Results 1 to 40 of 42
    Jan 22 2020
    UK
    10.9 Second S6 shopping list and advice.
    Hi all
    Looking at the next project (currently in a mid/high 11 second B9 S4), in the UK low mileage 2018 S6's are really good value right now, this looks like a chance to drive a V8 before they are outlawed...
    I'm thinking the minimum list is going to be:
    * DS1 software
    * RS7 intake
    * RS7 turbo cartridges (SRM / HPA?)
    * HFC downpipe (Redstar?)
    * Bigger coolant pump
    That should be good for low 600bhp and scraping out a 10.99 I'm led to believe?
    Assuming this list sounds sane / adequate as a starting point, my next job is to do a bunch of research and understand the practicalities at hand. The main question I have however is for the replacement turbo cartridges, once all the intake stuff and oil lines are out the way, can you easily change the turbine and housing without having to remove all the exhaust side manifolds etc? Is this a DIY job for someone with medium skill?
    Thank you!
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by Boosted_six View Post
    Hi all
    * DS1 software
    * RS7 intake
    Thank you!
    You’ll need a TCU tune to achieve those numbers. Plus, it may save you a clutch replacement for a bit - the DL501 will not be able to handle the torque levels alone.
    If you have E85 near you, many have seen running cooler temps and HP gains.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Feb 21 2017
    St Louis
    There's a guy that hit mid 10s with stock turbos and full weight. Aggressive custom ECU and TCU tunes with ethanol would get you there. Your list is adequate, though you may need custom tunes as well.
    2016 Mythos Black S6 | 20% Tint | APR Exhaust | DS1 Stage 1
    Jun 19 2018
    NH
    Stock turbos may be a ticking time bomb - over spin fatigue has happened.
    Don’t forget about the oil screen - do something with it - remove or relocate; big debate which is still the best option.
    Registered User Four Rings John@DEADBEEF_DynoSp's Avatar
    Nov 01 2019
    Isle of Man
    In the UK when it is cool and with 99 RON fuel you can do OK, but the S6 is a higher compression engine than the S8/RS6/RS7 so can be disappointing for results if you use pump petrol only and don't have some methanol in the tank or water methanol injection. The 4.0T charge cooling is really poor and whilst the UK climate is never properly hot, the charge temperatures in summer can get too hot and really kill performance.
    With good conditions and good technique one guy got 10.8 in the US with E85 on an A8 with RS7 turbos and intakes and downpipes without pushing hard as he was just using an OTS map that is designed for harder use than just best quarter mile acceleration.
    We have higher staged OTS maps that push RS7 turbos hard, but they need supporting octane and ideally cooling. There is a tendency to push 4.0T engines really hard because they are tough, but people end up crossing the quarter mile with silly charge temperatures just holding out to get another tenth or mph. It is quite short term thinking in terms of reliability and can encourage grenade style tuning.
    Do have a look at the S8 too, they are also good value and a somewhat better base to modify.
    Feb 19 2020
    minnsota
    Hi all
    * DS1 software
    * RS7 intake
    Thank you!
    I run 10.49 on rs7 cartridges and downpipes only (SRM ECU and TCU)
    Sent from my SM-G973U1 using Tapatalk
    Junior Member Two Rings c13thx's Avatar
    Mar 19 2019
    The Lakes, England
    Hi all
    * DS1 software
    * RS7 intake
    Thank you!
    Good to see another UK guy on the S6 band wagon
    I have the DS1 on Stage2 with Peron 3.5 inch decat and milltek non res cat back current with the SRM intake and its amazing in current climate but what John said is completely right come summer time without meth it cripples the performance. You get a couple of good pulls and that's it heat soak.
    I have the SRM +4mm lined up to go in and just about to purchase aquamist hfs-4 to go with it for the cooling mainly but added octane will benefit for sure.
    For me I had the bigger pump but felt no benefit so will see what comes in the form of air to air in the future but hoping for now the water meth will drop the temps enough to get a little more run time before losing so much to heat.
    With just what I have currently alone its a whole world of difference and the DS1 like John said is solid not only for keeping the car within its limits safely but just wakes it up to what it should be. If your big into your cars what the DS1 brings with tune abilities also is next level for seeing what is actually going on in real time.
    I'll be sticking with the OTS for now but when the time comes with the DS1 at least I can just get it done remotely with a solid tuner rather than having to lose the car for a day and drive out of my way.
