 that the system needs to be cleaned. In my case the values were both 0.047.
Anyone with an idea of what that value actually means? The after values are supposed to be 0.9 to 1.0 so I can only assume mine is "terrible" and might be so low as to be a pump or a hose problem instead?
Thanks for any insights.
