HAPPY NEW YEAR Audiziners ! Lets all hope this is a much much better one...
Crawled under Wolfie to have a quick look before a visit to the hoist.
I discovered that when I hold the input flange on the rear diff and try to rock the tailshaft there is a small,really small amount of movement whereas when I do this on the output shaft of the front diff-nothing.
When I grab the shaft about a foot behind the front diff and rock it backwards and forwards I can hear click click click.Hard to tell from which end or where as it is probably transmitted noise ? Note no click noise obvious when I see the movement on the rear diff.
I don't know if its gear noise from the diff transmitted or what.
The center bearing looks fine as far as the donut go's (hard to see because of heat shield )
I also found this :
Rear muffler looking rearward ,look at the muffler mount -its a heavy welded rod that forms a U and then connects to car with a donut at each end-the tailshaft has been rubbing and in fact worn the rod down.I've never heard any noise which I could put down to this and not the noise this thread is about I wouldn't think-but maybe it is ?.
Closeup of the situation :
No mods to rear of exhaust other than dp and no impacts...
So is this evidence of too much driveshaft movement ?
Are my findings above indicating stuffed rear CV joint on tailshaft ?
What do you think ?