    That's my 2 pence anyway but like you said enjoying the V8 while it lasts is the main thing.
    Sent from my SM-G988B using Tapatalk
    Jun 19 2020
    Summerfield, FL
    Quote Originally Posted by dealermaintnd View Post
    What ...??
    Stock air intake (filter and tubes) ...?
    2015 Audi S4 (totaled )
    2017 Audi S6 Wickedly quick | Prestige w/ Black Optic | H&R sway Bars |Eurocode Alu Kreuz Drivetrain Stabilizer | 034 transmission and differential inserts | SRM driveshaft carrier bearing | SRM shorty intakes w/ RS7 airbox | APR ECU stage 1 and TCU | APR (non-res) catback | Giro Disc Front rotors w/ EBC Yellow pads │ 034 2 piece rear rotors w/ Hawk HPS 5.0
    Feb 19 2020
    minnsota
    Quote Originally Posted by Optimus247 View Post
    What ...??
    I made a big 3 inch intake with filters but it didn't help much so I run stock airbox. Realllllllly want the SRM inlets to help get my compressor rpm down. Where I am I have extremely low DA so I get results that are impossible in warmer climate
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    I mostly can understand your point going for S6 versus RS6/S8 as prices on the S are definatly more affordable. Went for S6 here in Belgium aswell few years ago, for roughly 20.000€ back then i found an S6 as good as fully loaded with options with ceramic brakes compaired to a semi loaded RS6. Definatly worth it and don't regret at all, especially it is more of a sleeper....but yeah, when it comes to performance, the RS/S8 difference in terms of engine and trans are pretty big :). But can't go wrong with both imho, just need to accept once you go stage 2 or higher, you will need to throw bigger money to support the performance!
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Established Member Two Rings Sinister6's Avatar
    Dec 27 2018
    2019 Audi S4, 2021 Supra
    Wisconsin
    No kidding, that's awesome.
    I'm going RS7 turbos very soon as well. I'm currently full bolt-on stage 2 so I'd be extremely happy with 10.5 (ish)
    What kind of tire were you running at the time?
    2018 Audi S6 Prestige (Mythos Black)
    RS7 Turbos / APR Tuned / APR Full Exhaust / APR Heat Exchanger / AWE Intake / APR Mobile / CeramicPro / 35% Tint / 21" HRE FF04 w/ Michelin PS4S / OEM RS6 Grille / CETE Module
    2019 Audi S4 Prestige (Quantum Grey)
    Vorsteiner VFF107 / APR Tuned / AWE / IE
    www.twinskrulldesign.com
    Feb 19 2020
    minnsota
    Quote Originally Posted by Sinister6 View Post
    Stock spec p0's on stock black optics wheels. Minnesota DA 100 - -100 and 30 degrees
    Dec 27 2018
    Wisconsin
    Nice work! I'm in Wisconsin and I'm running a lighter HRE with Michelin PS 4S.
    Feb 19 2020
    minnsota
    All I can say: launch rpm 3000, LLRMR(launch torque in NM) 300. This is the key to going fast.
    Dec 27 2018
    Wisconsin
    Thank you for the advice...I was not sure where to set the LC. I believe I currently have it set at 4K RPM.
    Feb 19 2020
    minnsota
    If you dont change that launch torque in the ecu tune it will just spin every launch and barely break 2.0 60ft
    Dec 27 2018
    Wisconsin
    Okay, 300 NM is approximately 225 ft lbs?
    Feb 19 2020
    minnsota
    I dont think this value is corrected or accurate, im just telling you what number worked for me in the ecu tune. You might be able to turns yours up more. But the stock 360 is wayyyyyyy too high for any tire.
    Jun 19 2018
    NH
    Nice work indeed - boost weather for sure at 30degrees lol. You may want to use this set-up in warmer weather, so likely the DA won’t be the same as the other member.
    PS4S’s cannot be used in temps below 40degrees - per Michelin
    Feb 19 2020
    minnsota
    Quote Originally Posted by MattyMarkey View Post
    Do a burnout launch first, thats what I do.
    Dec 27 2018
    Wisconsin
    For sure, The race that I signed myself up for will be taking place late June. looking for every advantage.
    Jun 19 2018
    NH
    Just making a distinction with Sinister6’s set-up versus the temperature you did your run - his tire set-up is not ideal in 30degree temps.
    Feb 19 2020
    minnsota
    Do you think mine is? Far from it.
    Dec 27 2018
    Wisconsin
    Were you still spinning hard out of the hole on your 10.4 run?
    I'm curious what the peak of the S6 (with RS turbos) performance is. A 10.4 has to be close...perhaps a tenth or two better?
    Feb 19 2020
    minnsota
    With the 300nm launch in the winter I get some spin yes, after warming tires up with a fake launch its more of a chirp. In the summer it will grip and go most of the time
    Dec 27 2018
    Wisconsin
    Thank you for the insight
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Quote Originally Posted by c13thx View Post
    Make that 2 UK guys, picking mine up tomorrow 👍
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Jun 19 2018
    NH
    Does your tire manufacturer specifically call out “Do not use in temperatures below 40degrees”???
    Because Michelin does for the PS4S. Exactly the distinction being made.
    Feb 19 2020
    minnsota
    Yes, use below 45 degrees voids the warranty on the p0's. I can confirm they perform pretty poorly in the cold too. But if you warm them up with a spinning launch they do alright
    Mar 02 2020
    Anchorage, Ak
    I've gone 10.53 on mine.
    Mods are:
    DS1 on 4x tune
    SRM TCU tune
    RS7 turbos
    SRM inlets
    SRM stage 1 coolant pump
    APR Downpipes
    on 104 file. I imagine running lower octane, but with ethanol, you should definitely be in the 10s. I've broken into the 10s on 93 octane with a DA of around 2500 before if that helps for reference.
    Jan 22 2020
    UK
    Thanks for the feedback all.
    Just some thoughts overall:
    The DSG gearbox while it doesn't exactly love monster torque, it don't seem particularly fragile? I think it will be fine with some sympathy right?
    I have 94aki/99ron fuel for the daily that can be bumped 2-3 points with a slosh of Boostaine when required. Ethanol is not really an option.
    The car was built in the summer of 2018 so has the latest revision oil screen.
    I'm trying to find a UK supplier for the RS6/7 turbo cores and compressor. I'm not sure 2 grand is good value for an OEM core and cover shipped over from the USA. There are lots in China for cheap cheap, but I'm not that brave.
    Nov 13 2014
    Manchester, England
    As long as you're not launching it everywhere then it should be fine for the occasional lunatic driving.
    I'm looking into doing a 20% methanol blend when I get my DS1 which should yield decent results, you can get it delivered in 25l drums off ebay
    As for turbos, hit this guy up and see what he can do to your existing turbos for you
    https://en-gb.facebook.com/Turbo-Ber...2262361478082/
    Dec 27 2018
    Wisconsin
    Have you looked at CTS Turbo? They have the RS7 turbos on sale for $1,445.00 USD.
    https://www.ctsturbo.com/product/cts...s7-s8-rs6-rs7/
    I too have a 2018 S6 with the revised oil screen, but for safety purposes, I'm still going to do the external oil screen relocation kit.
    https://jhmotorsports.com/stainless-...8-s8-4-0t.html
    Nov 13 2014
    Manchester, England
    3.5% import tax plus 20% VAT + shipping costs to the uk...gets expensive!
    Sep 07 2010
    Belgium
    Quote Originally Posted by skiptowncat View Post
    Maybe check with TurboSystems, they are Europe....but if not mistaken since you guys had the Brexit there is again import costs on European stuff afaik and recently read in the newspaper (i'm from Belgium).
    For what it is worth, might want to check that UK turbo shop, forgot the name but a Youtuber got a hybrid one from them (the guy that broke his axle before doing the swap) and sold his RS6 little after he installed the hybrids. They told it was not a crazy top end turbo, but allowed quick spooling.
    Nov 13 2014
    Manchester, England
    Still have to pay the VAT whatever it is, now if you can get the company to mark down the value of the goods however....
    That link I posted is a decent fella, he did loads of hybrids and upgrades for the Mazda platform.
    Jul 16 2019
    Sydney Australia
    Quote Originally Posted by Dasquade View Post
    This guy?
    https://youtu.be/TU3_YAgSQns
    Sep 07 2010
    Belgium
    Quote Originally Posted by choppedfish View Post
    Yes, Turbo Technics.
    Jan 22 2020
    UK
    Please don't lynch me... I've decided to head back to BMW with a 4.4L twin turbo V8
    Nov 01 2019
    Isle of Man
    I'd have one already if I had faith in the rods not to bend. Audi have their fair share of problems too though.
